Is it my receiver or speakers that's under powered? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 11-19-2012, 11:11 AM - Thread Starter
lilfleck's Avatar
Hey guys,
I have a Yamaha RX-V467 paired with KEF bookshelf speakers and center.
Subwoofer: BIC F-12
I've always noticed it took quite a bit for these speakers to really shine. When watching a bluray, I have to crank it to around -10db. Normal tv viewing, it's probably sitting around -23db. With black friday around the corner, I was thinking about upgrading to floor standing speakers and moving these to the rear; however, I am thinking what if my receiver isn't powerful enough for an upgrade...
What are your thoughts on my setup and what I should upgrade next. I watch most of my content from my HTPC. TV shows & movies. Little music.
lilfleck is offline
post #2 of 20 Old 11-19-2012, 11:15 AM
ccotenj's Avatar
Liked: 101
assuming you have run ypao, those volume levels sound perfecrly normal and in no way indicate that the avr is underpowered...
iow, you are fine...
- chris
ccotenj is offline
post #3 of 20 Old 11-19-2012, 11:18 AM - Thread Starter
lilfleck's Avatar
I have. Thanks. In that case... whats next to upgrade? I want better sound. While it sounds good, it doesn't really blow me away.
lilfleck is offline
post #4 of 20 Old 11-19-2012, 11:27 AM
ccotenj's Avatar
Liked: 101
1) speakers/sub...
2) the room they are in...
- chris
ccotenj is offline
post #5 of 20 Old 11-19-2012, 05:49 PM
NorCalJason's Avatar
Liked: 30
Your receiver is fairly modest. And your bookshelf speakers are inefficient.
Your easiest path to "sound that blows you away" is some efficient (90db+) 8 ohm speakers.
NorCalJason is offline
post #6 of 20 Old 11-19-2012, 06:06 PM - Thread Starter
lilfleck's Avatar
Hm... anyone know of a set of floor standing speakers I can grab for around $300 (pair)? I almost got the Polk 70s on newegg for $300 the other day... then I read some reviews that argued other bookshelf speakers being better for cheaper.
lilfleck is offline
post #7 of 20 Old 11-19-2012, 06:27 PM
M Code's Avatar
Quoted: 816 Post(s)
Liked: 499
Frys has been selling some nice JBL floor standing towers for <$300 about 50% off..
The JBLs are very efficient and a real 50W/CH amplifier powers them nicely..
M Code is online now
post #8 of 20 Old 11-19-2012, 08:32 PM
afrogt's Avatar
Quoted: 1440 Post(s)
Liked: 983
Fry's also has the Infinity P363 towers for $109 each.
Afro GT
afrogt is offline
post #9 of 20 Old 11-19-2012, 08:34 PM
derrickdj1's Avatar
Quoted: 998 Post(s)
Liked: 740
Check Vann's.com for some Klipsch speakers. Very efficient and great for TV and movies.
derrickdj1 is offline
post #10 of 20 Old 11-20-2012, 03:56 AM - Thread Starter
lilfleck's Avatar
Is there a consensus on what's the best bang for the buck floor standing speakers for my price range?
I don't have a Frys near me (NJ), so I'd have to ship. Could you guys provide suggested models? I don't want to buy completely blind.
Tapped and talked.
lilfleck is offline
post #11 of 20 Old 11-20-2012, 04:20 AM
g_bartman's Avatar
Quoted: 170 Post(s)
Liked: 139
I saw a black Friday ad for best buy that had half price Klipsch floor standers listed. Don't remember the model number.
g_bartman is offline
post #12 of 20 Old 11-20-2012, 05:15 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
There are 3 relevant truths:
(1) Just about every AVR has 100 wpc +/- 3 dB.
(2) Very few people are troubled by clipping in the power amps of their AVR.
(3) It takes 10 dB more power to create the impression of doubled loudness. That's 10 times! IOW you next power amp needs to be rated at no less then 1 KW/channel 8 ohms, low distortion.
Read and reconsider:
http://www.kef.com/html/us/showroom/hi-fi_series/c_series/fact_sheet/bookshelf/c3/index.html
If 88 dB/W speakers are "inefficient" home audio speakers then there is a blizzard in San Diego today. ;-)
His speakers have average efficiency.
88 db is only 2 dB less than 90 dB. While I see home speakers rated at 95 dB efficiency, I suspect that at least some of that is specsmanship. That all said 95 dB is only 7 dB more than 88 dB and thats still less than 10 dB.
As I pointed out in the discussion of amplifier power, 3 dB more loudness isn't a good justication for even just a chicken to cross the road. ;-)
The weakest parts of his system are the cheap subwoofer, room acoustics and system setup.
Running YPAO is just the beginning when it comes to system tuning.
Just because his sub has a 12" driver doesn't mean it has enough Xmax to blow your nose. The anemic 150 watt (rms? peak? PMPO?) power amp driving it is probably a tacit admission of the fact.
arnyk is offline
post #13 of 20 Old 11-20-2012, 05:25 AM
Theresa's Avatar
Liked: 51
I'm frequently dismayed when I see efficiency "specs" given for speakers taken as gospel truth when in reality they are more marketing than anything else. There are 86/db/watt/meter that have 90db given as their efficiency.
Theresa is offline
post #14 of 20 Old 11-20-2012, 05:31 AM - Thread Starter
lilfleck's Avatar
Are they any good?
http://*******/rURRh - $175 ea
http://*******/eGlKv
Reading through this thread, seems like mixed opinions. Guess I'd have to listen in person. In the meantime, isn't there a popular go-to value speaker? Is it the Polk 70 and did I screw up by not biting on $300 for the pair?
lilfleck is offline
post #15 of 20 Old 11-20-2012, 06:03 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Are they any good?
Something wrong someplace. If this is a 2-way ported floorstander with a waveguide tweeter, what's that second 6 1/2" whatsis on the front of the speaker?
No way can a single 6 1/2 speaker be the cure for a 12 inch long-stroke subwoofer that ain't there!
At least the picture matches the speaker's specs.
However the same basic truth applies.
No way can two 6 1/2 speakesr be the cure for a 12 inch long-stroke subwoofer that ain't there!
Yup, and you just ignored a big chunk of it.
Not my favorite answer. The sound of speakers is profoundly affected by the room they are in and the setup. If you are going to audition speakers meaningfully, do it right (in your listening room, with an optimized setup for that speaker) or don't do it at all!
Your biggest mistake so far involved things like not learning how to spell Hsu, and/or not spending $500 or more on a decent subwoofer. ;-)
arnyk is offline
post #16 of 20 Old 11-20-2012, 06:21 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Are they any good?
Sure there are, the polk monitors, the andrew jones pioneers, and the infinity P363's are among the most commonly referenced budget speakers talked about on this site. Start with one of them.
You shoulda got the polk monitor 70's when you had the chance instead of second guessing yourself. tongue.gif
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #17 of 20 Old 11-20-2012, 12:58 PM
Liked: 30
Newegg is having a black friday special on the Polk Monitor 60's. $99 each with free shipping.
post #18 of 20 Old 11-20-2012, 02:03 PM
Kini62's Avatar
Quoted: 1746 Post(s)
Liked: 1558
If that is your goal then going to Polk monitor series is taking a backward step from that goal. Louder? Likely. So if your equating loud with better than get the Polks. If you want something better than you might need to spend a little more.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #19 of 20 Old 11-27-2012, 07:31 AM - Thread Starter
lilfleck's Avatar
Are the Polk Monitor 60 and 70 not as good quality as my KEF bookshelfs? The floorstanding KEF's are definitely out of my price range and unfortunately, there are no local retailers who carry KEF anymore frown.gif
lilfleck is offline
post #20 of 20 Old 11-27-2012, 08:11 AM
clanmjc's Avatar
I have the Polk M60, and while they sound great for a budget floorstander I wish I would have spent a little more money. I would suggest looking at premier acoustic and bic acoustech floorstanders. The prices on these are around the price of polk monitor series but the driver and build quality is that of the RTI series and upper end Klipsh. I recently just picked up the premier acoustic pa-6s for my side surrounds and they sound so much better than any speaker in my system right now (lol?). A neighbor has the Premier Acoustic PA-8F which he bought for his game room (I convinced him after having purchased the pa-150 sub). They sounded so awesome, we both agreed they sounded better than his Polk RTI A7 (who would have thought), so now the Premier acoustics sit in his main theater and the Polks in his game room. The premiers can be had for close to $400 for a pair and the PA-6F for probably less than the Monitors you were looking at that will absolutely destroy them. They are still doing their Black Friday deals too (as far as it looks from the website), I'd look into it.
I haven't heard the Bic Acoustech's in person, so I have no real world experience with them, I've only read and researched and everything I've seen has been positive. To me they are the ID Klipsch speakers and the Premiers are the ID Polk speakers (They have no relation this is all just perception).
VIZIO E601i-A3
AVR: Denon 3312CI
Front L/R: 2 Polk M60's
Center: Polk CS2
Surround L/R: Premier Acoustic PA-6s
Sub: PA-150 Subwoofer
clanmjc is offline
