Denon 1613 to PS3 using HDMI can only get 1080i video out on LED TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-06-2012, 09:00 PM - Thread Starter
wadehw's Avatar
Do you know how how to get a 1080p video?
If I connect the PS3 to LED TV using the same HDMI cable, I can get 1080p video right away. I have been trying this for 3 long nights frown.gif Please help
-Wade
wadehw is offline
post #2 of 11 Old 12-07-2012, 05:47 PM
Latinoheat's Avatar
Quoted: 1136 Post(s)
Liked: 927
What exactly are you trying to do? Are you getting 1080p on your PS3? Cable tv/ satellite is only 1080i/720p HD. You can't get 1080p from cable tv. If you have a new receiver you can upscale to 1080p but is not true 1080p video. It only makes the picture look better.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, HTPC, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC,Klipsch Reference R-62II,Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #3 of 11 Old 12-07-2012, 05:51 PM
jdsmoothie's Avatar
Quoted: 15085 Post(s)
Liked: 7277
There is no video card in the 1613, rather the resolution the source passes to the AVR is what should be passed to the TV. Check to make sure the "Deep Color Output" setting on the PS3 is set to OFF.
jdsmoothie is offline
post #4 of 11 Old 12-07-2012, 10:57 PM - Thread Starter
wadehw's Avatar
When I connect PS3 to LED TV via hdmi, I press a "Info" button, I can see that the video resolution is 1080P.
Then I purchased a Denon 1613. PS3 is now connected to 1613 via hdmi and 1613 connect to my led tv via hdmi too.
To my surprised, now the Staus screen shows that the video resolution becomes 1080i.
I did turn off Deep Color on PS3. It does improve. but still getting 1080i.
How can I get back to 1080p?
wadehw is offline
post #5 of 11 Old 12-08-2012, 09:34 PM - Thread Starter
wadehw's Avatar
Interesting. Denon used to have this issue...
http://www.avsforum.com/t/1176040/ps3-slim-to-denon-avr-4310-hdmi-problem
When I first connected PS3 to Denon 1613, the screen had obvious blue flash lines on the tv. The ways I fixed it is...
1). turn off Deep Color on ps3
2). use a 3 feet hdmi instead of a 6-foot one
It is much better now but I can get only 1080i now.
Based on the link above, seems that I got a defect 1613. I posted a question to Denon support. Hope I do not need to return it.
wadehw is offline
post #6 of 11 Old 12-09-2012, 03:30 AM
jdsmoothie's Avatar
Liked: 7277
I also posted the question in the Denon AVR-XX13 Owner's thread linked in my sig to see if any other 1613 owners can confirm whether this issue presents on their units as well.
post #7 of 11 Old 12-09-2012, 05:02 AM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
did you try resetting the video settings on the ps3?
w/ the ps3 off press and hold the power button until you hear the 2nd beep. that will reset the settings and you can re-select 1080p.
http://www.semperthree.com/resetVideo.html
My living room budget build: Samsung PN51E530 / Denon AVR1613 / DefTech PC1000 / DefTech PM60 / DefTech ProSub 60 / Dayton Sub1200
UGAd13 is offline
post #8 of 11 Old 12-10-2012, 10:57 PM - Thread Starter
wadehw's Avatar
I have tried...
1). set deep color to off on PS3(get rid of blue flash line issue but still can only get 1080i)
2). switch to different hdmi on back of denon 1613. no help. still 1080i
3). reset the Video setting by holding PS3 power until PS3 beeps. no help. Still 1080i
4). switch to different hdmi cable(bought from RadioShake) no help
wadehw is offline
post #9 of 11 Old 12-11-2012, 02:27 AM
jdsmoothie's Avatar
Liked: 7277
On the remote press SETUP --> INFORMATION ---> VIDEO. If under [Signal] it says 1080i, then that is what the AVR is receiving from the PS3 and that is what the AVR would pass on to the TV. In this case, the issue would be with the PS3.
post #10 of 11 Old 12-14-2012, 10:10 PM - Thread Starter
wadehw's Avatar
Originally Posted by wadehw View Post
I have tried...
Finally, resolved...
5). buy two AmazonBasic HDML(with Ethernet) cables... then it just works smile.gif
wadehw is offline
post #11 of 11 Old 12-15-2012, 01:24 AM
jdsmoothie's Avatar
Liked: 7277
Ah, so you were apparently using a "Standard" speed HDMI cable rather than a "High Speed" cable. Thanks for posting back, although note the additional "ethernet" feature capability is not required.
