Pioneer vsx-1022 no longer works with Pandora - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-01-2012, 08:22 AM - Thread Starter
pttitzer's Avatar
I can no longer connect to my Pandora account with my vsx-1022. I can log into my Pandora account with my phone and computer browser. When I try to log into my Pandora account through the receiver using the on screen menu or Pioneer web control I get the message "could not apply new settings". I have tried resetting the receiver to factory defaults and upgrading the firmware but this has not solved the issue. Any help would be greatly appreciated as I can not find a reference to this problem on the internet. Is Pandora no longer compatible with Pioneer receivers?
pttitzer is offline
post #2 of 14 Old 12-01-2012, 08:37 AM
jdsmoothie's Avatar
Quoted: 14671 Post(s)
Liked: 6992
jdsmoothie is offline
post #3 of 14 Old 12-01-2012, 09:13 PM
frybabyjay's Avatar
I get a similar issue. From my smart phone and Tablet, i get "app does not support this operation". HELP!!
frybabyjay is offline
post #4 of 14 Old 12-02-2012, 08:19 AM - Thread Starter
pttitzer's Avatar
pttitzer is offline
post #5 of 14 Old 12-02-2012, 05:41 PM
usmyguy's Avatar
I am having the same problem. The next problem is I can't even update firmware via USB or Internet.
Any solution?
usmyguy is offline
post #6 of 14 Old 12-02-2012, 06:03 PM
BretM3's Avatar
http://www.pioneerelectronics.com/PUSA/Home/Pandora
I just updated my firmware today, via USB, so I can't help with that one. Just followed the instructions of Pioneer's website.
Bret
BretM3 is offline
post #7 of 14 Old 12-02-2012, 06:07 PM
BretM3's Avatar
www.pioneerelectronics.com/pandoranotice
Sorry, can't post a link; I'm too new.
Just updated my firmware today, via USB. No problems. Followed the instructions on Pioneer's site.
Bret
BretM3 is offline
post #8 of 14 Old 12-02-2012, 06:08 PM
BretM3's Avatar
Apparently, after enough posts are rejected, it qualifies you to post a real link.
Bret
BretM3 is offline
post #9 of 14 Old 12-03-2012, 06:47 PM - Thread Starter
pttitzer's Avatar
Any solution?
Try a different USB stick. The first I tried didn't work.
pttitzer is offline
post #10 of 14 Old 12-05-2012, 08:56 PM
usmyguy's Avatar
I tried 4 USB FAT32 formated drives none of them work. I called Pioneer they are sending me another USB drive, I am sure it doesn't work either. Look like my VSX-1022 is going to repair shop soon.
usmyguy is offline
post #11 of 14 Old 12-05-2012, 10:04 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 104
Bret
No, you just need to make 5 posts before you can post links. It helps stop drive-by spammers.
jdcrox is offline
post #12 of 14 Old 12-11-2012, 05:25 PM
usmyguy's Avatar
It is fixed. Go to Pioneer website and download firmware update 1.059 and enjoy your Pandora.
usmyguy is offline
post #13 of 14 Old 12-11-2012, 07:47 PM - Thread Starter
pttitzer's Avatar
Thanks. It works great now.
Were you able to get the Pioneer USB stick to work?
pttitzer is offline
post #14 of 14 Old 12-12-2012, 05:15 PM
usmyguy's Avatar
The USB Stick sent by Pioneer work! The reasons is the file is difference format.
The file I downloaded from Pioneer website was .bin file.
The USB stick sent by Pioneer is .bcd format.
It work on .bcd format but not .bin
Now my VSX-1022 is updated to 1.059
That answered my questions.
Ok! All our problem solved!! Enjoy!!!
usmyguy is offline
