Onkyo TX-NR818 causing issues with my Panasonic Plasma? - AVS Forum | Home Theater Discussions And Reviews
Old 12-01-2012, 03:51 PM - Thread Starter
Adam James's Avatar
Quoted: 24 Post(s)
I just hooked up my Onkyo TX-NR818 that I got on Black Friday, and it's causing the strangest issue, I hope someone can help.
When I'm using the main HDMI out on the receiver into my Panasonic th-42px80u TV, and I turn it off, it won't turn back on, the power light just keeps flashing. I tried using a different HDMI cable, I tried different HDMI inputs on the TV too, same thing.
When I use the 2nd/Sub HDMI out on the receiver this problem goes away, I can turn the TV on and off without any issues, when I switch the HDMI cable back over to the receiver's main HDMI output, same thing happens, I turn off the TV and it won't come back on, the power light just flashes. I never had this issue with the other receiver I bought to compare with the Onkyo, its a Yamaha RX-A2010. Also, never had this issue with my Denon 889 that died a few weeks ago. Any ideas?
Receiver is in direct mode for Picture Mode. The sub HDMI doesn't have the OSD menu, so it's not feasible for me to use it permanently.
Adam James is offline
Old 12-01-2012, 03:57 PM
putox1051's Avatar
Send a message via AIM to putox1051 Send a message via Skype™ to putox1051
Is HDMI CEC enabled on your Onkyo?
putox1051 is offline
Old 12-01-2012, 04:12 PM - Thread Starter
Adam James's Avatar
Quoted: 24 Post(s)
I believe that it's disabled because HDMI Control (RIHD) is turned off.
Old 12-01-2012, 10:53 PM - Thread Starter
Adam James's Avatar
Quoted: 24 Post(s)
What could cause something in the HDMI signal from the receiver to cause my TV to go into some protective mode? This is so weird and a shame because I really like the Onkyo and was going to return the Yamaha.
Old 12-02-2012, 03:48 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
IIRC, the Panny 10 "red' blinking LED is an indication of an HDMI voltage difference outside of the TV's parameter, so it would appear there is either a defect with the Onkyo's main monitor out jack or the TV's HDMI board is simply too sensitive. You could try calling Panasonic to determine if it's a repair issue that can be resolved with the TV.
jdsmoothie is online now
Old 12-02-2012, 08:10 AM - Thread Starter
Adam James's Avatar
Quoted: 24 Post(s)
I'm thinking it's a problem with the 818's main hdmi out, because I've had two Denon and one Yamaha receiver hooked up to this TV in the past month without any problems.
Old 12-02-2012, 07:34 PM - Thread Starter
Adam James's Avatar
Quoted: 24 Post(s)
I tried using the front HDMI input on the TV and it works fine, why would the Onkyo specifically cause this issue when the other receivers don't?
Old 12-27-2012, 09:29 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
Because the Onkyo has a problem and the others didn't...
Newbie01 is offline
Old 12-28-2012, 06:05 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
Onkyo has a long history of HDMI board problems. Not saying the problem is definately with the Onkyo. Just saying in general.
KidHorn is offline
Old 01-07-2013, 08:24 PM
rnrt99's Avatar
Wow , I had to sign up when I read your problem ! Because of you there isnt a 4 year old 50" panasonic plasma tv at the dump.I just bought the 818 and had the same issue and thought I suddenly had the "red light of Death " happening lol I really do like the receiver and from your post I'm just running from the sub hdmi without the fancy OSD , it sucks but I know someday I'll upgrade the tv and all should be good, thanks.
rnrt99 is offline
Old 01-07-2013, 08:34 PM - Thread Starter
Adam James's Avatar
Quoted: 24 Post(s)
Wow, so it seems the Onkyo 818 and some Panasonic plasmas don't play well together.
My workaround was to buy a $25 powered hdmi splitter to use between the tv and the receiver, I didn't want to go without the OSD.
Old 01-07-2013, 10:01 PM
rnrt99's Avatar
Well I will have to check that out , I would defiantly use the real osd if I can , thanks !!
rnrt99 is offline
Old 01-08-2013, 05:49 PM
rnrt99's Avatar
So you go from your main hdmi out into this splitter then to your tv and everything's fine ?? I'm just wondering how the splitter makes the tv work again ??
rnrt99 is offline
Old 01-10-2013, 11:06 AM - Thread Starter
Adam James's Avatar
Quoted: 24 Post(s)
Correct, the hdmi switch is powered and provides its own voltage to the hdmi outputs, seems like the voltage that is sent by the receiver causes the issue with the Panasonic's hdmi board.
Old 01-15-2013, 11:47 AM
RaphaelGal's Avatar
Hi,
I'm having a similar problem with the 818.
I only have this unit for 2 weeks.
it was connected to Samsung LCD via the HDMI main out.
It was working OK for couple of days, though it took some time and "shuttering" before i saw a picture on the TV.
However, in the last 5-6 days, there no picture anymore, just "No Signal" on the TV and i can hear the Audio through the speakers.
I've changed cables, unplugged the AC etc, but nothing works.
When I tried connecting the TV through the SUB out, everything works fine.
what are your suggestions? should i go for the splitter?
RaphaelGal is offline
Old 01-15-2013, 12:09 PM
Patrick Murphy's Avatar
Quoted: 67 Post(s)
Liked: 64
I don't know if this will help but I had a problem once with the 818 and my Mitsi projector syncing.
Start the 818 and cable box/directv, wait until you see "HDMI start up' on the receivers front panel go away and then turn on the TV.
Patrick Murphy is offline
Old 01-15-2013, 01:03 PM - Thread Starter
Adam James's Avatar
Quoted: 24 Post(s)
Originally Posted by RaphaelGal View Post
Hi,
Same thing for me, the problem didn't start for a few days. The hdmi splitter/switch solution works perfectly.
Old 01-16-2013, 06:28 AM
RaphaelGal's Avatar
I will try today and advise
Old 01-16-2013, 07:14 AM
gurkey's Avatar
Quoted: 112 Post(s)
Liked: 89
I thought the recommend sequence would be: sink (display) first, then repeater (AVR) next, source (i.e. BD player) last.
This way the component turned on in sequence would always see an already active partner for the HDMI handshake with known parameters.
This did cure - at least for me - all HDMI handshake problems.
This is the way i programmed my Harmony One remote.
gurkey is offline
Old 01-16-2013, 08:36 AM
Quoted: 67 Post(s)
Liked: 64
You may be right. I was just saying how I do it since the one and only time that the pj wouldn't sync.
Thinking about this a little more, wouldn't the most logical work-around be to just turn off the 818 and start the whole process again as the OP said it works fine until he turns off the tv and turns it back on?
Old 01-16-2013, 11:18 AM
RaphaelGal's Avatar
Well,
I found an old HDMI switch (not splitter) but with it's own DC voltage.
I tried and still no picture through Main Out, connected via SUB out and no problem.
Feels like sending this AVR down the drain.
Old 01-18-2013, 10:14 PM - Thread Starter
Adam James's Avatar
Quoted: 24 Post(s)
Well,
The problem I was having was the receiver putting my tv into a protected mode where it would not power on, it wasn't an issue with just video signal. The led on the front of the tv would just flash and not turn on until I disconnected the hdmi, and held the tv power button down for like 20 seconds.
Old 01-31-2013, 09:27 PM
rnrt99's Avatar
Ok , I've received my splitter and hooked it up to the main out and everything works great but .........now when I have the tv on when I adjust the volume it automatically mutes ?? I hit mute and everything is great again until I adjust the volume again . When the tv is off playing CD's etc volume works fine ? Any thoughts ?? Hdmi audio?
rnrt99 is offline
Old 02-03-2013, 12:19 PM
rnrt99's Avatar
Update , I turned off the hdmi control (RIHD) and everything is working fantastic !!!!!
rnrt99 is offline
Old 02-18-2013, 10:41 AM
Awake0001's Avatar
I am having a similar problem with a Panasonic GT-50 monitor. In which unit did you turn off the HDMI control - the TX NR-818 or the monitor? Were you still using the splitter when the problem was "finally" solved? Thanks for your help!
Awake0001 is offline
Old 02-18-2013, 10:49 AM
Awake0001's Avatar
Hi! Do you use audio return channel in this setup and does it work? If you have the name and model number of your powered HDMI splitter, I would appreciate it. Thanks.
Onkyo Tx Nr818
