Which <$200 budget HT receiver - Yamaha RX-V371, Onkyo TX-NR414, Sony STRDH520 or Pioneer VSX822 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 11-23-2012, 09:00 AM - Thread Starter
b8b
b8b's Avatar
Hi All,
I Misplaced or inadvertently sold was going to use for the whole-house audio, and then use my Yamaha RX-V663, but I have that hooked up to my whole house audio right now (overkill, I paid $350 for it in 2007 for my first projector setup, but it had RCA to hdmi conversion which I needed at the time), but I don't feel like unhooking it all and would also like a receiver with hdmi 1.4 for 3D (just in case) and maybe network functions (iPhone app and Pandora is cool). Also want to keep the spend down, otherwise I'm tempted to buy more than I need.
So, after a few hours research, my choices are:
1. $150 refurb or $169 new YAMAHA RX-V371 3D 5.1-Channel AV Receiver http://*******/UxoQDl
2. $199 ONKYO TX-NR414 5.1-Channel 3-D Ready Network A/V Receiver http://*******/10GF0Oj - sounds like there's been a lot of issues with it though, but it has an iPhone app.
3. $150 Sony STRDH520 7.1 Channel 3D AV Receiver http://www.amazon.com/gp/aw/d/B004NHCGJO
4. $200 Pioneer 550-Watt 3D 5.1 Home Theater Receiver with AirPlay® Wireless Streaming (Model: VSX822) (HH Gregg with "freeship" code)
5. Other?
Thoughts, Recommendations or other suggestions?
b8b is offline
post #2 of 14 Old 11-23-2012, 09:21 AM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 757
If networking and airplay are most important features then get the Pioneer.
Afro GT
afrogt is offline
post #3 of 14 Old 11-23-2012, 10:00 AM - Thread Starter
b8b
b8b's Avatar
Thank you, Afrogt.
Ignoring network capability, what's the best option?
b8b is offline
post #4 of 14 Old 11-23-2012, 01:21 PM
afrogt's Avatar
Liked: 757
I'm not a Sony fan at all and the Onkyo receivers seem to be problematic. so either the Yamaha or Pioneer.
Actually the Yamaha 371 doesn't have any room calibration software but the Pioneer does, so I'd get the Pioneer.
I would also seriously consider the Denon AVR 1612
http://www.accessories4less.com/make-a-store/item/DENAVR1612/DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver/1.html
b8b likes this.
Afro GT
afrogt is offline
post #5 of 14 Old 11-23-2012, 01:41 PM
adg1034's Avatar
Would you also recommend the 1612 over, say, the Pioneer VSX-42? I'm in roughly the same budgetary situation as the OP. With tax, the Pioneer is $270, and the Denon is roughly $200 shipped...
adg1034 is offline
post #6 of 14 Old 11-23-2012, 02:20 PM
busbeepbeep's Avatar
You can get the Yamaha 471 for $200 at Newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16882115314
b8b likes this.
busbeepbeep is offline
post #7 of 14 Old 11-23-2012, 02:55 PM - Thread Starter
b8b
b8b's Avatar
Thank you Busbeepbeep. I should have added that I would like to have component->HDMI for Wii and such because I only have one 30' HDMI chord running through my walls/attic to an Epson 3020 projector. Does that kill my <$200 options?
b8b is offline
post #8 of 14 Old 11-23-2012, 05:23 PM
Yeah, I think so. The Pioneer 1022-K will do it. It's $250 at Newegg and Amazon.
post #9 of 14 Old 11-25-2012, 10:35 AM - Thread Starter
b8b
b8b's Avatar
I thought about the Pioneer VSX-1022-K, but reading the reviews at Newegg, it's sounds like a disproportionally large amount of folks had trouble with the HDMI switching and video quality, so I am a little concerned to pull the trigger on that.
If I upped the budget to $250, is there something else network-ready that you might recommend?
b8b is offline
post #10 of 14 Old 11-25-2012, 10:46 AM
afrogt's Avatar
Liked: 757
If you need analog to HDMI video conversion for your Wii none of the receivers in your original post will give you that.
Afro GT
afrogt is offline
post #11 of 14 Old 11-25-2012, 10:54 AM - Thread Starter
b8b
b8b's Avatar
Good point, only the Pioneer 1022-K will do that. I suppose I could buy some component to HDMI conversion or even Monoprice's Wii->HDMI for $30, but I'd rather invest that in the receiver. I wish I had gotten in on the Yamaha RX-V671 deal for $300, that probably would have been worth the stretch.
b8b is offline
post #12 of 14 Old 11-26-2012, 05:26 PM - Thread Starter
b8b
b8b's Avatar
I just pulled the trigger on the Pioneer for $180. I hope it's a decent unit and will not cause problems like I've read here.
b8b is offline
post #13 of 14 Old 11-30-2012, 04:32 PM
tavuslokus's Avatar
Very nice find...
I was about to buy the Denon mentioned above when I saw this thread.
OP did you get the system yet? Any issues to worry about?
I see from the linked website the price just went up to 199.99 FREE S/H. Just $10 more than the Denon.
Is this Pioneer being a 2012 with network features a better option than the 1612?
tavuslokus is offline
post #14 of 14 Old 12-01-2012, 10:08 AM - Thread Starter
b8b
b8b's Avatar
I ended up ordering the Pioneer since it was network capable, but I might return it and buy the Onkyo TX-NR515 for $220 as it seems you can get according to this Onky refurb deal thread.
b8b is offline
