Yamaha RX-A2020- recomended standfloor speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-26-2012, 07:59 AM - Thread Starter
realmode's Avatar
Hello,
I just bought the new RX-A2020 receiver from Yamaha. I don`t have any speakers yet and I don't realy know what speakers brand is "reliable" for both stereo and cinema experience.
The room size is 1615 inch x 1600 inch.
Thanks in advance for any advice.
realmode is offline
post #2 of 4 Old 11-26-2012, 01:08 PM
Kini62's Avatar
Quoted: 1723 Post(s)
Liked: 1539
Originally Posted by realmode View Post
Hello,
I'm sure you misquoted the dimensions.
Second you gave no budget which leaves everything from $100/pair to over $100,000/pair.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #3 of 4 Old 11-26-2012, 11:31 PM - Thread Starter
realmode's Avatar
OK, in feet is 13.44 x 12.95 and 174.04 square feet.
Budget is maximum 3000 USD.
What I need:
- 2 standfloor speakers
- 2 read bookshelf speakers
- 1 center speeker
- 1 subwoofer, I guess no more than 200W.
realmode is offline
post #4 of 4 Old 02-22-2013, 09:28 AM
SVERZI's Avatar
Hi .. Just bough last month the RX-A 2020, and im using for speakers the BW, MT 60 D.
Sounds great on the Yamaha.. bestbuy has the M1's just go there and listen to speakers that will give you the sound you re looking for.
Sound is like the rest.. it can be very personnal.
good luck!
SVERZI is offline
Yamaha Rx A2020 9 2 Channel Network Aventage Av Receiver
