need help asap!!!!!!! is this fire from amp or just dirt from storage locker? - AVS Forum | Home Theater Discussions And Reviews
Old 12-06-2012, 11:25 AM - Thread Starter
keyboardcat's Avatar
two.jpg 307k .jpg file
keyboardcat is offline
Old 12-06-2012, 11:26 AM - Thread Starter
I have a chance to buy this amp cheap. what does it look like is on the back? i know that it's in bad conditition, but it's a nad. i thought maybe it would work. it's a hour drive each way.
Old 12-06-2012, 11:34 AM - Thread Starter
is it just me or do some of the red and black connections where you slide the speaker wire look broken on some sides? would the wire still stay in?
Old 12-06-2012, 11:39 AM - Thread Starter
I have been looking for a used nad for over a year. i wish that this was in better condition. the people who bought it at a storage locker don't know if it works. i guess they bought a big lot of stuff and the stereo stuff was in it.
XStanleyX's Avatar
Liked: 1269
Looks like the springs that keep pressure on the speaker wire are broken.
XStanleyX is offline
Old 12-06-2012, 11:41 AM - Thread Starter
is it hard to fix or broken for good stanley? i offered 25 for it because of the condition, so since the springs are broke the wire would just fall out right unless i taped it? ps cool monkey pic
Old 12-06-2012, 11:46 AM
XStanleyX's Avatar
Liked: 1269
That's not a monkey. That was me 50 years ago. You could probably jerry rig the wires to stay in. You might be able to replace the posts with new ones. Don't get brand smitten just because it's a NAD. It's just a an old amp as far as I'm concerned.
Don't mean to rain on your parade.
Old 12-06-2012, 11:47 AM - Thread Starter
stanley the display on the front that shows you what imput that you have on looks badly scratched to me or maybe cracked what do you think? 3 to 4 nad deals were made this year, but the sellers were shady and wanted to much. one even said in the ad 100 for everythig and a cd player. they later said no just the pre amp for A 100 AND another 100 for the power amp. I don't really want to spend more then 60 or 70 for a 1980s nad. I see that the prices are 2 and 300 bucks a lot of times on ebay. I was going to save up and get the new 326bee but I thought that i would try a few more times before the end of the year for a used amp. this one is 1995 so it is newer.
Old 12-06-2012, 11:48 AM
XStanleyX's Avatar
Liked: 1269
Save up for a better one. IMHO.
Old 12-06-2012, 11:50 AM - Thread Starter
i do get excited about nads, but your right other old amps sound just as good. I have been listening to a old zenith receiver lately in my room. it picks up some radio stations better then my old sony. if it was you stan would you stay away from that nad? this seller doesn't know what nad is so I thought that i could get a good deal with her compared to the major resellers that go to the thrift stores and estate sales and reselll for big bucks.
Old 12-06-2012, 11:52 AM - Thread Starter
do you ever like to switch different brand amps and speakers for your set ups sometimes in a few months? for 3 weeks I was using the yamaha receiver with sansui speakers. i think that i am going to hook up the sansui speakers to my heath pre amp and power amp for better sound.
XStanleyX's Avatar
Liked: 1269
Sorry but I wouldn't make a 2 hour drive if it were for free.
Old 12-06-2012, 11:53 AM - Thread Starter
do you own any nad amps or did in the past stanley? if so were you impressed with them?
Old 12-06-2012, 11:55 AM - Thread Starter
there is a guy with a nad receiver cd player and two expensive psb speakers but he wants $650.00. he is 4 hours away. I can't pay that much used. his amp is only 7 years old.
Old 12-06-2012, 11:56 AM - Thread Starter
in case i notice those spots in the back of a receiver again are those spots from a fire? what do you think it is stanley?
Old 12-06-2012, 11:57 AM
XStanleyX's Avatar
Liked: 1269
Just one. I don't remember the model number. I've owned lots of audio gear. Sold it all after my wife died and moved to Arizona for a year. Back in Seattle now and am starting over. Click on the link in my sig. Just some of the stuff I've owned.
It can get to be a very expensive hobby. Now that I've retired my budget is much less.
Old 12-06-2012, 11:58 AM - Thread Starter
stanley I am so sorry that your wife died.
Old 12-06-2012, 11:59 AM
XStanleyX's Avatar
Liked: 1269
Old 12-06-2012, 12:01 PM - Thread Starter
wowwwwwwwwwwwwww your stereo gear is impressive. you have stuff that most people only dream about having. you even have the expensive thiel speakers krell expensive cary and bryston. aren't bryston amps like 2 or 3 thousand and up? I hear that they are the only amp close enough to a mctintosh though.
Old 12-06-2012, 12:05 PM
XStanleyX's Avatar
Liked: 1269
I bought a pair of those Brystons used. They didn't sound any better than the receiver I had at the time. If you need the power amps are worth it. If not they are a waste of money. Just my opinion.
Old 12-06-2012, 12:22 PM - Thread Starter
in a blind test you mean it would be hard to tell the bryston nad rotel emotiva over the cheaper receivers unless you need a lot of power that the receivers can't do because of the small heat sinks?
Old 12-06-2012, 12:23 PM - Thread Starter
like mainly huge bass output that the small receivers can't do?
Old 12-06-2012, 12:24 PM - Thread Starter
when I heard a cheap aiwa bookshelf speaker hooked up to a 70s heath power amp and a optimus 5 cd changer that I tested it with I was amazed though. I never saw a aiwa speaker sound that good before on a small aiwa system.
Old 12-06-2012, 12:25 PM
XStanleyX's Avatar
Liked: 1269
That's what subwoofers are for.
Old 12-06-2012, 12:25 PM - Thread Starter
the people selling the amp didn't have speakers to hook it up to so i brought the aiwa speaker figuring if I blow it it doesn't matter.
Old 12-06-2012, 12:27 PM - Thread Starter
when i was a teen I remember big speakers and a few years later passive subs. now a lot of stuff is powered subs and smaller speakers. i saw some floor standing energy speakers a 10 inch energy sub and three small energy speakers at sears last night. I didn't know that they carried energy. I used to see them demo the cheap home theater in a box stuff only.
Old 12-06-2012, 12:38 PM - Thread Starter
I think that i will take your advice and stay away from the used nad from her stan.
Old 12-06-2012, 01:24 PM
Titan7170's Avatar
I think thats the metal reacting with the oils from the persons hands/fingers over time. And the tabs are not broken just pointing directly at the camera....its the angle and the tabs that look missing are closed!
Titan7170 is offline
Old 12-06-2012, 01:29 PM - Thread Starter
thanks for letting me know Titan. I decided to forget about the amp since some of the connectors are messed up. i would only be using it for stereo, but I worry that it won't even power on if i go to the trouble of trying to replace the connectors. I don't know what I am doing, so i might mess it up more trying to fix the connectors
Old 12-06-2012, 01:34 PM
Titan7170's Avatar
NP but as I look at the pic the speaker tabs are just closed, not broken I dont see anything broken on the back?
