Denon AVR-786 for Yamaha RX-A1020. Big improvement? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-28-2012, 08:17 PM - Thread Starter
sylvainchar's Avatar
I would like to change my Denon AVR-786 (without HDMI) by a RX-A1020. Is it worth the cost? Do you think this will be a big improvement ?
My front speakers are B&W DM220, the back are dm302 and the center speaker is REEL. Not a very good one. I know my speakers should match but for now i don't want to change my DM220. I might consider buying a center B&W HTM61 or 72.
sylvainchar is offline
post #2 of 3 Old 11-29-2012, 02:22 AM
jdsmoothie's Avatar
Quoted: 14671 Post(s)
Liked: 6992
You're much better served upgrading the center speaker first and then when you've saved up again, take a look at upgrading the AVR.
jdsmoothie is offline
post #3 of 3 Old 11-29-2012, 06:22 AM - Thread Starter
You are probably right even though a receiver is sexier than a speaker...
Thanks for sharing.
Yamaha Rx A1020 7 2 Channel Network Aventage Av Receiver
