Audyssey XT32 and sub level - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-30-2012, 01:31 PM - Thread Starter
Vallhall's Avatar
Hi
Just got a Audyssey XT32 receiver to compare with my MCACC receiver, and have a question about sub level.
Then i run the setup it tells me to lower the sub to 75db, but i cant as the kef sub doesnt have volumecontrol.
Any advice?.
Thanks in advance
Vallhall is offline
post #2 of 12 Old 11-30-2012, 01:50 PM
Bill Mac's Avatar
Quoted: 1561 Post(s)
Liked: 1806
Originally Posted by Vallhall View Post
Hi
Any advice?.
Thanks in advance
What model KEF sub is it? Is it a powered sub? That is odd that the sub does not have a volume or gain control.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #3 of 12 Old 11-30-2012, 01:58 PM - Thread Starter
Vallhall's Avatar
Bill
Thanks for the reply
The sub is a 3005 sub, and yes its powered
Vallhall is offline
post #4 of 12 Old 11-30-2012, 03:00 PM
Bill Mac's Avatar
Liked: 1806
Sure enough in this review it comments that there is no sub volume control. Maybe try posting in the Audyssey thread as I have no idea how to get past the "set sub to 75dB" step if your sub does not have a volume control. When you are running Audyssey at this step is there output from your sub? Does it show the sub volume level at this step? Is it above or below 75dB.
Bill
post #5 of 12 Old 11-30-2012, 03:09 PM - Thread Starter
Vallhall's Avatar
Bill
Yes it shows it, 85DB.
Vallhall is offline
post #6 of 12 Old 11-30-2012, 03:14 PM
Bill Mac's Avatar
Liked: 1806
Thats a tough one. Definitely try posting in the Audyssey thread as many in that thread are very knowledgeable and can hopefully help you out. Just out of curiousity can you get past the sub level setting or does the level need to be lowered to 75db before you can go further?
Bill
post #7 of 12 Old 11-30-2012, 03:25 PM - Thread Starter
Vallhall's Avatar
Bill
Many thanks for your help Bill
I can proceed and finish the setup so no problem. Ofcoure i can go into speakers level, and turn it down, but i thoght audyssey did this automatic. That said it sounds very good
Vallhall is offline
post #8 of 12 Old 11-30-2012, 03:40 PM
Bill Mac's Avatar
Liked: 1806
My pleasure. But it looks like you have everything under control smile.gif. Thats great that you can finish the calibration. I wasn't sure as my sub has a volume control so I can set it to 75dB. I have the 4311 and I've found that XT32 works quite well in my room. I'm glad to hear everything sounds good which is all that counts smile.gif.
Bill
post #9 of 12 Old 11-30-2012, 03:50 PM - Thread Starter
Vallhall's Avatar
Bill
Thanks again
I also have a Infinity kappa "10" sub with volume control, will try it later and report back:)
Vallhall is offline
post #10 of 12 Old 12-01-2012, 04:08 PM
jdsmoothie's Avatar
Quoted: 14995 Post(s)
Liked: 7227
As the sub is putting out 85db (or +10db over the calibration level), the AVR will likely max out at -12db trying to attenuate it, therefore you won't be able to further lower it using the AVR. You'll want to add an in-line attenuator similar to this one ---> http://www.amazon.com/Harrison-Labs-Line-Level-Attenuator/dp/B0006N41B0.
jdsmoothie is online now
post #11 of 12 Old 12-02-2012, 10:57 AM - Thread Starter
Vallhall's Avatar
Many thanks for your explanation
The heavy Onkyo is an great amp:D
Vallhall is offline
post #12 of 12 Old 12-06-2012, 10:27 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 780
This purplexed me on my 4520CI just 2 days ago..
Prior, under old XT & my 4308CI, I'd set the gain at 12 oclock on my Berighner 2500 amp and the sub would be set at around -2db or so, within plus/minus 3db pure the audyssey set-up guide.
Then, upon running XT32 on my new 4520CI it said my sub was @ 84db and displayed this box for me to move the gain knob till it was withing traget, target being 75db but actually once I went below 80db the box went from red to green and I could have proceeded. I had to turn the gain down to just past 9 oclock (I'm a "w" now, so can't give the gain# from memory).
In the end, even dialed down to lower gain XT32 set my sub trim to -4db.
So, it appears XT32 is analyzing the bass much different than XT did....I should have taken out my RS SPL meter, but forgot.....
For correct 0db reference listerning, sub's are 10db more than mains, 115db vs 105db @ peak's, so kinda curious why for the initial dial in XT32 asked for 75db astarget instead of 85db.....
mtbdudex is online now
