MCACC problems with sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 11-25-2012, 11:33 AM - Thread Starter
Vallhall's Avatar
Hey
I using a small kef 3005 5.1 setup now, and then i run mcacc, the sub was messed. It sounds to muddle, distorton and sounds very boomy.
I also have a set of floorstanders, and then i run mcacc with them and no sub it sounds perfect, so it seems to me that the mcacc dont calbrate the subs.
I have also owned a receiver with audyssy xt and didnt have any problems with the subs after the calibration.
That said it was in a different room
Any help plz?
Thanks in advance
Vallhall is offline
post #2 of 15 Old 11-25-2012, 11:37 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
MCACC doesn't eq the subwoofer, that's the problem. You need a receiver with Audyssey MultEQ or higher.
Afro GT
afrogt is offline
post #3 of 15 Old 11-25-2012, 03:49 PM - Thread Starter
Vallhall's Avatar
Thanks for replying
Seems your right, but i realy expect better from an flagship receiver
Vallhall is offline
post #4 of 15 Old 11-25-2012, 03:51 PM
ccotenj's Avatar
Liked: 101
why? mcacc has been that way since day 1...
- chris
ccotenj is offline
post #5 of 15 Old 11-25-2012, 04:55 PM - Thread Starter
Vallhall's Avatar
Well maybe its time they develop their system. MCACC is very good if you DONT have sub, atleast in my room
Vallhall is offline
post #6 of 15 Old 11-25-2012, 05:09 PM
afrogt's Avatar
Liked: 755
they have a new advanced MCACC on the higher end Pioneer receivers like the SC-68. Maybe that version will eq the subwoofer. haven't seen it or tried it myself though.
http://www.hometheater.com/content/pioneer-elite-sc-68-av-receiver
Afro GT
afrogt is offline
post #7 of 15 Old 11-25-2012, 05:11 PM
ccotenj's Avatar
Liked: 101
nope... still not there...
it's one of the big reasons why i'm no longer a pioneer fanboy and am now a denon ho'... smile.gif
- chris
ccotenj is offline
post #8 of 15 Old 11-25-2012, 05:12 PM
DonH50's Avatar
Quoted: 1795 Post(s)
Liked: 1329
Nope, still no sub EQ on any Pio model current or previous.
Sounds like the main problem is the room, but a sub EQ unit lile a miniDSP or Antimode might help. I would try doing the sub crawl (do a search) first and move the sub around to see if you can find a better spot.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #9 of 15 Old 11-25-2012, 05:35 PM - Thread Starter
Vallhall's Avatar
I have the last years Pioneer LX 85, think its SC 57 in US, and the mcacc in 57 and 68 is just the same as i understand
Vallhall is offline
post #10 of 15 Old 11-25-2012, 05:39 PM - Thread Starter
Vallhall's Avatar
Thanks for your advice
The room is very small and akward/difficoult, and my cable to the sub is very short so i dont have much options to change the position.
Thinking much on Audyssey multi xt32 WITH EQ sub:rolleyes:
Vallhall is offline
post #11 of 15 Old 11-25-2012, 05:49 PM
ccotenj's Avatar
Liked: 101
well, you can always get a longer cable... wink.gif they are dirt cheap...
the antimode don mentioned is a good "plug and play" device... i used one both with mcacc and with audyssey xt units... i found that even with xt, the antimode helped...
that's a good thought process to have... wink.gif no need for antimode there...
- chris
ccotenj is offline
post #12 of 15 Old 11-25-2012, 06:05 PM - Thread Starter
Vallhall's Avatar
Yes cable is cheap:), but maybe my problem is the exuse i need to buy a receiver with XT32. I mean if i go for Onkyo i have flexible crossover and the new crossover network with biamping +++biggrin.gif
Vallhall is offline
post #13 of 15 Old 11-25-2012, 06:09 PM
ccotenj's Avatar
Liked: 101
won't do you any good unless you also remove the passive xover from your speakers... wink.gif
but i won't talk you out of a xt32 avr... imo, xt32 is the real killer app these days... i know i'm very pleased with the results....
of course, then we'll drag you into getting a pro kit, measuring tools, and spending hours tweaking and fiddling... tongue.gif
- chris
ccotenj is offline
post #14 of 15 Old 11-25-2012, 06:30 PM - Thread Starter
Vallhall's Avatar
And how do you remove the passive xover from the speakers then?eek.gif.
I hope you didnt think i would biamp the little kef eggs:p
Vallhall is offline
post #15 of 15 Old 11-25-2012, 07:08 PM - Thread Starter
Vallhall's Avatar
Vallhall is offline
