Looking for a cheap replacement for my Denon 1709. Wii U doesn't support optical Audio :( - AVS Forum | Home Theater Discussions And Reviews
Old 11-15-2012, 10:25 PM - Thread Starter
treepop's Avatar
Hey there,
I am looking to upgrade my Denon 1709. The upcoming Wii U doesn't support optical audio out, so I am forced to purchase a new receiver.
I really just want something with identical quality and features to my 1709, but with hdmi surround pass through capability. I also love my audysee multEQ. My room is massive and I have really enjoyed how well the Denon 1709 has filled my room and I give a lot of the credit to the multEQ.
I am looking for something used and cheap. Thinking $180? $200? Shoot I would love $150 or $100. This doesn't seem to far fetched, seeing as I see my beloved 1709 for $80 and less all day. I am thinking the 1909 my be a nice option, but is it the best option? Is there really anything I might be missing above the 1909?
treepop is offline
Old 11-16-2012, 03:32 AM
jdsmoothie's Avatar
Quoted: 12180 Post(s)
Liked: 5548
If you just need to add another HDMI input, why not just add an HDMI switch from forum sponsor Monoprice?
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011001&p_id=8150&seq=1&format=2
jdsmoothie is online now
Old 11-16-2012, 07:09 AM - Thread Starter
treepop's Avatar
I wish it were that simple. Unfortunatly the 1709 only passes through Video. It does not allow for any sound, let alone Dolby 5.1 etc..
treepop is offline
Old 11-16-2012, 07:13 AM
ccotenj's Avatar
Liked: 101
i'm a bit confused... why do you need to "pass through" the audio?
- chris
ccotenj is offline
Old 11-16-2012, 10:19 AM
Ross Ridge's Avatar
Liked: 81
I think he mispoke and just needs a basic AV receiver that's capable of decoding HDMI audio. His receiver is one of those early HDMI models that could only switch HDMI.
This Ambery HDMI audio decoder should let him hook up a Wii U to the analogue multi-channel inputs of his AVR-1709 and get surround audio. (Note that the optical output of this device or any other similar device will only get stereo audio when used with the Wii U.)
Ross Ridge is offline
Old 11-16-2012, 03:26 PM
jdsmoothie's Avatar
Liked: 5548
So just connect the analog audio cable from the Wii U and let the 1709 use DD PLII to simulate 5.1. Otherwise, a refurb 1612 fits in your budget.
http://www.accessories4less.com/make-a-store/item/DENAVR1612/DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver/1.html
Old 11-16-2012, 10:47 PM - Thread Starter
treepop's Avatar
Thanks for the link. That looks good. Curious. What is the difference between the 1612 and 591? I know the 1612 has upscalling and 5.1 while the 1611 has no upscalling, but 7.1. So is the only differance between the 591 and the 1612 upscalling? Is the remote controller different? Is there any reason to get the 1612 over the 591? I will only ever use 5.1 and never need multizone.
treepop is offline
Old 11-16-2012, 11:17 PM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
Your info is wrong. Actually the 591 and 1611 will convert analog video to HDMI and the 1612 does not. I own a 591 so I am sure about this. Both the 591 and 1611 also have one component video input and the 1612 does not have any. The 1611 is a 7.1 receiver and the surroud back channels can also be assigned to zone 2.
The advantage of the 1612 are the front USB input and it will overlay the on screen display over HDMI. I wouldn't trade my 591 for a 1612 unless I had all HDMI devices.
Check your local best buy for clearance sales on the xx12 models. I found a Denon 1912 for $199 at one of the stores by me.
Afro GT
afrogt is online now
Old 11-17-2012, 08:28 AM - Thread Starter
treepop's Avatar
Good to know. So the 1611/591 seems better in every way except usb and the osd. Also, GREAT FIND on that 1912! I would buy that in a heart beat.
treepop is offline
Old 11-18-2012, 02:10 AM - Thread Starter
treepop's Avatar
treepop is offline
