Owners Thread Cambridge Audio 651r/751r - Page 23 - AVS Forum
post #661 of 685 Old 11-02-2014, 05:19 AM
Liked: 0
Hi,
I am Considering a CA ...
2 questions -
1- What about the 751 v2 ? Anyone has one , instead of the 1st version?
Have they fixed the issues, or there are still a lot of noteworthy problems ...audio drops , HDMI issues and so on ?
2- Anyone tried the CA 751v2 with B&W 600 s2 speakers ( i have 684 s2, 685 s2, HTM62...and maybe i will upgrade next year the frontal to a CM) ? It's a good match ?
Cheers
J_P_P is offline
post #662 of 685 Old 11-03-2014, 05:35 AM
healthnut's Avatar
Hearing good things about CA sound quality, I also carefully considered them. But two glaring issues quickly presented themselves: reliability and poor customer service. If you go this way, I would buy from an authorized dealer and opt in to a good extended warranty. A local dealer would be best, online, Crutchfield has a reputation for standing behind their products. Personally, all the frustration experienced by CA owners drove me away from their receivers. I do own and love their blu ray players however. Best of luck!
healthnut is offline
post #663 of 685 Old 11-03-2014, 07:53 AM
Liked: 0
Yeah ! the reported problems are scaring me, and preventing me from even considering it !
J_P_P is offline
post #664 of 685 Old 11-04-2014, 04:14 PM
Liked: 0
No other options or experiences with the new V2 ?
J_P_P is offline
post #665 of 685 Old 11-05-2014, 08:32 AM
schane's Avatar
So... I have a 650r and have been having all sorts of issues with video passing through HDMI. I understand that this is because of the older hardware in this aged unit.
I have a 751r v2 on order and I hope this fixes my issues. I run a Mac mini using plex as my theater server and has always worked great up until mid to late summer when I started having all sorts of video issues with my older unit.
Does anyone run a Mac mini with plex thru their v2!?? I'd love to get some input.
schane is offline
post #666 of 685 Old 11-09-2014, 07:18 AM
Liked: 0
New to home audio
Hello All,
I recently picked up the CA Azur 651R. I am trying to figure our the best way to play streaming audio from my PC (Pandora/Spotify) on my home system. This model does NOT have the USB port like the 751R does for computer connection.
1. Should I use HDMI cable from PC to CA?
2. Should I use 3.5mm Jack from PC to MP3 plugin on the front of the receiver
3. Should I use bluetooth from my PC to my belkin bluetooth device (purchased separately) that is plugged in to my 3.5mm MP3 port on the fron of my receiver. Easier for me as less cables/wires but I imagine i loose a fair amount of sound quality this way
4. Is there a better way I should be doing this?
Thanks so much for any/all response. I am new to the home audio world but do appreciate good sound. Trying to get the most of my system for home listening
Jeff
Jeff Puette is offline
post #667 of 685 Old 11-09-2014, 09:50 AM
TripleFun's Avatar
Originally Posted by Jeff Puette View Post
Hello All,
Jeff
Use the HDMI connection so you preserve the digital content.
TripleFun is offline
post #668 of 685 Old 11-09-2014, 02:11 PM
Liked: 0
Great, thanks for the response. If I use an hdmi cable to connect my pc to my CA receiver will I be taking advantage of the built in DAC from my receiver or using my computers sound card?
Jeff
post #669 of 685 Old 11-10-2014, 07:56 AM
adrman's Avatar
Jeff
The receiver's DAC.
adrman is offline
post #670 of 685 Old 11-16-2014, 05:06 AM
DoctorFouad's Avatar
I own a CA751 and while the sound quality is great I am still encountering very annoying problems with sound dropping/cutting several times while watching TV/youtube videos + 1-2 seconds delay of sound whenever I play a new file (audio or video). Some youtube videos are just unwatchable with this receiver, you just cant hear anything, it cuts every two seconds.
Do you know if a new firmware solved thiese problems ? or if the new v2 of 751 solved these sound dropping/cutting/delayed issues ?
I would be grateful for your help. thank you.
DoctorFouad is offline
post #671 of 685 Old 11-23-2014, 10:45 AM
Mustafa Jones's Avatar
751r help with usb
Hi all I've had my 751 for about a month now and am loving it. It seems to be sounding better and better although I'm sure it's a combination of the new totems breaking in also.
Anyways I've just started playing around with it and I've hooked up my pc with the usb to see if there is a difference in SQ. I had it running over hdmi. My question is once I switch to usb on the reciever I have no video output. Can anyone help me I'd like to have the audio over usb and video hdmi from the htpc. Is this possible?
Thanks for any help,
David
Mustafa Jones is offline
post #672 of 685 Old 11-23-2014, 06:02 PM
TripleFun's Avatar
David
You can assign an analogue audio signal to a video signal, but, I don't think USB is a valid audio option. You could also try 'audio split mode' (see page 31 of the manual) although this feature does not look as if it is accessible using the remote ..
Audio split mode
In some circumstances the 651R/751R is able to allow the user to view one
source whilst listening to another. For instance you could watch the video of
a sports channel whilst getting an audio commentary from another such as
the Tuner.
To perform Audio Split:
1. Select the source you wish to watch in the normal way.
2. Press and hold the button on the front panel (not remote) for the source
you wish to listen to. After 4 seconds approx “Audio Split” will scroll across
the display and you will now be listening to that source instead. Video will
not have changed.
The 651R/751R allows splitting from any source whatever its video input
type (Composite, S-Video, Component or HDMI) but only to sources where
analogue or digital audio is the current audio input type, not HDMI.
If the combination is not allowed “Mode Unavailable” will instead scroll
across the display and no change will be made. To cancel audio split mode
simply select a new source and normal operation will be resumed.
post #673 of 685 Old 11-24-2014, 09:08 AM
Hey thank you it works great!!!! I was trying that "split" method the other day but for some reason when I tried to select usb as the alternate audio source it was switching it to digital....but went down this morning and tried it and all works.
Thanks again
post #674 of 685 Old 11-28-2014, 11:43 AM
Liked: 0
I've read this whole thread but so far haven't found anyone posting on the one feature which I'm interested in - the Follow Main.
What I'm after is something which will let me listen to multi-channel sound on a 5.1 speaker system while my wife listens on cordless headphones - she is hard of hearing so needs the volume high.
When I had separate sources (blu-ray player, satellite PVR, terrestrial PVR) this was doable since each source had an analogue stereo out as well as HDMI so we used an audio switchbox. But now I have a media PC which can't do this - so I'm using HDMI only.
I'm currently using a HDMI splitter and an Atlona audio converter to feed the headphones but this is clumsy and needs more HDMI cables and PSUs.
So - can the 651R/751R send a stereo downmix to analogue outputs that I could plug the headphones into, while simultaneously sending the 5.1 to the speakers? Some places say yes, others say no, the speakers will revert to 2 channel stereo.
quartermain is offline
post #675 of 685 Old 11-28-2014, 10:04 PM
TripleFun's Avatar
The 751r/651r supports 7.1 preamp out which could be used to drive a headphone amplifier.
post #676 of 685 Old 11-29-2014, 02:18 AM
Liked: 0
But it needs to mix (at least) the centre channel into the front left and right to form the stereo output, else there would be no dialogue in films.
post #677 of 685 Old 11-29-2014, 04:15 AM
Francky's Avatar
Liked: 24
If you go and take a look at every official receiver thread you will find horror stories one after another. Anthem Mrx 710 wich is known to be the best thing around has shutdown issues, On kyo's have heating issues and hdmi boards issues. I could go on about every manufacturers. I've had my share of problems with my 751r V1 but nothing major. I wouldnt tell people to stay away from this unit.
Focal Chorus 816v, CC800, 807V, SVS PB2000, Cambridge 751r, OPPO 103D.
Francky is offline
post #678 of 685 Old 11-29-2014, 02:26 PM
TripleFun's Avatar
Other then investing in a 7.1 headset you could also look at using an HDMI heaphone amp. The 751r has 2 HDMI outputs.
post #679 of 685 Old 12-01-2014, 11:46 AM
Liked: 0
But don't they just send video, not sound? Designed for a TV and a projector I guess.
If anyone who has one of these could confirm exactly what the "Follow Main" function does it would be very useful. Cambridge aren't responding to requests left on their web site and Richer Sounds aren't picking up the phone (or at least they weren't at 4-30 today).
post #680 of 685 Old 12-05-2014, 06:24 PM
KLoNe's Avatar
Can someone please send me the latest 651r firmware with install instructions?
Many thanks!
klone1 (at) gmail (dot) com
Yes, both the 651r and the 751r can both certainly send a FOLLOW MAIN signal to Zone 2.
KLoNe is offline
post #681 of 685 Old Today, 03:14 AM
Linefader's Avatar
Liked: 0
Originally Posted by ariston View Post
Although the manual recommends connecting the 751BR to the 751R using both the HDMI and the direct analogue connections, this will not work. I found that until I disconnected the analogue connection and just used the HDMI, I could not get the receiver to with to multichannel audio when watching movies. Also I have not been able to get the 751BR and 751R to communicate using the 7.1 direct button and the analogue connections between the units.
I have a 752BD connected to my 751rV2 using both HDMI and analogue cables and everything is working fine: I can switch the input from HDMI to analogue (which I am doing e.g. when I am playing a SACD) and back (for playing BluRay discs).
However, I also had a problem when both HDMI outputs of my 752BD were used: the 752BD HDMI-Out1 was connected to the 751rV2 and the 752BD HDMI-Out2 was connected to HDMI-In1 of my beamer (Epson EH-TW9100), while the 751rV2 HDMI-Out1 was was connected to my TV and the 751rV2 HDMI-Out2 was also connected to the beamer. With this setup, there was occasionally no sound when I was playing a BluRay disc. However, after I simply disconnected the direct HDMI connection between the 752BD the 751rV2 everything was working fine.
Originally Posted by ron hawaii View Post
Anyone know if the zone 2 ir jack is dual band or single band? anyone tried wireless extenders that worked?
this is a pretty interesting question. Nobody seems to know that (not my dealer nor his distributor ..) I only know that the Logitech Harmony Extender does not work (at least not with the cables that I tried).
Can anyone tell what the best way to play spotify via this receiver?
I am using a CA Stream Magic 6v2 which supports Spotify Connect and I am quite happy with it.
Originally Posted by Tamiri View Post
I own the 752BD. I'm interested in the 751 as an ideal pair but worried about the problems encountered (sub management, first second cutted and so on)
I have both devices and I would recommend them: I encountered no serious problems so far.
Originally Posted by MSHAVS View Post
this will be my last post on this forum since I switched from my CA 651R to the Marantz SR7008 (on sale this moment due to new SR7009).
that's interesting: I had a Marantz SR7008 which I traded in for a CA 751rV2 since I had picture dropout problems with the Marantz. Since I have the Cambridge receiver, my beamer never lost the signal from my 752BD (which frequently happened with the Marantz).
Originally Posted by TripleFun View Post
I use a programmed Logitech harmony to process all the connection options.
I am also using one and I have one problem with the activities:
When all my devices are turned off and I choose an activity (such as "play a BluRay disc") the input selected on my 751rV2 is always the same that was used before I put the device into standby (e.g. the Stream Magic). However, once the 751rV2 is powered on, I can switch between my programmed activities and the 751rV2 always picks the correct input. Thus, my Harmony is sending the correct signals. Does anybody know how to fix this?
I already tried re-ordering my devices, such that the 751rV2 is always switched on as the first/last device for an activity but this did not help. After powering on, the 751rV2 always remembers the last input and I once have to change it manually.
Linefader is offline
post #682 of 685 Old Today, 03:17 AM
Linefader's Avatar
Liked: 0
of course I meant the direct connection between the 752BD and the beamer .. I don't know how to edit a post in this forum ..
post #683 of 685 Old Today, 05:00 AM
Linefader's Avatar
Liked: 0
one more correction: whenever I said beamer, I actually meant "video projector"
post #684 of 685 Old Today, 06:22 AM
b4z
b4z's Avatar
I was offered a really great deal on a 651r demo. I've had quite a few problems with my 540rv2. Every time it is turned on it goes to -6dbw and blasts, concerned it will blow the speakers so i have been leaving it on. The remote also stopped working and it stopped passing any signal to the sub.
I felt like it would be the wrong thing to give CA my money again, so I bought a marantz sr5009 on sale at best buy Friday night. Pretty sure I am done with CA, it was supposed to be a higher end, better quality product. I had much better reliablity from the countless Sony ES products I've bought since the '80s. Fingers crossed on the marantz. This wll be my first marantz product. I did have to do a hard reset to get it to pass through hdmi, but has been perfect since then and the sound quality is fantastic.
b4z is offline
post #685 of 685 Old Today, 10:26 AM
TripleFun's Avatar
@Linefader I already tried re-ordering my devices, such that the 751rV2 is always switched on as the first/last device for an activity but this did not help. After powering on, the 751rV2 always remembers the last input and I once have to change it manually.
In the harmony activity startup command sequence you can add additional commands including changing the 751r input. If the commands don't work then try changing the device delays - see power advanced settings. I don't have access to my 751r just now and can't tell you my settings.
Cambridge Audio Azur 651r Home Cinema Receiver , Cambridge Audio Ltd , Cambridge Audio , Cambridge Audio Azur 751r Black
Gear in this thread - 751r by PriceGrabber.com
