XPA-5 overkill for my system? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-26-2012, 06:23 PM - Thread Starter
Schuyler Bain's Avatar
Quoted: 33 Post(s)
At high volumes my center and fronts breakup. I am running 7.2 and watch movies 70%, and music 30% of the time. Also looking at the XPA-100 (250w x 1) just for the center.
I definitely need more power to my center, but do you think the XPA-3 or XPA-5 is total over kill for my setup? I usually like to buy for the future - may have completely different speakers in 2-3 years...
Emotiva is also running a sale now.
Onkyo TX-NR5008
C - DefTech CS-8080HD
L/R and surrounds - Deftech ProMonitor 1000's
Schuyler Bain is offline
post #2 of 12 Old 11-26-2012, 09:40 PM
wes182's Avatar
Quoted: 51 Post(s)
Liked: 26
May be your speakers not able to handle the high volume well. That is a pretty beefy receiver. Seems to me you have plenty of power and may need speakers to match.
wes182 is offline
post #3 of 12 Old 11-26-2012, 09:55 PM
Splicer010's Avatar
Liked: 39
A center with a built-in powered sub?! rolleyes.gif Get a passive center and all shall be right with the world. cool.gif
Splicer010 is offline
post #4 of 12 Old 11-26-2012, 10:44 PM
Snowmanick's Avatar
Quoted: 247 Post(s)
Liked: 349
I also run a DefTech set up (STS mains and CS-8060HD for center, Gem XL surrounds). Considering your speakers and your receiver, I don't think the amp would add much. The center is pretty efficient, and the most demanding frequencies (bass) are handled by the internal amp.
If you are not happy with the output, I'd look at either A) adjusting the setup (different X0over, bass management settings, checking the Audyssey calibration), or B) more powerful mains (the SM65's are not too much larger, and are much more capable, while still blending with your center). Option A is free and option B is in the same ball park as the amp, either/both will provide you a more significant upgrade than adding an outboard amp to your setup.
~Nick
"Every loaf of bread is a tragic tale of grains that could've become beer.......but didn't...."
"If it works the first time, it's not high end." ~ Harry Pearson
Snowmanick is offline
post #5 of 12 Old 11-27-2012, 11:45 AM - Thread Starter
Quoted: 33 Post(s)
Audyssey has my center Xover at 40hz and fronts at 80hz, but a recalibration never hurts. I really only hear the distortion (highs) when I come up close to the speakers at high volumes.
I really like the idea of adding SM65's as my mains and converting from 7.2 to 9.2. The last time I was pricing DefTech mains, I don't remember seeing those - must be new.
I thought I could maximize my current setup and bring my speakers to full potential by adding an amp, but you may be right in mentioning that more powerful fronts and 9.2 would be money better spent.
Also read that sometimes you can find the SM65's at up to 40% off list price. I don't need to add anything, but can't think of anything else I want for Christmas. wink.gif
post #6 of 12 Old 11-28-2012, 08:31 PM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
Raise the center to 80Hz to match the FL/FR speakers.
jdsmoothie is offline
post #7 of 12 Old 11-28-2012, 11:20 PM
Snowmanick's Avatar
Quoted: 247 Post(s)
Liked: 349
Expanding on that idea, if you are running out of juice, try crossing over at a higher frequency. Depending on your sub (FR,quality, and location), crossing over at 100hz or 120hz will take a sizable amount of stress off your mains. This could allow for your system to be played louder and clearer, with more bass, and again, for free.
Audyssey tests for the -3db point, but the receiver sets the crossover/speaker size and crossover points, even if these are not optimal. Chris K. of Audyssey makes a frequent point of telling people to ignore the small/large settings, and to try a crossover around 80hz. At the worst, it was only a few minutes of time (you won't need to rerun Audyssey, just change the settings in your AVR)
Even with my STS towers, I tend to crossover at 100hz to my subs.
~Nick
post #8 of 12 Old 11-29-2012, 03:23 AM
Theresa's Avatar
Liked: 51
I don't think that either the XPA-5 or XPA-3 would be overkill. I have an XPA-3 that I bought because my "receiver" was clipping and it solved the problem. My system has been totally redone since then and I use three Emo amps along with a different "pre-pro."
Theresa is offline
post #9 of 12 Old 11-29-2012, 06:12 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Onkyo TX-NR5008
You are talking about these?
one 5.25-inch cast basket bass/midrange drivers coupled to one 5.25-inch pressure-driven planar low-frequency radiators
one 1-inch pure aluminum dome tweeter
And the subwoofer is?
If there really isn't a subwoofer adding a good subwoofer costing you the price of an Emotiva XPA-5 will give you the following significant advantages:
(1) Superior bass because it doesn't take a lot to overpower what you got now (not a heck of a lot!) in the lowest octave
(2) Superior midbass because offloading the low bass from your fronts will make your fronts sound that much cleaner.
(3) Much higher SPL before AVR clipping because you're wasting a lot of power trying to make your fronts do what God never intended them to do, which is make low bass.
Ever hear the one about what happens if you try to make a pig fly?
The pig never flies but you pi$$ it off! ;-)
That is what happens if you try to get good subwoofer bass out of a 5.25 inch driver, or even twelve of them.
arnyk is offline
post #10 of 12 Old 11-29-2012, 06:20 AM
Theresa's Avatar
Liked: 51
Are those his speakers? Sorry I didn't research what the speakers were. Your right, apart from Exodus Acoustics Anarchy drivers, 5.25" drivers are unsuitable for anything lower than about 100Hz. If he's getting distortion its pretty certain its the speakers and not the amplification.
Theresa is offline
post #11 of 12 Old 11-29-2012, 07:14 AM - Thread Starter
Quoted: 33 Post(s)
one 5.25-inch cast basket bass/midrange drivers coupled to one 5.25-inch pressure-driven planar low-frequency radiators one 1-inch pure aluminum dome tweeter
Yes, that's the speaker.
For bass I'm running 2 HSU VTF-3 MK3's and an MBM-12, so I'm not trying to get bass out of my satellites (make a pig fly). Just leaving the crossover where Audyssey MultEQ XT32 set it.
I'll try the mains at 100 and 120hz as well as bumping up the center to 60 or 80hz. Hopefully that will clean it up a bit. All recommendations are appreciated!
post #12 of 12 Old 11-29-2012, 11:49 AM - Thread Starter
Quoted: 33 Post(s)
CORRECTION: My center was set at 60hz, mains at 100hz and surrounds at 80hz. I just moved the center to 80, and surrounds to 100hz. Will test for a few days.......move up to 100 and 120hz if necessary.
Audyssey has definitely set my Xovers at different points on the same speakers for no apparent reason. Slightly different on almost every run.
Emotiva Xpa 5 5 Channel Power Amplifier
