HELP Wanted : ) regarding two output amplifier to one input speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-04-2012, 05:20 PM - Thread Starter
Leeds_AudioPhile's Avatar
I have a techincs seperates system and have recently bought new speakers, now the old ones that came with the system had four inputs on the back. two for LF and two for HF.
I bought some eltax floor standing speakers that only have two inputs the red and black. how do i wire this correctly as i tried connecting them earlier and when i turned the amp on and tried turning it up it cut out as if i had some touching wires. i checked and this was not the case.
i wired the positives to positives and negatives to negatives. where am i going wrong??
help would be much appreciated : D
Leeds_AudioPhile is offline
post #2 of 5 Old 12-04-2012, 05:22 PM
speavler's Avatar
Quoted: 12 Post(s)
Liked: 26
i would not do that. i don't think you can bi-amp - i believe that's what you're attempting - speakers that are not designed to be bi-amped. did you blow a fuse in your amp?
speavler is offline
post #3 of 5 Old 12-04-2012, 05:30 PM - Thread Starter
no havnt blown a fuse just think it cut off before any damage was done. i would have thought this would have done damage to the speakers if anything. also the speakers are 200watts a piece an the amp is only rated at 180 watts per channel. i have ended up wiring the HF to the new speakers and the LF to the old speakers so now i have four on the go...
thanks for your reply
post #4 of 5 Old 12-04-2012, 06:25 PM
whoaru99's Avatar
Liked: 69
Yeah, you can't just connect the HF and LF cables together. Lucky you don't blow up the amp.
Leeds_AudioPhile likes this.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #5 of 5 Old 12-05-2012, 05:09 AM - Thread Starter
so theres no way of doing this except how i have it now with seperate speakers for the different frequencies? eg two speakers for HF and two for LF?
the amp is only rated at 360watts and the total wattage of my 4 speakers is 760 watts. maybe time for a power amp that can run this setup..
