Pre/Pro Dilemma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 11-30-2012, 06:32 PM - Thread Starter
Manchild's Avatar
All,
I'm in the market for a pre/pro (or an AVR that I'll just use as a pre/pro) whose primary use will be home theatre (TV and Blu-ray). I really don't anticipate ever needing much beyond 7.1 given the current constraints of the room (...and pocketbook...and wife), but want to be sure that I have both MultEQ XT32/Sub EQ and reasonable video processing.
Thus far I'm looking at:
Integra DHC-80.3 or Onkyo PR-SC5509
Denon 4520CI or Marantz AV8801
Onkyo TX-NR5010/3010/1010
Anthem MRX 300/500/700
Clearly a big spectrum of pricing in the above...so I guess my real question is whether I need much more than a TX-NR1010 or MRX500 based on my needs? Any compelling reason to spend the dough on the others if I know I'm not going to get into 9+ channels?
Manchild is offline
post #2 of 17 Old 11-30-2012, 10:43 PM
mlknez's Avatar
Quoted: 205 Post(s)
Liked: 52
You should also take a look at the Outlaw 975 as a low end pre/pro and the Sherbourn line.
mlknez is offline
post #3 of 17 Old 11-30-2012, 11:04 PM - Thread Starter
Manchild's Avatar
Question on either of those is whether their room correction can compete with either Audyssey or ARC. The Sherbourn pre/pro appears to share a great deal with the MRX line.
Manchild is offline
post #4 of 17 Old 12-01-2012, 02:26 AM
Theresa's Avatar
Liked: 51
The 975 has no room correction. The Sherbourne is from the same company as Emotiva whose pre-pros have a very bad record when it comes to room correction.
Theresa is offline
post #5 of 17 Old 12-01-2012, 04:52 AM
MUDCAT45's Avatar
Quoted: 346 Post(s)
Liked: 280
Also Onkyo / Integra has a bad record for complete failure.
MUDCAT45 is offline
post #6 of 17 Old 12-01-2012, 04:57 AM
Theresa's Avatar
Liked: 51
Very true. I would not advise someone to get an Onkyo/Integra until I was certain they had sorted out their problems. I have absolutely no complaints about my Onkyo as far as SQ is concerned. What a disappointment the heat related problems have been! Its why I bought a Denon which was delivered yesterday. I also wouldn't advise anyone to buy a pre-pro or receiver without Audyssey XT32 which pretty much leaves Denon and Marantz.
Theresa is offline
post #7 of 17 Old 12-01-2012, 05:19 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5070
AFAIK they have. The x09 models haven't shown any significant issues AFAIK and the x10 models will presumably be even better.
EDIT: Actually, I have forgotten what you have, Theresa - is it the 80.3 (which is the same as my 5509)? If so, then that gives lie to my assertion here.
kbarnes701 is offline
post #8 of 17 Old 12-01-2012, 05:29 AM
Theresa's Avatar
Liked: 51
I have the 5508. Its good news that they've fixed the heat related problems as they are quality units in every other way. Now if I could get it replaced by Onkyo with a 5509, not likely I admit. Its been reported that they won't replace a unit with a newer one until it's been repaired three times.
Theresa is offline
post #9 of 17 Old 12-01-2012, 05:35 AM
kbarnes701's Avatar
Liked: 5070
Ah yes, of course. Sorry about that temporary brainfade... my 5509 has been entirely reliable so far (knock on wood).
post #10 of 17 Old 12-01-2012, 06:00 AM
Theresa's Avatar
Liked: 51
So far the only symptom indicating failure has been the unit power cycling for no apparent reason.
Theresa is offline
post #11 of 17 Old 12-01-2012, 06:32 AM
kbarnes701's Avatar
Liked: 5070
Yes but that is totally consistent with the Beginning Of The End as reported by so many on the x08s. It will get worse, with random source switching etc and then loss of all sound which will come back after a power cycle, followed by total failure. The good news is that Onkyo have stepped up to the plate and are fixing them without hassle.
post #12 of 17 Old 12-01-2012, 08:12 AM
aerial1230's Avatar
Onkyo is replacing my 5508 with a 5509 after 2 times being repaired. No hassles.
aerial1230 is offline
post #13 of 17 Old 12-01-2012, 08:17 AM
Theresa's Avatar
Liked: 51
That's good news.
Theresa is offline
post #14 of 17 Old 12-01-2012, 10:05 AM - Thread Starter
Manchild's Avatar
Well that pretty much takes those out. I agree that XT32 or ARC is a requirement, which means I'm still stuck with that first list.
May not be able to beat the MRX or TX-NR1010 for the money.
Dumb question, but I assume with nearly any of these you can use the pre-outs and the amps in combination (i.e. pre-outs for front stage and AVR for surrounds), yes?
Manchild is offline
post #15 of 17 Old 12-01-2012, 10:14 AM
Theresa's Avatar
Liked: 51
I just got the Denon 4311CI and you can use some or all of the amplifier channels. The new 4520CI also will do this.
Theresa is offline
post #16 of 17 Old 12-01-2012, 11:25 AM - Thread Starter
Manchild's Avatar
Cool. Question then is should I spend 70% more on a 4520CI or TX-NR5010 versus a MRX 300/500/700 or TX-NR1010. Tough.
Upside on the Onkyos is that they have superior video processing; upside on Denon is the 4K passthrough and presumed SQ.
Manchild is offline
post #17 of 17 Old 12-01-2012, 11:58 AM
Theresa's Avatar
Liked: 51
Many have good things about Anthem but I don't know anything about them.
Theresa is offline
