Quick AirPlay question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-14-2012, 04:46 PM - Thread Starter
Gomdaf's Avatar
I'm looking at Denon and Onkyo. Just came across smokin deal on a 5009 that I think i might jump on. The only thing that bugs me is lack of AirPlay
Is there a way to "add" AirPlay capability via an external box or something? Would the apple TV box give me the same features as having an AV with built in AirPlay or am I just way off base here.
Any help would be appreciated
Gomdaf is offline
post #2 of 5 Old 11-14-2012, 04:49 PM
ccotenj's Avatar
Liked: 101
yes... it actually gives you more, as you can stream video with the atv as well... smile.gif
- chris
ccotenj is offline
post #3 of 5 Old 11-14-2012, 04:50 PM
XStanleyX's Avatar
Liked: 1269
Yep, the apple TV will give you airplay. Works quite well.
XStanleyX is offline
post #4 of 5 Old 11-14-2012, 04:56 PM - Thread Starter
Gomdaf's Avatar
Nice! Thanks for the quick replies. So I would then just connect via hdmi to Avr and Hdmi out from AVR to projector and presto?
Gomdaf is offline
post #5 of 5 Old 11-14-2012, 04:58 PM
ccotenj's Avatar
Liked: 101
- chris
ccotenj is offline
