HK AVR 1600 - 3600, 1560 or 1700? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-27-2012, 06:09 PM - Thread Starter
miscrms's Avatar
I'm wondering if anyone has any advice on a new receiver purchase.
I had an HK AVR 7000 which I absolutely loved for many years, but it died about two years back. Since then I've been using my old HK 3500 stereo receiver, which is great for music but lousy for home theater. I've spent some time working on the 7000 to try and resurrect it, soldering new caps etc but no joy so far. Its also becoming clear to me that even if I got it back its pretty outdated now, no HDMI etc.
My budget is pretty restricted these days, now that we have kids and all, so I'm stuck in the Dom Perignon taste, MD 20/20 budget situation wink.gif Probably need to keep it in the $200-300 range. I'm not 100% set on HK, but I do really love their sound. Sound quality for music is definitely my #1 priority, with competent home theater next.
I've been looking at the new low end HKs, such as the 1700 and 1565 which seem to be doable in the price range with current sales. I like some of the new features, including the iphone app control, OSD, Auto EQ etc, but am pretty concerned about the quality of the new HKs. The weight reduction and more "traditional" peak power ratings don't seem like good signs for maintaining the traditional HK sound.
The xx50 class are probably out of range on budget, but I am still seeing a few AVR 1600/2600/3600s around either as local display models or from HK refurbished that would fit the budget. Seems like some folks think the xx00 series was perhaps better (once the HDMI issues were more or less sorted out) than the xx50s.
Our setup is pretty simple (compared to what it used to be) these days, here's what we're working with:
HTPC: Mac Mini HDMI out to TV, DVDs & BRs on NAS via Plex plus streaming video and itunes music / video
Games & Netflix: Wii component 480p
TV: Panasonic G series 54" 1080p Plasma
Fronts: JBL Studio S38 "bookshelf" 8" 3 way 175W 45Hz - 20kHz
Center: JBL Studio S-Center 5.5" 3-way 150W 80Hz - 20kHz
Rear: random cheap infinity, don't remember what they are but nothing special
Control: retired iphone with Hippo Remote
No big upgrade plans on the horizon, would like to add a sub at some point but the S38s hardly need it most of the time. May add an Xboxy sort of thing as the kids get older. Will probably stick with 5.1 (may not have a choice with the Mini), if I had 7.1 I might be more interested in using the extra channels for an upstairs zone 2. As it is the HK3500 will probably move upstairs for music, so that's maybe not a big deal.
Setup is in finished, carpeted basement, probably 15x30' with back half used for tv area.
Any thoughts would be much appreciated! Any reason to consider the new bottom end 1700/1565 over the 1600/2600/3600? Probably leaning toward the 2600 right now. Would like the 3600, but probably can't quite swing it.
Rob Smith,
Phoenix, AZ
miscrms is offline
post #2 of 5 Old 11-27-2012, 10:22 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3099
The 2600 would be your best bet regarding build quality as well as sound quality. The newer HKs are a bit disappointing. The room correction on the 2600 (Ez Set) leaves something to be desired but is better than no EQ I suppose.
If you are up to considering a receiver not made by HK the Denon 1612 is worth a look as well as the Marantz 1602. Both are on close-out right now. You can get a refurb 1612 for $189 at accessories4less. These receivers have Audyssey MultEQ room correction software. The 1602 has networking and a USB port if these features interest you.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 5 Old 11-27-2012, 11:26 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
I saw the 3600 for $399 on black friday - I don't remember where. Deals are available.
lespurgeon is offline
post #4 of 5 Old 11-28-2012, 02:52 PM
Kini62's Avatar
Quoted: 1421 Post(s)
Liked: 1308
I've had the 1600 for a couple of years now and it's been rock solid. Doesn't get hot, seemingly has a lot more power than the specs indicate and sounds good.
Currently I need more power for music (small inefficient speakers) but not for movies. Passes analog through HDMI (non HDMI Xbox) decodes all the latest HD sound streams.
I would definitely look toward the 2600 or 3600 before any of the new low end HKs.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #5 of 5 Old 12-12-2012, 10:24 PM - Thread Starter
miscrms's Avatar
Thanks everyone for the feedback. Got a small, but unexpected year end bonus and decided to pull the trigger on a refurbed 3600 from Harmon on ebay for $399. Will post my impressions over in the main thread once I get it set up and have a chance to play with it a bit!
miscrms is offline
