Help: Yamaha rx-v373 stops playing sound while listening to music - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-22-2012, 02:36 AM - Thread Starter
turbobnl's Avatar
Quoted: 16 Post(s)
Hello Avs Members
I’m having issues with my new receiver. When playing music from my iphone or ipad through the front usb, it would play a few songs. After playing a few songs the sound would stop playing while showing the music is still being played. I have tried a new cable and yet still the same problem. The only way for the problem to be fixed is if i disconnect the ipod and reconnect it.
Any help would be very much appreciated. Thank you
Equipment:
Yamaha rx-v373
Polk Audio CS2 series 2 center
Polk Audio Mointor 60 series 2 floor stand
Polk Audio T15 surrounds
Polk Audio PSW10 subs
turbobnl is offline
post #2 of 5 Old 01-26-2013, 02:31 AM
bonzoq's Avatar
I'm having exactly the same issue with my yamaha rx-v373. Have you managed to do something with it?
bonzoq is offline
post #3 of 5 Old 01-26-2013, 02:54 AM
GaryWA's Avatar
Quoted: 16 Post(s)
Don't have a lot of experience with Yamaha, but definitely sounds like a firmware issue.
GaryWA is offline
post #4 of 5 Old 01-26-2013, 10:18 AM
SleepyKat's Avatar
When this happens, if you switch to like BD or any other input and back to the iPod makes any difference or do you have to physically disconnect the iPod and plug it back?
SleepyKat is offline
post #5 of 5 Old 02-17-2013, 06:21 PM - Thread Starter
turbobnl's Avatar
Quoted: 16 Post(s)
I have not tried the method above, I know when unplugging/plugging the iphone/ipad without touching the receiver, the music will play.
Does the rx-v373 receiver allow you to update the firmware?
also another question, is it normal for my polk audio subwoofer to have a humming noise when putting my ear next to it?
turbobnl is offline
Yamaha Rx V373 5 1 Channel Av Receiver
