New to receivers/amps...pretty much home theatre in general. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-14-2012, 02:48 PM - Thread Starter
Achillees's Avatar
I recently ordered a Polk Audio PSW10 10-Inch Monitor Series Powered Subwoofer and Polk Audio CS20 Center Channel Speaker to start my set up.
Little did I know (please be gentle) that I'd need a receiver/amplifier for the set up. I'd been anticipating connecting them directly to my TV. That's my fault. So now, I'm looking for a good receiver/amp to go with the setup without breaking the bank. Think...<$300...the lower the better.
I have a LG 32CS460 32-Inch 720p which I'll be looking to upgrade much later on.
Right now I have my sub connected to the cable box...because my TV doesn't have audio out. My ps3 is connected directly to the TV, so my sub is useless for gaming. Don't even get me started on the center speaker...the sub has ports for speaker wire, which I connected the center channel to, but doesn't work. Which I guess is why I need a receiver/amp.
So, I guess my question is....help?
Thanks in advance.
Achillees is offline
post #2 of 5 Old 11-14-2012, 03:37 PM
Scout's staff's Avatar
Wow -
What are you using for your main L&R speakers - the TV? Adding a receiver (AVR) with component video out (red, blue & green RCA cables) will be key for you until you upgrade to a TV with HDMI inputs. In the meantime, I believe you can run a second line of speaker wire from either the left or right main output to the subwoofer. It should pull the low frequency signal being directed to the chosen speaker.
Here are a couple of options to start your AVR search with (Again these have the component video out function - not just HDMI) - all under $300
Yamaha
http://www.amazon.com/Yamaha-RX-V373-5-1-Channel-AV-Receiver/dp/B007JF8FD8/ref=sr_1_5?s=electronics&ie=UTF8&qid=1352931484&sr=1-5&keywords=receiver
Onkyo
http://www.amazon.com/Onkyo-TX-NR414-5-1-Channel-Network-Receiver/dp/B0077V88YU/ref=sr_1_14?s=electronics&ie=UTF8&qid=1352931484&sr=1-14&keywords=receiver
Scout's staff is offline
post #3 of 5 Old 11-14-2012, 03:53 PM - Thread Starter
Achillees's Avatar
Originally Posted by Scout's staff View Post
Wow -
Yamaha
Onkyo
Thanks for responding, Scout.
Sorry if I misspoke, my TV does have HDMI inputs. It's connected to the cable box and my ps3 via HDMI, but currently, I have just the subwoofer and the center channel speaker. The center channel is currently a huge paperweight because there's no power going to it. The subwoofer is connected directly to the cable box, because I don't have RCA audio outs on my TV. I tried connecting the speaker wire from the center speaker to the subwoofer, but nothing comes out. frown.gif
I've been doing a bit of research though, and read that Onkyo has issues with HDMI...
post #4 of 5 Old 11-14-2012, 04:18 PM
jdsmoothie's Avatar
Quoted: 12217 Post(s)
Liked: 5563
If you want a networking AVR then the Denon 1613 ....
http://www.accessories4less.com/make-a-store/item/DENAVR1613/DENON-AVR-1613-5.1ch-Networking-Receiver-w/AirPlay-3D-ready/1.html
otherwise the Denon 1612 (from same reseller) if networking not required. Neither the previously recommended Onkyo or Yamaha will be able to EQ the subwoofer, while both the Denon 1612 and 1613 can.
jdsmoothie is offline
post #5 of 5 Old 11-14-2012, 04:41 PM - Thread Starter
Achillees's Avatar
That does look good.
I read that the networking is wired, not wireless...meaning I'd have to connect my laptop to it via ethernet cord to play music from?
Also, how reliable would a second-had receiver be? I saw that it says "Denon Refurbished", but I've always been wary about buying electronics secondhand.
Thanks for replying.
