I need help finding my first 5.1 channel receiver. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-23-2012, 01:44 AM - Thread Starter
gopanthersgo1's Avatar
I've been looking around for a good 5.1 channel receiver. I've been looking at the Denon AVR-1613 which costs $270 (Until the 25th of this month). My budget is anything $300 or under. Please don't recommend me anything over than that, as whenever that happens, I start spending a TON of money on a first time deal, and start to regret it. I have absolutely no problem in buying used, as long as it's not scratched up, and still works perfectly. I prefer a warmer, lusher sound with a forward mid range, as I mostly listen to rock and alternative rock, but also play games and watch movies all the time. The speakers I will be using this with are undecided, and I'll look into them after the receiver, but until then I'll be running some CHEAP Panasonic surround speakers that came with a system for only $160, but I now realize that they sound horrible. The only thing about the Denon, is that it's highs are supposed to be rolled off. The overall U.I. doesn't matter to me, as I have too much time on my hands most of the time.
Thanks in advance for all the help,
Mark K,
gopanthersgo1 is offline
post #2 of 6 Old 11-23-2012, 10:39 AM - Thread Starter
If I buy the the Denon, it will be in less than 2 hours, feedback would be GREATLY appreciated
Thanks in advance,
Mark K.
post #3 of 6 Old 11-23-2012, 11:02 AM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
The speakers you purchase make way more difference than the receiver.
Since when do receivers have rolled off highs? That 's usually a comment reserved for speakers.
If the Denon 1613 has all the features you want then it'll be a good purchase.
Afro GT
afrogt is offline
post #4 of 6 Old 11-23-2012, 11:09 AM
XStanleyX's Avatar
Liked: 1269
+1
Pull the trigger.
XStanleyX is offline
post #5 of 6 Old 11-23-2012, 11:10 AM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
So, did you get the Denon? I own the 1613 and eventhough I had my doubts about it early on, I've come to really like it.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #6 of 6 Old 11-23-2012, 10:43 PM - Thread Starter
I didn't get it, I decided to get a Nexus 7 instead, but am still really wanting to get a Denon receiver, but I want to save up until I can afford the Denon, and some decent speakers.
