Yamaha RX-V671 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-27-2012, 05:28 PM - Thread Starter
lamplighter's Avatar
How would I connect wi fi to this. I have a desktop pc connected to a cable modem. Would I need to add at wireless router..then what would I need to connect to the receiver to pickup the signal?
lamplighter is offline
post #2 of 5 Old 11-27-2012, 09:00 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
How far is your receiver from the PC and cable modem? Does the cable modem have any extra network ports?
If you buy a wireless router you can also directly connect a network cable to the receiver since the router has 4 ethernet ports. Of if you need wireless you have to buy some type of wireless adapter to connect to the Yamaha.
Afro GT
afrogt is offline
post #3 of 5 Old 11-27-2012, 09:08 PM
bishop_161's Avatar
+1
You can get a wireless bridge for pretty cheap.
http://www.amazon.com/TRENDnet-Wireless-4-Port-Bridge-TEW-640MB/dp/B004FMI3DA/ref=sr_1_1?s=electronics&ie=UTF8&qid=1354075752&sr=1-1&keywords=trendnet+wireless+bridge
I have this exact model. Works pretty good. Check out the pictures of the item. It will give you a diagram of how to hook everything up.
You will also need a router-something like this: http://www.amazon.com/gp/product/B004T9RR6I/ref=amb_link_361521402_4?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=hero-quick-promo&pf_rd_r=0RDBQDED22H4BN6WTASZ&pf_rd_t=201&pf_rd_p=1413800122&pf_rd_i=B0044YU60M
if you want to stay with the official yamaha gear, you'll need Yamaha YWA-10 Wireless Network Adapter + a wireless router.
http://www.amazon.com/Yamaha-YWA-10BL-Wireless-Network-Adapter/dp/B0085ZIN4W/ref=sr_1_2?s=electronics&ie=UTF8&qid=1354075628&sr=1-2&keywords=Yamaha+RX-V671+wi-fi+adapter
bishop_161 is offline
post #4 of 5 Old 11-28-2012, 06:17 AM - Thread Starter
Well I dont have wireless..but I think I can use something called Powerline..but I just checked and on my cable moden I dont have any outlets except the one I have gong to my computer. Is there something I can install to give me another ethernet outlet??
post #5 of 5 Old 11-28-2012, 06:18 AM - Thread Starter
To use a wireless bridge..I need wireless in the first place..correct?
Yamaha Rx V671 Receiver
