Important question about what I should buy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-27-2012, 02:12 PM - Thread Starter
Jjay92597's Avatar
Hey I bought the polk monitor 40 speakers while they were on sale. I was looking to buy an amp or receiver etc. and I can't decide whats best to get receiver, integrated amp,pre amp, etc. All i want to do is listen to my music as best I can. My music source is a computer but mostly an iPod I know I know not the best but that's what I got. So basically what system should i buy for good music. This is probably a dumb question but I can't decide whats best.
Jjay92597 is offline
post #2 of 7 Old 11-27-2012, 02:16 PM
afrogt's Avatar
Quoted: 1069 Post(s)
Liked: 775
What's your budget?
Afro GT
afrogt is offline
post #3 of 7 Old 11-27-2012, 02:33 PM - Thread Starter
Jjay92597's Avatar
My budget is under $500, I may be able to stretch it but that's my basically it
post #4 of 7 Old 11-27-2012, 07:10 PM
jdsmoothie's Avatar
Quoted: 12351 Post(s)
Liked: 5642
Do you expect to expand beyond the 2 speakers? What about buying a sub? If yes to both, try getting a Denon 1612 or 1712 on clearance at a Best Buy store (~ $200) and put the savings into a sub (~$300).
jdsmoothie is offline
post #5 of 7 Old 11-27-2012, 07:46 PM - Thread Starter
Jjay92597's Avatar
Im definitely getting a sub probably the bic f12 but I might not expand but is the 1713 better besides the networking I mean sound wise
post #6 of 7 Old 11-27-2012, 09:13 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Your best solution from the standpoint of having a clean install, best sound quality, and maximum expandability is a regular 5.1 AVR. A basic model from one of the mainstream vendors such as Yamaha, Onkyo, Pioneer, etc, will perform brilliantly.
arnyk is offline
post #7 of 7 Old 11-28-2012, 12:07 AM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Any $200 receiver. By the time you are at the quality level of iPOD and MP3 files, the amp can't do much damage.
lespurgeon is offline
