The **OFFICIAL** Onkyo TX-NRxx10 thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-18-2012, 07:17 PM - Thread Starter
Lepus's Avatar
TX-NR1010
Special Features
  • 9in/2out HDMI Support for 3D Video and Audio Return Channel
  • THX Ultra2 Plus Certified
  • Network Capability Delivers Internet Radio and Network Streaming
  • Dual Core Video Engine w/ HQV Vida and Marvell Qdeo™ Processing
  • MHL™ (Mobile High-Definition Link) for Smart Phone Content on HDTV
  • Picture-in-Picture Input Source Preview with InstaPrevue™ Technology
  • Zone 2 HDMI Output for HD Video in a Second Zone
  • Digital Crossover Processing Network to Cancel Crossover Interference
  • Direct Digital Connection of iPod/iPhone via Front-Panel USB Port
  • Onkyo Remote App for iPod/iPhone
  • DTS Neo:X, Dolby® Pro Logic® IIz and Audyssey DSX Add New Dimensions to Surround Sound
  • Hybrid Standby Function to Reduce Power Consumption
Product Specifications
Amplifier
# Channels 7.2
Power Watts/ch -
Power (8ohms 20-20kHz 0.05%) /Ch 140W (8ohms 20-20kHz, 0.05%, 2 Channels Driven, FTC)
THX Certified Ultra2 Plus
Continuous 6ohms Rated
Certified 4ohms performance
All Discrete Circuitry
3-Stage Inverted Darlington Circuitry
PUSH-PULL Design
Independent Block Construction (Amp/Preprocessor)
Toroidal Transformer -
Independent Power Supply -
Bi-amp Capability For Front
BTL Capability For Front -
Processing
DOLBY Decoder True HD, DD Plus, PLIIz
DTS Decoder DTS-HD Master Audio, DTS-HD Express
DTS Neo:X
Dolby PLIIz
ONKYO GAME Surround Modes
THX Processing Mode
Audyssey DSX
Audyssey Dynamic EQ
Audyssey Dynamic Volume
Direct/Pure Mode /
Music Optimizer (Advanced)
192K/24 Bit DACs (Burr-Brown)
VLSC
isf Certified Calibration Control
Connectivity
Audio I/O 8 / 1
Phono Input
Digital Audio IN (OPT/COAX) 3 / 3
Digital Audio OUT (OPT/COAX) -
Composite I/O 5 / 1
S-Video I/O - / -
Component Video I/O 2 / 1
Front-Panel A/V V / R / L
Front-Panel Optical
USB Input Front (made for iPod/iPhone) and Rear
HDMI I/O 9 (7 + 1)/ 2
HDMI Support 3D video, Audio Return Channel, DeepColor, x.v.Color, LipSync, CEC
Component Video Upconversion -
Analog To HDMI Upconversion
1080p Upscaling (HQV Vida)
4K (up to 4096 x 2160) Upscaling (Marvell Qdeo)
Multi-Channel Input -
Analog Pre-Outs 9.2
Speaker A/+B -
Powered Zone2
Powered Zone3
Zone 2 Line Out
Zone 2 Video Out (Composite, HDMI)
Zone 3 Line Out
U-Port -
iPod Ready (direct USB input)
HD Radio
Internet Radio Capable (vTuner, Pandora, Spotify, Rhapsody, Sirius/XM iRadio, Slacker, LastFM iRadio, Aupeo, MP3tunes)
Streaming Audio From PC
Streaming Audio From USB memory
Wireless Network Ready via USB (optional UWF-1)
Bluetooth Ready via USB (Optional UBT-1)
PC Input (15 pin D-sub)
Integration Access
RS-232
IR Input
Ethernet
ONKYO-RI System Control
12V Trigger (zone 2/3)
Miscellaneous
Pre-Pro/Learning Remote /
Back-Lit Remote -
On Screen Remote Programming
Bi-directional Remote Setup via GUI
Activity Based Remote
Color-Coded Speaker Terminals
Auto Speaker Calibration W/Mic. (Audyssey MultiEQXT32)
OSD Out (advanced "Home" GUI)
Solid Aluminum Front
Warranty 2 YEARS
Amplifier Section
Power Output -
All Channels 140 W (8 ohms, 20 Hz-20 kHz,
0.05%, 2 channels driven, FTC)
Front L/R 140 W (8 ohms, 20 Hz-20 kHz,
170 W + 170 W (6 ohms, 1 kHz, 0.1%,
Center 140 W (8 ohms, 20 Hz-20 kHz,
Surround L/R 140 W (8 ohms, 20 Hz-20 kHz,
Surround Back L/R 140 W (8 ohms, 20 Hz-20 kHz,
Dynamic Power 320 W (3 ohms, 1 ch)
270 W (4 ohms, 1 ch)
160 W (8 ohms, 1 ch)
THD+N (Total Harmonic Distortion + Noise) 0.05% (20 Hz-20 kHz, Rated power)
Damping Factor 60 (Front, 1 kHz, 8 ohms)
Input Sensitivity and Impedance 200 mV/47 k-ohms (Line)
2.5 mV/47 k-ohms (Phono MM)
Maximum RCA Output Level and Impedance 5.5 V/470 ohms (Pre out)
Phono Overload 70 mV (MM, 1 kHz, 0.5%)
Frequency Response 5 Hz-100 kHz/+1 dB, -3 dB (Direct Mode)
Tone Control ±10 dB, 50 Hz (Bass)
±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio 110 dB (Line, IHF-A)
80 dB (Phono MM, IHF-A)
Speaker Impedance 4 Ohms–16 Ohms or 6 Ohms–16 Ohms
Video Section
Input Sensitivity/Output Level and Impedance -
Video 1 Vp-p/75 ohms (Component)
0.7 Vp-p/75 ohms (Component PB/CB, PR/CR)
1 Vp-p/75 ohms (Composite)
Component Video Frequency Response 5 Hz–100 MHz, -3dB
Tuner Section
Tuning Frequency Range -
FM 87.5 MHz–107.9 MHz
AM 530 kHz–1,710 kHz
FM/AM Preset Memory 40 stations
General
Power Supply AC 120 V, 60 Hz
Power Consumption 8.6A
Standby Power Consumption 0.1W
Dimensions (W x H x D) 17 1/8" x 7 13/16" x 18 1/4" (435 x 198.5 x 463.5 mm)
Weight 50.7 lbs (23.0 kg)
_________________________________________________________________________
TX-NR3010
Special Features
  • 9in/2out HDMI Support for 3D, Audio Return Channel, DeepColor™, x.v.Color™, LipSync, Dolby® TrueHD, DTS-HD Master Audio™, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC
  • Multi-Transformer for Audio, Video, and Digital Processing
  • 11.4 Multichannel Pre-Outs
Amplifier
# Channels 9.2
Power Watts/ch -
PUSH-PULL Design
Independent Power Supply (4 Transformers)
Processing
DTS Neo:X
Dolby PLIIz
THX Processing Mode
Audyssey DSX
Audyssey Dynamic EQ
Direct/Pure Mode /
VLSC
Connectivity
Audio I/O 8 / 1
Phono Input
Composite I/O 5 / 1
S-Video I/O - / -
Front-Panel Optical
HDMI I/O 9 (7 + 1) / 2
Analog Pre-Outs 11.4
Speaker A/+B -
Powered Zone2
Powered Zone3
Zone 2 Line Out
Zone 3 Line Out
U-Port -
HD Radio
Integration Access
RS-232
IR Input
Ethernet
12V Trigger (Zone 2/3)
Miscellaneous
Back-Lit Remote -
Warranty 2 YEARS
Amplifier Section -
Power Output -
Video Section -
Tuner Section -
General -
Power Consumption 11.0A
Weight 55.1 lbs (25.0 kg)
TX-NR5010
Special Features
  • Massive Toroidal Transformer and Two Separate Transformers for Audio and Video Processing
Amplifier
# Channels 9.2
Power Watts/ch 145 x 9
Power (8ohms 20-20kHz 0.05%) /Ch 145W (8ohms 20-20kHz, 0.05%, 2 Channels Driven, FTC)
PUSH-PULL Design
Processing
DTS Neo:X
Dolby PLIIz
THX Processing Mode
Audyssey DSX
Audyssey Dynamic EQ
Direct/Pure Mode /
192K/32 Bit DACs (Burr-Brown)
VLSC
Connectivity
Audio I/O 7 / 1
Phono Input
Digital Audio IN (OPT/COAX) 4 / 3
Composite I/O 5 / 1
S-Video I/O - / -
Front-Panel A/V Analog L+R + Optical / Composite
Front-Panel Optical
HDMI I/O 9 (8 + 1) / 2
Speaker A/+B -
Powered Zone2
Powered Zone3
Zone 2 Line Out
Zone 3 Line Out
U-Port -
iPod Ready (Direct USB input)
HD Radio
Integration Access
RS-232
IR Input
Ethernet
Miscellaneous
Back-Lit Remote -
Warranty 2 YEARS
Amplifier Section
Power Output -
All Channels 145 W (8 ohms, 20 Hz-20 kHz,
Front L/R 145 W (8 ohms, 20 Hz-20 kHz,
175 W + 175 W (6 ohms, 1 kHz, 0.1%,
Center 145 W (8 ohms, 20 Hz-20 kHz,
Surround L/R 145 W (8 ohms, 20 Hz-20 kHz,
Surround Back L/R 145 W (8 ohms, 20 Hz-20 kHz,
Dynamic Power 400 W (3 ohms, 1 ch)
300 W (4 ohms, 1 ch)
180 W (8 ohms, 1 ch)
Video Section
Tuner Section
General
Power Consumption 12.4A
Lepus is offline
post #2 of 4 Old 11-18-2012, 07:21 PM - Thread Starter
Lepus's Avatar
Since there was no official thread for this receiver I thought I would start one. Just finished setting the 3010 with some Paradigm speakers Center 3, Monitor 9s, Surround 1 + 3, and DSP3200....
All I have to say is that this is one nice receiver, with all the features that it has, I just have to say wow. The box I received was banged up a little, but the receiver looked pristine when I received it. I did the software update right away, and it took no problem. The unit said it would take an hour to do the update. I've sent music from PC to the receiver, but for some reason it won't do video, not sure if I missed something somewhere.
I recently upgraded from a Denon 3805, since I did not compare them side by side I really can't say much, except there are a lot of newer features and I like them. My wifes reaction when we watched a TV show, she thought it was weird, as she heard stuff behind here and couldn't figure what it was. She was like; "did you hear that". Never had dipole speakers and they are quite enveloping.
Lepus is offline
post #3 of 4 Old 11-19-2012, 04:30 AM
jdsmoothie's Avatar
Quoted: 12119 Post(s)
Liked: 5518
jdsmoothie is online now
post #4 of 4 Old 12-01-2012, 08:30 PM
baaless's Avatar
What color is the receiver's display? Can it be dimmed? How bad is the heat production in a smaller cabinet?
baaless is offline
Onkyo Tx Nr1010 Network A V Receiver
