whats your thoughts on refurbished receivers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-02-2012, 08:37 PM - Thread Starter
dizzyrapper18's Avatar
Are they worth it?
Accessoriesforless.com offer up to 5 year extended warranties. So does it make it a must buy? Anyone know if you have to pay for shipping?
dizzyrapper18 is offline
post #2 of 12 Old 12-02-2012, 08:55 PM
Rob-Houston's Avatar
Quoted: 126 Post(s)
Liked: 73
I bought a Denon avr-591 from Accessoriesforless.com for my bedroom home theater. Audyssey worked so well that I bought a 1712 for my family room home theater. I've also bought some xlo/vdo cables from them. I'm happy with everything I've bought from Accessoriesforless.com.
I've never gotten my money's worth from an extended warranty.
Shipping depends on the model you're buying. The 591 had free shipping the 1712 I paid shipping.
Rob-Houston is offline
post #3 of 12 Old 12-02-2012, 08:55 PM
XStanleyX's Avatar
Liked: 1270
Originally Posted by dizzyrapper18 View Post
Are they worth it?
Just enter your state and zip code and it will calculate the shipping cost if there is any. A must buy? Of course not but you will usually save a good chunk over buying new.
They have had a good reputation in the forums.
XStanleyX is offline
post #4 of 12 Old 08-25-2013, 04:22 AM
luvthefloyd's Avatar
I'm looking at a refurb from them. Should i expect it to appear new or are dings an scratches the norm?
By Grabthar's hammer.......... What a savings.
luvthefloyd is offline
post #5 of 12 Old 08-25-2013, 05:13 AM
jdsmoothie's Avatar
Quoted: 15338 Post(s)
Liked: 7497
Both conditions have been reported. Just depends what the mfr ships to them.
jdsmoothie is offline
post #6 of 12 Old 08-25-2013, 05:19 AM
XStanleyX's Avatar
Liked: 1270
The 4311 I bought from them had 3 small dings on the corner of the face about the size of a grain of rice. Not very noticeable till you get up close. Like jd said, you may or may not get one that looks perfect. The seller has no way of knowing what it looks like in the box.
post #7 of 12 Old 08-25-2013, 05:37 AM
Thanks i kinda figured it might be a random chance situation. Does Marantz have a particular reputation either way?
post #8 of 12 Old 08-25-2013, 05:53 AM
XStanleyX's Avatar
Liked: 1270
Any of them could be used with some sort of damage. The last Marantz I bought was a 7005 open box floor model from BestBuy. You get the full warranty with those. You might check the local BestBuys in your area to see what they have, Only the BB's with a Magnolia Hi Fi in them will have the higher end models. You can sometimes find some good buys. Try the link below. The BB in Issaquah has a Magnolia in it and I think Lynwood also.
http://www.bestbuy.com/site/Clearance/Deals-Near-Me/pcmcat254400050000.c?id=pcmcat254400050000&DPSLogout=true&_requestid=137398&isLogout=true&ci_src=11138&AID=10474050&PID=4003003&SID=1et7lr6zcv0gu&URL=http%3A%2F%2Fwww.bestbuy.com%2Fsite%2FClearance%2FDeals-Near-Me%2Fpcmcat254400050000.c%3Fid%3Dpcmcat254400050000%26DPSLogout%3Dtrue%26_requestid%3D137398%26isLogout%3Dtrue%26ci_src%3D11138&ref=39&CJPID=4003003&loc=01
post #9 of 12 Old 08-25-2013, 06:16 AM
I go to the bellevue magnolia. They have a open box section, theres always a bunch of cool stuff in there.
post #10 of 12 Old 08-25-2013, 06:17 AM
You don't happen to know the output voltage on marantz receivers do you? I've been trying to find out if the sr5007 puts out more than 1.4v.
post #11 of 12 Old 08-25-2013, 06:21 AM
MalVeauX's Avatar
Heya,
I bought used receivers from Amazon's warehouse deals. Saved like $200 off retail. Shows up in a different box, but fully functional with remote and a manual (which I could have gotten a PDF of online anyways). I think I replaced a foot on it for $5 since it was cracked. Others had zero issues, maybe some finger prints or a small scratch or scuff here and there. Overall though, fully working machines for 25% to 50% less cost. Fine by me. Plus, with warehouse deals (if amazon specifically, don't do this if it's not sold by Amazon LLC) you can return them in 30 days if something isn't right.
Very best,
Source: Pioneer VSX1121
Fronts: Polk Monitor 70 x 2 (AudioSource AMP100 in bridge mode, each)
Center: Polk Monitor 70 x 1 (AudioSource AMP100 in bridge mode)
Side Surrounds: Polk Monitor 50 x 2 (Direct from VSX1121)
Rear Surrounds: Polk Monitor 50 x 2 (Direct from VSX1121)
Subs: Polk PSW505 x 2
MalVeauX is offline
post #12 of 12 Old 08-25-2013, 10:27 AM
bladerunner6's Avatar
Quoted: 22 Post(s)
Liked: 59
As for an extended warranty, if you use Amex through PayPal you get another year of warranty from the credit card.
bladerunner6 is offline
