7.1 or 5.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 11-28-2012, 10:14 AM - Thread Starter
mijotter's Avatar
Liked: 59
Greetings. I'm not sure if i'm going to settle with 5.1 or 7.1 yet as i'm still building my HT. However I was wondering if a 7.1 receiver will be ok for a 5.1 setup, will it affect the sound, frequency, anything. Just in case I find out i want to upgrade to 7.1 later down the road.
mijotter is offline
post #2 of 16 Old 11-28-2012, 11:31 AM
sdurani's Avatar
Quoted: 4507 Post(s)
Liked: 2911
If your seating area is at least a few feet away from the back wall, then consider doing a 7.1 layout, since you'll be able to get meaningful separation between your side speakers and rear speakers. If your seating is at or near the back wall, then stick with a 5.1 layout, since there won't be enough space behind you for the rear speakers.
Whether you buy a 7.1 or 9.1 receiver, you can connect as many speakers as you want, even if you decide to start off with just 2 speakers initially. Also, modern receivers can scale the number of channels in the source material to the number of speakers in your set-up. A 5.1-channel soundtrack can be downmixed for 2 speakers or upmixed for 7.1 speakers, without throwing away or adding anything to the soundtrack.
So buy the receiver that has the features you want. Don't worry about the number of speakers you'll be using.
Sanjay
sdurani is offline
post #3 of 16 Old 11-28-2012, 11:35 AM - Thread Starter
mijotter's Avatar
Liked: 59
Oh wow i didn't know that. I'm still in the construction phase but it doesn't hurt to plan ahead to keep the ball rolling. So what IS the difference in a 7.1 and 5.1 receiver if not how man speakers it can handle properly?
mijotter is offline
post #4 of 16 Old 11-28-2012, 11:41 AM
BllDo's Avatar
Quoted: 575 Post(s)
Liked: 373
If you are still in construction, you may as well wire for 9.1 or even 11.1. A couple bucks extra for some speaker wire will go a long way for future proofing. Off topic, but do also consider extra Cat6 runs, you can never have enough.
BllDo is offline
post #5 of 16 Old 11-28-2012, 12:06 PM
sdurani's Avatar
Liked: 2911
That IS the main difference. But since 5.1 receivers are typically at the lower end of a company's product line and 7.1/9.1 receivers are at the top end of the product line, the latter means that you get things like: better room correction, additional surround processing choices, more connectivity, greater amplifier power, etc. So it's worth getting those features, even if you never plan on going beyond a 5.1-speaker layout.
I'll also echo what BllDo posted: since you're in the construction phase, this is the best time to run wire for additional speakers. To that end, a couple of quick questions about your set-up. What are your room dimensions (LxW)? And where is your main listening position going to be (i.e., how far from the back wall)?
Sanjay
sdurani is offline
post #6 of 16 Old 11-29-2012, 12:25 PM - Thread Starter
mijotter's Avatar
Liked: 59
Could anyone give me a list of good medium budget receivers. Looking to spend under $400 at max. Also, What do you recommend for speaker wire. I have a high performance Inifinity system 5.1 as of right now.
mijotter is offline
post #7 of 16 Old 11-29-2012, 01:23 PM
BllDo's Avatar
Quoted: 575 Post(s)
Liked: 373
Monoprice is a great source for cables (and everything else).
For receivers, if you don't mind looking at factory refurbished models, check out Accessories for Less. You can get a Denon 2113 for $399. http://www.accessories4less.com/make-a-store/item/DENAVR2113CI/DENON-AVR-2113CI-7.1ch-Networking-Receiver-w/AirPlay-3D-Ready/1.html
Otherwise a factory new 1713 would fit the bill nicely.
BllDo is offline
post #8 of 16 Old 12-01-2012, 06:25 AM
AVTrauma's Avatar
If you look at the line up of AVR's from the major manufacturers, they have only 1 model that is a 5.1 AVR, with many that are 7.1 with increasing bells & whistles for increasing costs. Your best bet would be to go for the 7.1 models that may have options you could utilize now, or in the near future (prior to your next AVR upgrade). List the feeatures you would need now, then research what is available. Also don't forget to call some of the authorized sellers (Electronics Expo, J&R, AVSF store, et al) to get the current price they are selling the unit for... they typicaly sell for less than the price listed on their web page (saving you money, which may give you an opportunity get a better AVR for the same price you have decided you could afford). Best wishes!
AVTrauma is offline
post #9 of 16 Old 04-12-2013, 06:50 PM - Thread Starter
mijotter's Avatar
Liked: 59
Sorry it took so long to respond. Room is 10.8' wide x 16.6' long. Main listening position will be about 6 feet from the back wall.
mijotter is offline
post #10 of 16 Old 04-12-2013, 08:01 PM
sdurani's Avatar
Liked: 2911
That's enough distance from the back wall to give you good rear-vs-side separation in the surround field. Put your side speakers directly to the sides of the listening are (or a few degrees forward) and spread your rear speakers apart on the back wall.
Sanjay
sdurani is offline
post #11 of 16 Old 04-12-2013, 08:29 PM - Thread Starter
mijotter's Avatar
Liked: 59
There will be a row of seating behind the main listening posistion about 3 feet from the back wall. Should the sides be placed at ear level when seating in between the 2 rows?
mijotter is offline
post #12 of 16 Old 04-12-2013, 10:55 PM
sdurani's Avatar
Liked: 2911
You're going to have rows 6 feet AND 3 feet from the back wall? That's not enough space (3 ft between rows) unless people in the back row have no legs.
Consider placing the front row at 3/5ths of room length, around 10 ft from the front wall. That will give you 6.6 feet of space for the back row. Sitting at any of the 1/3rd or 1/5th divisions of room length will help improve frequency response.
Place all 4 surrounds at least a couple of feet above ear level.
Sanjay
sdurani is offline
post #13 of 16 Old 04-12-2013, 10:59 PM - Thread Starter
mijotter's Avatar
Liked: 59
I did all the measuring and marking and it works. Be just like a movie theater. People like me with long legs may have to sit up for people to pass but it's not a big issue. . Thanks for the speaker height. Where would the sides go in relation to the 2 rows? In between the two rows or more at the front row.
mijotter is offline
post #14 of 16 Old 04-15-2013, 08:28 PM - Thread Starter
mijotter's Avatar
Liked: 59
Bump
mijotter is offline
post #15 of 16 Old 04-24-2013, 04:33 PM - Thread Starter
mijotter's Avatar
Liked: 59
Where would the sides go in relation to the 2 rows? In between the two rows or more at the front row?
mijotter is offline
post #16 of 16 Old 04-24-2013, 10:03 PM
Legairre's Avatar
Quoted: 480 Post(s)
Liked: 273
I have two rows of seating in a 7.1 setup and have my side surrounds even with the front rows headrest.
mijotter likes this.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
