MiniDSP Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 11-30-2012, 06:54 AM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
Good morning everyone,
I just took receipt of a new Behringer EPX4000 amp and was looking to use the miniDSP to handle the EQing, however, I don't know which one to buy.
The input sensitivity of the amp appears to be 1V and my options for output are either .9 or 2. The question I have is how much am I really losing if I get the unbalanced that outputs .9, thats 10%, but is that really enough to fret at? The alternative would be the balanced version which would 2v output. Would that overpower and send my amp into clipping or will it only draw the 1v it requires? Any help would be greatly appreciated. Thanks.
kcnitro07 is offline
post #2 of 26 Old 11-30-2012, 08:10 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Use the 2V output setting and run it a few dB below that to match the amplifier's input. No significant loss. It's always better to try to run outputs a few dB below max as opposed to a few dB above... ;-)
As far as clipping the EPX 4000 goes, you seem to be highly confused. The master volume control in your system still rules that. Besides haven't you noticed that the Behringer has its own input level controls? The input sensitivity of the amp is only below 2 volts if you keep the little knobs most or all of the way up. Back them off to about 70, and you're as matched as you could ever hope for.
arnyk is offline
post #3 of 26 Old 11-30-2012, 08:20 AM
Quoted: 995 Post(s)
Liked: 523
Buy the balanced one. It has more signal, less noise. The unbalanced one only puts out .9Vrms no matter what the input setting is. The "2V" jumper just attenuates the input signal by 3dB.
Only drawbacks are that the unbalanced one has a sleeker-looking case, and it needs a 12V wall-wart (can't just be powered from the USB port).
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #4 of 26 Old 11-30-2012, 11:50 AM
Theresa's Avatar
Liked: 51
Just to clarify, its the balanced model that requires a 12 volt supply. It can also be used as a unbalanced to balanced converter.
Theresa is offline
post #5 of 26 Old 11-30-2012, 02:29 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
The balanced version comes with the connectors needed to plug into it?
post #6 of 26 Old 11-30-2012, 02:56 PM
Theresa's Avatar
Liked: 51
yes it does.
Theresa is offline
post #7 of 26 Old 11-30-2012, 07:16 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
Ordered, from hong kong? How long will that shipping take?
post #8 of 26 Old 12-01-2012, 01:09 AM
Theresa's Avatar
Liked: 51
It takes one to two weeks depending how long it takes for the order to be processed.
Theresa is offline
post #9 of 26 Old 12-01-2012, 06:40 AM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
That's encouraging, I ordered another item frm China and shipping time was quoted at a month and a half frown.gif
post #10 of 26 Old 12-01-2012, 10:57 AM
Quoted: 995 Post(s)
Liked: 523
IIRC, I had my last order from them (an 8x8, their box for the 8x8, and two balanced 2x4s) in the Southeast in roughly a week.
Serious Audio Blog
DS-21 is offline
post #11 of 26 Old 12-01-2012, 02:45 PM
DonH50's Avatar
Quoted: 2207 Post(s)
Liked: 1805
There is a dedicated thread on the miniDSP in the DIY Forum that may be helpful.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #12 of 26 Old 12-01-2012, 10:10 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
I read part of it, unfortunately my patience for arguments that are off topic and pointless isn't very high so I turned away. Whence it gets here I am sure I will go back there and look for usable information. Thanks
post #13 of 26 Old 12-02-2012, 01:36 AM
Theresa's Avatar
Liked: 51
I can't see any harm in starting a new thread if that's what is needed. If you have any questions just let me know.
Theresa is offline
post #14 of 26 Old 12-02-2012, 10:35 AM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
Thank you Theresa
post #15 of 26 Old 12-08-2012, 11:01 AM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
So I got the little burger today and I feel like a complete ******. I'm following the manual and haven't gotten very far. First off, it says it comes with a 1x3 rca cable.....I don't see that in the box, but beyond that, I can't get it to power on. I have plugged it into a USB 2.0 port on my PC and into the MiniDSP with the supplied cable and nothing is happening. It sounded like you didn't need the external power, that the device would be powered off USB only. Is this not true?
post #16 of 26 Old 12-08-2012, 11:15 AM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
NVM, apparently USB isn't enough to power it, I have plugged in an external power supply nad it appears to be working.
post #17 of 26 Old 12-08-2012, 11:39 AM
Theresa's Avatar
Liked: 51
Is it the balanced miniDSP?
Theresa is offline
post #18 of 26 Old 12-08-2012, 12:02 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
Yes balanced. I am to take it that you have to split open some RCAs and match up cables to plug into this thing eh?
post #19 of 26 Old 12-08-2012, 12:13 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
hahah saturday morning distracted by children....I was looking at the wrong manual, that has been corrected now. THanks.
post #20 of 26 Old 12-08-2012, 12:33 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
USB ports vary in terms of how much current they can actually provide. There are no global rules, but laptop USB ports seem to be more likely to be current-challenged.
arnyk is offline
post #21 of 26 Old 12-08-2012, 12:42 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
So I have it hooked up, I spliced a rca cable into the input 1, its unbalanced so I jumpered the - over to the S and did the same on output 1. PLugged the Input 1 into SW out on my Onky and Output 1 into the Channel 1 of my EPX4000 with it set to mono and now I get no sound out of my subs at all....did I do something wrong. I did practice with a cheapo real thin set of RCAs I had laying around before cutting into my $10 monoprice RCA cable. Any thoughts?
post #22 of 26 Old 12-08-2012, 01:11 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
I went ahead and upgraded my RCA cable to a nice big thick peavey cable I had laying around just in case. Same issue. On the input RMS meter I'm getting -75 dBFS at max regardless of what volume my SW channel is at.
post #23 of 26 Old 12-08-2012, 02:36 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
So I realized I was still using a 5V power supply so I picked a 12V and hooked it up, same issue...any one have any idea why its not working??
post #24 of 26 Old 12-08-2012, 03:06 PM
Theresa's Avatar
Liked: 51
Are you getting sound out of the unit?
Theresa is offline
post #25 of 26 Old 12-08-2012, 03:19 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
yes I realized it was working, just really quiet. If I graph with REW the graphs are identical, except with the miniDSP in the chain its 10 dB quieter. The peak of the graph without the miniDSP in the picture peaks at 98 dB (uncalibrated so that is probably not the true spl) When I add the miniDSP and leave everything else the same, it peaks at 87 dB. Which means to get the same output I have to turn the SW lvl up to +4. Once I start EQing I will likely have to go even higher than that in order to get anything worth listening to.
post #26 of 26 Old 12-08-2012, 03:22 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
I actually only had to go up to -1 from -6 on the SW to get the same volume as if I didn't have the miniDSP in the loop. Is this expected?
