Just got a Sony STR-DA5800ES - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #121 of 137 Old 01-21-2015, 04:34 PM
HDTVAV's Avatar
Quoted: 760 Post(s)
Liked: 343
Originally Posted by JimSatala77 View Post
They will eventually release a new flagship the new 3000es isn't a flagship but since they did an update of the 5800es to the 5800es2 a few months ago to get rid of the video streaming because they didn't have the proper licensing in place and had to pay a substantial fine , if they had something else in the pipe I would have thought they would have pulled it but I'm guessing that they are waiting on hdmi 2 / hdcp2.2 capabilities full implementation ...currently they are limited to a 4:2:2 chroma or something else less than full capacity
Looks pretty nice...
The webpage says it is 100 watts per channel... but that is at 6 ohms...
I guess it goes up to 110 watts per channel at 8 ohms...
Not quite the 130 watts per channel of the 5800 - but still looks nice.
HDTVAV is offline
post #122 of 137 Old 01-21-2015, 06:18 PM
JimSatala77's Avatar
Quoted: 396 Post(s)
Liked: 139
I think it's built to match up with their new High res speaker's that came out 6 months ago...all are 6ohm
JimSatala77 is offline
post #123 of 137 Old 03-09-2015, 07:18 AM
atbodamer's Avatar
Originally Posted by AYColumbia View Post
Quote:Originally Posted by Ryan1
One other thing is that the calibration will configure the levels based on the speaker size (frequencies determine this) so if the surrounds are determined to be large, then the levels are set based on that. I mention this because if the speaker size is changed manually, bass steering will occur which will then require further adjustment to the sub as bass from those speakers will be sent to the sub and fonts based on the crossover frequency set for the small size. Once I figured all this stuff out, I'm extremely happy with the results.
I just got one of these beasts. When I auto-calibrated, all my speakers came up as "large." Subsequently, I changed them all to "small" and adjusted the crossover settings to send to my powered sub. It doesn't appear there is a way to force calibration after the speakers have been manually set to "small." Any insights about how to re-calibrate would be appreciated.
atbodamer is offline
post #124 of 137 Old 04-03-2015, 07:33 AM
TheMiracle's Avatar
HI!
quick question, can anyone tell me if there is a large difference between 5300 ES and 5800 ES in sound quality, I read somewhere that after 5400 they had a sound quality issue on 5600 and 5700, is this true?, I have the ES line of speakers, and I couldn't be happier with sound quality of this match, but now im in need of 4k past through and the only Sony s doing it is 5800 ES and Z3000 ES, is it better to wait or the Next ES, that is possibly around the corner, or should I buy the 5800?
Max.-=
TheMiracle is offline
post #125 of 137 Old 04-12-2015, 11:26 PM
Elxan Aqayev's Avatar
Originally Posted by TheMiracle View Post
HI!
Max.-=
Hi !
I have this is STR-DA5800ES. And this is Fantastic Amplifier
https://c2.staticflickr.com/8/7343/1...73ef2adc_h.jpg
https://c4.staticflickr.com/8/7450/1...e7feff8b_h.jpg
https://c1.staticflickr.com/9/8729/1...05b167f5_b.jpg
Elxan Aqayev is offline
post #126 of 137 Old 04-12-2015, 11:30 PM
SONY STR-DA5800ES. Dolby Atmos.
post #127 of 137 Old 04-25-2015, 04:13 PM
Headspace's Avatar
Originally Posted by Elxan Aqayev View Post
There is no Atmos update available yet.
Headspace is offline
post #128 of 137 Old 04-25-2015, 04:43 PM
Headspace's Avatar
After calibration set it to small and be done with it is the only answer I have. I have been very pleased with manually tweaking everything. I'm glad I am! In my 7.1 set up I got the Code 34 error because my front height speakers are not mounted above my floorstanders and couldn't continue with the auto calibration. I have my heights placed directly on top of my Quartets and that's what works in my room. Funny I never ran into that problem before with YPAO or any other auto calibration.
The other niggle is you can't change the music and movie modes from the Sony remote. I have to manually change modes directly on the receiver. Thankfully I have my settings set for how I like them (DTS NEO X) for music and (Movie Height) for bluray so it isn't a huge deal.
No receiver I have ever owned has been perfect but I can say the STR-5800 has the best audio quality that I have heard to date. Better than all the other receivers and Yamaha RX-A1000 I last had and the Yamaha was no slouch. I find the Sony just has a really smooth sound to it with plenty of punch and dynamics. I am really happy with how it sounds and the bottom line for me is that's what counts!
camgrant84 likes this.
post #129 of 137 Old 04-28-2015, 07:55 PM
TheMiracle's Avatar
Ok, Im really happy with this receiver, I believe is a huge jump in technology, and features, really happy with my purchase, I will leave y 5300 to my secondary room, love the es line
Max.-
post #130 of 137 Old 06-02-2015, 12:11 PM
Headspace's Avatar
To change music & movie soundfields press the shift key first on the upper left hand corner then press the soundfield keys located on the bottom right hand corner of the remote. There's a small remote that comes with the European models that's not included with US models that simplifies a few functions. You can find it for sale on Ebay occasionally.
post #131 of 137 Old 06-15-2015, 07:49 AM
temitch's Avatar
Second Subwoofer Not Recognized
I've connected a second subwoofer to my STR-DA5800ES receiver and it is not being recognized. My speaker setup is now a 9.2 configuration. When I try to configure the speaker connection speaker pattern it doesn't show the option for 5/4.2 it only lets me select 5/4.1. Is this normal?
temitch is offline
post #132 of 137 Old 06-24-2015, 06:12 PM
unbiased's Avatar
Hello, I have a question to all you STR-DA5800ES owners. Does all your internet video streaming sources still work if you stay on the older firmware or did Sony disable and shut all the services down?
If you update the old STR-DA5800ES with Sony's latest software/firmware update, does it become exactly the same as the new STR-DA5800ES2 model? or are there some other differences between the old and new model (other than removing and disabling all the video streaming services)?
I just bought an STR-DA5800ES from ebay and wondering what to expect in regards to the ability to stream audio and video services from the internet connection.
I find it terrible that Sony has reneg'ed on providing the streaming functions like Shoutcast and Vtuner on their devices and especially for the ES line.
I have both an STR-DA4600ES and the STR-DA1040 mid-line receivers and they disabled both Shoutcast and Vtuner function on them. I think that is a BIG Mistake as it disappoints the heck out of me.
Words of wisdom, "The more you know, the more you know that you don't know."
unbiased is offline
post #133 of 137 Old 06-24-2015, 10:03 PM
philmike21's Avatar
Quoted: 57 Post(s)
Liked: 25
Cant believe Sony hasn't put out anything with Atmos yet. My buddy has the 5800es and I like it. Thing is loud and sounds good with his deftech speakers.
philmike21 is offline
post #134 of 137 Old 06-29-2015, 09:55 AM
unbiased's Avatar
Update:
All, nevermind, I was finally able to speak to a Sony ES Support rep and he said that the older software versions will no longer connect to the streaming services because they've changed the server addresses. You must install the latest firmware version 1062 in order to get the streaming connections back for older STR-DA5800ES models. So I updated my receiver and it now connects to all the streaming services what remains in them anyway. I am disappointed that they took away Vtuner support.
unbiased is offline
post #135 of 137 Old 09-14-2015, 01:39 PM
Quoted: 1020 Post(s)
Liked: 480
Anyone know when the a new Sony flagship AVR will come out to replace the STR-DA5800ES2?
While the newer Sony ES AVRs, like the 3000, are out I really would not consider them "flagship".
New24K is offline
post #136 of 137 Old 12-10-2015, 06:41 PM
Liked: 1
Hello everyone. New member here. I have the 5800es receiver here myself along with the new Sony 4K 950B TV. I recently added a 4K directv box. Somehow when the directv box is hooked up through a 4K input on the receiver my Tv says this device doesnt support 4k. Though when i hook up the directv box directly to the TV 4K input it works flawless. I have already updated all firmware on all devices. Is anyone having the same isuue here? I contacted Sony and they are no help,
SONYES1102 is offline
post #137 of 137 Old 02-02-2016, 04:05 AM
Quoted: 16 Post(s)
Liked: 6
Not sure if this will help since you're probably doing it already (and it may not even be relevant to your problem) but apparently only hdmi connections 1, 2 and 9 have 4K passthrough so if you're connecting through one of the other hdmi connections you might want to try changing to 1, 2 or 9 instead and see if that helps.
B-a-n-e is offline
