Denon AVR-1911: Remote Control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-03-2012, 02:50 AM - Thread Starter
taraskyn's Avatar
Hi people!!!
I own a Denon 1911 and I am trying to understand if I can actually program a remote to control any devices like tv, ps3, tivo box etc.
It looks like it is capable of doing that but it does not work for me. Is there a magic button or something? BY following the instruction in the manual does not help even though it has a code for tivo and a tv...
Anyone has any ideas please???
taraskyn is offline
post #2 of 4 Old 12-03-2012, 03:03 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
If none of the preloaded codes work for you (see p. 63 OM), then consider purchasing a Harmony remote.
jdsmoothie is offline
post #3 of 4 Old 12-03-2012, 03:14 AM - Thread Starter
taraskyn's Avatar
Yes, I was thinking buying a Harmony remote but I just wanted to give this one a shot.
One more thing, at the bottom of the remote there are two buttons: POWER TV INPUT - this turns on/off the tv. when I reset the remote I cannot do it any more. And I forgot how to set it back again. I've gone through the manual but cannot find it.
Any idea please???
taraskyn is offline
post #4 of 4 Old 12-03-2012, 03:19 AM
jdsmoothie's Avatar
Liked: 5502
As noted on p. 62, the preset code for TV is SONY. If you don't own a Sony, then you'll need to go through the registering process just as with any other device.
Denon Avr 1911 Receiver
