replace1066 rotel for hdmi - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-03-2012, 11:58 PM - Thread Starter
davey r's Avatar
hi all, I have a rotel 1066, it doesn't have hdmi. I could get around this using the multi channel inputs and sending the video directly to my projector. I will be using the oppo 103. I am thinking about replacing the rotel with the new outlaw 975. My question is other than using one cable(hdmi) vs several component cables, what would be the advantage to buying a new precessor? In general would this purchase be a down grade.? I know the 975 is very new and I have only read one review so not much to go on yet. Any thoughts? Thanks.
davey r is offline
post #2 of 7 Old 12-04-2012, 08:06 AM
LVS
LVS's Avatar
This is the reason why I moved away from Rotel because they are slow to adapt to switching changes. However, I don't feel like I have had the same quality in the sound department since. I moved from separates, Lexicon with ATI amps to a Rotel and didn't think the sound quality suffered much at all but when I changed from a Rotel to a Denon, I noticed a much bigger difference in sounds quality. This was to my ears and in my room though, so everyone's mileage will vary.
LVS is offline
post #3 of 7 Old 12-04-2012, 10:15 AM - Thread Starter
davey r's Avatar
I think I'm going to purchase the outlaw. My rotel remote needs replaced (worn out) and I will need more component cables. I won't be able to see the on screen menu of the rotel either since I would be bypassing all video direct to projector. None of these are big things in themselves but they kinda start to add up.
davey r is offline
post #4 of 7 Old 12-04-2012, 12:30 PM
LVS
LVS's Avatar
please report what you think of the Outlaw.
I am considering going back to separates and take a leap on the Emotiva UMC-200 and UPA-500 for a modest separates setup similar in price to the receivers I have been purchasing. The Denon has the Audyssey MultEQ XT but I think this is partly what is killing the sound.
LVS is offline
post #5 of 7 Old 12-07-2012, 10:53 AM
seiji's Avatar
Quoted: 40 Post(s)
Did you purchase the Outlaw, if so I would be interested in how it works. I know you said you will purchase a Oppo 103 or you already have one, have you ever considered using it as a preamp.
seiji is offline
post #6 of 7 Old 12-07-2012, 10:58 AM
seiji's Avatar
Quoted: 40 Post(s)
Have you purchase the Emotiva umc-200 if so I would be interested in how it works and how you have it setup. I was also looking at the Emotiva but I have read that it has not been realiable at least the Umc-1, I don't know about the Umc-200.
seiji is offline
post #7 of 7 Old 01-27-2013, 05:36 PM - Thread Starter
davey r's Avatar
it's been a while but I did purchase the outlaw 975 ....I'm not too impressed. Maybe my fault, not sure.
I have two isssues I can't resolve. 1) the unit must be turned up quite hi (18 19 etc.) to be very loud. 2) My sub ( lfm-1ex also an outlaw) doesn't do much, very little bass output. Volume on sub must be around 7 and the bass that's there is very sloppy. I have tripple checked all set ups and don't know what's wrong? I'll be calling monday to see what I can figure out. In the mean time if anyone has any ideas I'm all ears.
davey r is offline
