Pandora log in problem - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 115 Old 12-07-2012, 05:32 PM
jdsmoothie's Avatar
Quoted: 14564 Post(s)
Liked: 6913
Just a suggestion ... if you want it to happen sooner, you would be better served calling Pioneer rather than regular posts in this thread. wink.gif
jdsmoothie is online now
post #62 of 115 Old 12-08-2012, 05:06 PM - Thread Starter
Flashtime9's Avatar
And I'm still waiting
Flashtime9 is offline
post #63 of 115 Old 12-08-2012, 05:06 PM - Thread Starter
Flashtime9's Avatar
post #64 of 115 Old 12-08-2012, 07:36 PM
mcpackjoe's Avatar
wow, harsh!
mcpackjoe is offline
post #65 of 115 Old 12-08-2012, 09:16 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4780
Saw this thread mentioned in another where a guy with a Pioneer SC57 had an issue with the server error message. Made me at first not want to try my avr to find out but of course curiosity overcame that quickly enuf! So I start listening to Pandora on my Onkyo HTRC370 and it's fine, except in the second song it stops, indicating it's "buffering", yet at 100%, but no music. I wait a while, no change. Now I try to select another music app on the "net" setting,,.. nothing, it's like I don't even have a "net" selection on the avr as even "net" won't show on the panel. I try unplugging the USB dongle, that doesn't seem to make a difference, so unplugged the avr for a bit and then all okay; I used Pandora for a few hours after that and it's okay. Wonder if it's even the same issue, but the timing was ominous. Tried just now before posting and listened to a coupla songs, it's still okay. Why would it disable avrs particularly? I haven't tried Pandora apps on the Samsung tv or bd player I've got, tho.
lovinthehd is offline
post #66 of 115 Old 12-10-2012, 12:24 PM
sweh's Avatar
"UPDATE: For wireless speakers (XW-SMA1-K, XW-SMA3-K, XW-SMA4-K) a firmware update is now available. Please click here to download.
This page will be updated as soon as we have a fix for other products that have been affected. Please check back shortly."
Rgds
Stephen
sweh is offline
post #67 of 115 Old 12-11-2012, 10:31 AM
HDBones's Avatar
Well that link doesn't state new firmwares for receivers, but I checked the SC-67 product page and the Pandora firmware is available for it (came out yesterday, 10th). Downloading right now. Also available for the SC-68. I haven't checked any other products.
GO GET IT!!!!
UPDATE: Was able to login and listen, works great.
HDBones is offline
post #68 of 115 Old 12-11-2012, 10:41 AM
ss9001's Avatar
Quoted: 358 Post(s)
Liked: 423
GO GET IT!!!!
+1
I have installed it this morning & the installation went perfectly.
just don't put the zip file on the flash drive itself or extract the unzipped folder to the flash drive. once you've extracted the bin files to your hard drive, copy them, not the folder, to a blank FAT32/FAT16 flash drive with no other files on it and the receiver will install them just fine.
Steve
ss9001 is offline
post #69 of 115 Old 12-11-2012, 01:05 PM
sweh's Avatar
GO GET IT!!!!
And, indeed, the VSX-1022 page also seems to have a new firmware:
Code:
This firmware update includes the following:
    Adds HTC Connect feature for compatible Android® phones.
    Resolves an issue with connecting to Pandora's server.
Please note that all network settings, including the your Pandora account information, will be reset to the factory default after the update. Write down these settings before the update as they will be needed to set up the network again.
We apologize for any inconvenience this may have caused.
Updated 12/10/2012
Rgds
Stephen
sweh is offline
post #70 of 115 Old 12-11-2012, 02:57 PM
Grizz's Avatar
As does the VSX-60, downloaded, updated and all is well with Pandora. smile.gif
Grizz is offline
post #71 of 115 Old 12-11-2012, 05:02 PM
MASoxFan's Avatar
Having problem still with firmware update.
Have Pioneer SC-61 and Pandora issue. I downloaded firmware update directly from Pioneer website onto desktop. It saved as Zip file. Extracted files and resaved them as Binary files. Copied them over to my flash drive and then connected flash drive to USB connection on the front the receiver. I followed steps and selected system update/selected update from USB.
I keep getting an error: "The file may be damaged. Either reconnect the USB memory device or replace it. Also trying saving the update file again."
I have tried this 3 separate times on various flash drives.
Any help?
MASoxFan is offline
post #72 of 115 Old 12-11-2012, 06:59 PM
mcpackjoe's Avatar
My VSX -60 isn't seeing the update over the network. Updated with USB, no issues. All is well with the world!
post #73 of 115 Old 12-11-2012, 07:00 PM
Titan7170's Avatar
Any help?
Samething I also have SC-61 and get the same error when trying to update with the flash drive! I also tried to update via internet and it says I have the latest version even though the one on the reciever is the older 122 and the new one I downloaded is the 152.
Titan7170 is offline
post #74 of 115 Old 12-11-2012, 10:42 PM
ESfishOX's Avatar
the firmware update just posted for the Pioneer VSX-1022-K did indeed fix the connectivity issue I experienced to Pandora.
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Pioneer+Receivers/VSX-1022-K?tab=firmware
ESfishOX is offline
post #75 of 115 Old 12-11-2012, 10:57 PM
Hortonz's Avatar
I just tried installing the firmware update on my AVR3312CI. I got an error message that said the update failed and now my receiver appears to be in an endless loop trying to update. Help. Did this just toast my receiver?
Hortonz is offline
post #76 of 115 Old 12-12-2012, 12:19 PM
c3corvette's Avatar
i have same issues with my sc-67 update error 4 it ll update up too 90% then show that error code tried different flash drives ......called pioneer they have no answer accept keep downloadind and change flash drive............ Any suggestions ? please !!
c3corvette is offline
post #77 of 115 Old 12-12-2012, 12:47 PM
c3corvette's Avatar
what brand flash drive did you use and did you download wirelessly? i ll try anything at this point
too Sweh
post #78 of 115 Old 12-12-2012, 01:54 PM
Titan7170's Avatar
too Sweh
Its a Kingston 16gb....I downloaded the file to the laptop then unzipped the files and copied them to the flashdrive. Then I also tried to update directly through the Pioneer menu on the SC-61 which is hardwired to the wireless router!
post #79 of 115 Old 12-12-2012, 02:11 PM
c3corvette's Avatar
Thanks sweh !! Idk what to do .... Ill try. That brand though its probably for not !!
post #80 of 115 Old 12-12-2012, 02:37 PM
Grizz's Avatar
I don't know if any of this will help but...make sure your flash drive is formatted fat16/fat32 and not NTFS, make sure its empty.
Grizz is offline
post #81 of 115 Old 12-12-2012, 03:40 PM - Thread Starter
Flashtime9's Avatar
I had to power down 2 times, after that the update finally worked.
post #82 of 115 Old 12-12-2012, 04:10 PM
sweh's Avatar
too Sweh
I used a SanDisk Cruzer Fit 4GB. I downloaded the Zip file to my Linux machine, unzipped it, copied the resulting bin file to the SanDisk, and then plugged that into the receiver.
Rgds
Stephen
sweh is offline
post #83 of 115 Old 12-12-2012, 04:21 PM
skohlmey's Avatar
Here is the schedule of Marantz firmware updates to fix the Pandora issue:
Firmware Updates
December 6: NR1603, SR5007, SR6007
December 11 SR7007, AV7701, AV8801
December 17: NR1602, SR5006, SR6006, SR7005, AV7005, MCR603, NA7004
source: http://us.marantz.com/DocumentMaster/us/PressReleases/PandoraProblem-M.pdf
skohlmey is offline
post #84 of 115 Old 12-12-2012, 04:31 PM
ss9001's Avatar
Quoted: 358 Post(s)
Liked: 423
too Sweh
I can add that when it worked for me yesterday, I took the extra step of formatting the drive as fat32 before I copied the bin files to it. PNY 8 GB drive. and I never download FW files with wireless, a habit I formed in my early days of PC building & updating motherboard BIOS. maybe wireless is OK but I like to play it safe with files as sensitive as firmware.
Formatting shouldn't be needed but I did it anyway. maybe worth a try smile.gif
Steve
ss9001 is offline
post #85 of 115 Old 12-12-2012, 07:26 PM
Titan7170's Avatar
After reading these 2 posts I decided to check my flash drive, now mind you I updated 2 weeks ago with the same drive so it is FAT32 but check this out, I deleted everything off the drive 2 days ago and downloaded the update and put it on the drive, I checked it and it was the same as I downloaded......end result it didnt work like I posted previously, so today after seeing you guys posts I said let me look at the files on the drive again.........I go into the drive and theres 27 or 28 files there all consisting of weird symbols,I dontknow what they were or where they came from no words just symbols but each had a file size! so I tried to delete them and they wouldnt delete so I formatted the drive 2 times, put the firmware I downloaded on the drive again and it just updated completely........going to see if I can get into pandora Ill let you guys know
post #86 of 115 Old 12-12-2012, 07:30 PM
Hortonz's Avatar
so it appears I need to be more patient. tongue.gif I left for work this morning with the system trying to do the update. Apparently is was successful at some point today because tonight everything, including Pandora, is working fine.
Hortonz is offline
post #87 of 115 Old 12-12-2012, 07:36 PM
Titan7170's Avatar
got mine working also!........thanks for the suggestions guys
post #88 of 115 Old 12-14-2012, 10:06 AM
c3corvette's Avatar
Ok finally ... Was able to update ! Bought a fourth flash drive a ( PNY 8 gig ) all is well Yea thanks for all of your inputs !!! Merry Chirstmas !!!
post #89 of 115 Old 12-16-2012, 11:09 AM
jpeters1218's Avatar
Just got the Marantz update installed. Does not seem to fix the Pandora problem unfortunately. frown.gif
jpeters1218 is offline
post #90 of 115 Old 12-16-2012, 11:49 AM
SR303's Avatar
I just got finished installing the firmware update for my AV8801. It worked and so does Pandora now.
SR303 is offline
