Denon AVR 1613 & Yamaha RX-V471 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-24-2012, 02:13 PM - Thread Starter
dannyg40's Avatar
I currently have the older Yamaha Model RX-V471 and I'm wondering if it's worth upgrading to the Denon AVR1613 everyone has on sale this weekend. I like the Yamaha, but the issue I have is the Bass & Treble. I have a sub, but even at +6 the treble seems kinda "weak" for some reason. Anyway, how is the Denon as far as sound quality compared to the Yamaha ? I just can't seem to get the right sound with my Yamaha using the YPAO and even manually setting the "distance & levels". The 471 I have is basically the same amp specs as the newer 473. How is the sound on the Denon ?
dannyg40 is offline
post #2 of 13 Old 11-24-2012, 06:33 PM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 756
Maybe the problem is your speakers? What are they anyway?
buy the Denon locally and try it at home. Then you get 30 days to return if it doesn't meet your needs.
Perhaps Audyssey MultEQ will do a better job than Yamaha's YPAO.
Afro GT
afrogt is online now
post #3 of 13 Old 11-24-2012, 07:40 PM - Thread Starter
dannyg40's Avatar
Just got Polk Audio Monitor 50 series 2's. The speakers sound great, it's getting the distance and level right. What I'm really confused about is the receiver should decode all inputs the same I thought. Some TV stations sound to "boomy", some sound louder than others, and some sound clearer than others. What has me really confused is I don't change any settings on the receiver and I put a channel on the TV, it will say audio "digital 384kbs. 48hz" and when I hit the decode button it will say "straight", I change the TV to another channel, look at the decode, and it might say "pro logic". Has me confused. I know TV channels all broadcast different, I just thought the receiver would eliminate all the variances since it is a sound processor. My nephew has a Pioneer 822 I think, and we both have the same cable provider, and all his channels, songs, mp3's, all play constant with the same sound level and clarity. I might go to BB and check out the Denon and see if there is a difference.
dannyg40 is offline
post #4 of 13 Old 11-24-2012, 08:09 PM
afrogt's Avatar
Liked: 756
some channels are broadcasting in Dolby digital 5.1, Some in Dolby Digital 2.0, some in stereo. you really have no control over that.
Afro GT
post #5 of 13 Old 11-24-2012, 08:49 PM - Thread Starter
dannyg40's Avatar
Question. On my cable box I can change the setting to either "stereo" or "dolby sigital" for audio output. What should I have it set to since Its going through the HDMI ? Does it matter if you send a stereo or dolby digital signal to the receiver or will it decode it either way ?
dannyg40 is offline
post #6 of 13 Old 11-24-2012, 11:09 PM
afrogt's Avatar
Liked: 756
set the cable box to output Dolby Digital...
It matters a lot, you can't send a Dolby Digital signal if the cable box is set ot output stereo.
dannyg40 likes this.
Afro GT
post #7 of 13 Old 11-25-2012, 06:32 AM
Quoted: 73 Post(s)
Liked: 112
Go with the Denon as Audyssey MultEQ will EQ your sub which will help.
rnatalli is offline
post #8 of 13 Old 11-25-2012, 07:53 AM - Thread Starter
dannyg40's Avatar
Been going back and forth trying to decide "should I or shouldn't I". As for now I actually have just a 3.1 set up since my living arrangements are not right for 5.1. Always things I need around the house but I' going to get it for the $269 at BB and check it out today. Might as well give it a shot, who knows, might be better than my Yamaha. I'm mainly looking for a little better sound quality. Don't get me wrong, the Yamaha sounds good, I'm just looking for a little more "crispness" from the sound. Even using the Yamaha's 7 band EQ, I just can't get it dialed in right. I will get the Denon, hook it up, and post back tonight my thoughts.
dannyg40 is offline
post #9 of 13 Old 11-25-2012, 09:50 AM
afrogt's Avatar
Liked: 756
Good move, that's the best way to answer your question anyway.
Afro GT
post #10 of 13 Old 11-25-2012, 11:58 AM - Thread Starter
dannyg40's Avatar
Ok, got the Denon and messed with it for about 2 hours. Long story short, it's going back for sure.
I ran the setup in all 6 positions like it said, and I got exactly the same results with my Yamaha YPAO setup. Left 10.8ft, Right 9.8 ft., sub 18.6 ft. Left Speaker -1.0 db......
Things I don't like,
The Yamaha's menu is a lot easier to get through and change settings.
My Yamaha at -25 on the volume is -10 on the Denon.
The Yamaha is way louder than the Denon at any volume level
I noticed no major improvement in sound quality from the Yamaha
2 things I noticed right away that turned me off and I read about them on some reviews and they were not lying !
1. The remote sometimes don't act right. Mainly I would be in a menu to change something, and the "back" button on the remote wouldn't respond. I had to exit, go back in the menu, and do it again. 1 out of maybe 3 times the "back": button just wouldn't respond for some reason.
2. I messed with the Bass/Treble settings, and the manual EQ settings to customize the sound. I exit the menu, go back into the menu and everything is reset back to "0". I thought it was me, but I did it a few times, went back and check, a few times it was ok. I turned off the receiver, went to a different mode, back to the menu, then I would look, and it was all back at "0".
I had a funny feeling cause the big guy at BB was working today and he knows his stuff pretty good. I asked him what's their best selling receivers and he said Yamaha hands down. I guess I'm just used to the Yamaha and it's "quick" menu. Also, the Denon I think only lets you switch 1 HDMI output to be a "pass through" for when you turn the receiver off and want to watch TV. I believe thats what I read. The Yamaha lets all HDMI's pass through.
Thanks Guys, for now it's my Yamaha. If I decide on an upgrade, it will be another Yamaha down the road.
dannyg40 is offline
post #11 of 13 Old 11-25-2012, 05:01 PM
jdsmoothie's Avatar
Quoted: 12135 Post(s)
Liked: 5526
The Denon uses Dyn EQ which sets reference level volume to 0db whereas the Yamaha does not so you cannot compare their volume levels.
2. If you're messing with the Manual EQ settings, doing so disables Audyssey. if you're not interested in Audyssey, you're right to return the 1613.
jdsmoothie is online now
post #12 of 13 Old 11-25-2012, 06:54 PM - Thread Starter
dannyg40's Avatar
Well when I run my Yamaha YPAO and the Denon Audyssey, and the result is speaker level "0" all I know is the Yamaha is much louder than the Denon at the same setting of "0". -25 on my Yamaha is the same volume level as -10 on the Denon. When I run the Yamaha YPAO it gives me the exact same distance/level settings as the Denon Audyssey. Always after I run the YPAO, I change the default "YPAO Flat" setting to "equalizer through" or "equalizer setting" so I can customize the sound. Once I set my Bass/Treble on the Yamaha, it never changes on it's own. Running the setup sets timing and levels, and has nothing to do with being able to customize the "tone" of the sound. Once I set my Yamaha to the Bass/Treble I like, it never changes. All I know is the Denon keeps going back to Bass "0", Treble "0". It's not a matter of If I like Audyssey, the point is why have Bass/Treble and a 9 band custom EQ feature on a receiver if you can't use it because it always defaults back to the Audyssey setting ? Distance/Level & Tone should have nothing to do with each other
dannyg40 is offline
post #13 of 13 Old 11-26-2012, 04:14 AM
jdsmoothie's Avatar
Liked: 5526
The volume scales on both AVRs are different and cannot be compared directly. I would certainly hope the "distance/level" settings come out the same on both units as that's a fairly easy function to accomplish, but much different from the actual EQ process of YPAO vs. Audyssey. On the Denon, in order to use the Tone Control (bass/treble) settings, you must first disengage Audyssey Dyn EQ. Once you engage Dyn EQ again (which is recommended to be left on for all sources), you disengage the previous Tone Control settings. If you prefer the tweaking capability of the Yamaha, then there's your answer.
Denon Avr 1613 Receiver , Yamaha Rx V471bl 5 1 Channel Av Receiver
