AVR compatabilty with satellite receiver...channel change lag? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-28-2012, 12:49 PM - Thread Starter
tunafish24's Avatar
I've read a few posts about Pioneer Elite receivers adding a lag when changing channels on the satellite receiver. Presumably ,it's caused by HDMI negotiation when a channel is changed and new resolution is different. Some people are saying it's upto 5 seconds.
Is this an issue only with Pioneer Elite receivers or do all AVRs behave this way? Is there a way to resolve it on Pioneer AVRs?
tunafish24 is offline
post #2 of 6 Old 11-28-2012, 01:07 PM
tezster's Avatar
Quoted: 411 Post(s)
Liked: 282
I'm not entirely sure if it's specific to the AVR - I think it could be caused by any two HDMI-connected devices performing an HDCP negotiation. I noticed this when I switched my TV to a 55" LCD from my 50" DLP i.e. the display would blank out for about two seconds when switching resolutions; I ended up setting my STB to exclusively output 1080i as a work-around. The lag can definitely be annoying.
tezster is offline
post #3 of 6 Old 11-28-2012, 01:13 PM - Thread Starter
tunafish24's Avatar
does directv hr-34 have the option to fix output to a certain resolution? and how's the upscaling on the satellite receiver? Sorry, I don't have directv yet...will get it next week...but I'd like to place an order for the AVR asap.
Also, in the AVR, did you try setting video to passthrough mode?
post #4 of 6 Old 11-28-2012, 04:48 PM
ccotenj's Avatar
Liked: 101
any time you change resolutions in the source, it breaks the handshake and it must be renegotiated... it has nothing to do with the repeater (avr), whether it is scaling/deinterlacing or not... smile.gif
the only way around this is to set a fixed resolution from the cable box...
- chris
ccotenj is offline
post #5 of 6 Old 11-30-2012, 04:17 PM - Thread Starter
tunafish24's Avatar
so if I fix resolution in cable/satellite box...then there would be NO lag at all?
post #6 of 6 Old 12-01-2012, 05:27 AM
ccotenj's Avatar
Liked: 101
correct... keeping the same resolution from the source will ensure that the handshake is not broken...
- chris
ccotenj is offline
