Need advice: best receiver/preprocessor/amp combination for $2500 or less - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-07-2012, 05:54 PM - Thread Starter
danpetit's Avatar
I need some advice. I am looking to purchase equipment for a new media room (movies and music both). I am having a hard time deciding between a single high end receiver (like the pioneer sc-68) and a good combination of separates.
Requirements: 7.1 capable. Must have 7.1 analog in. Solid power (5000 cubic foot room).
So, if you had $2500 to spend, what would you buy?
danpetit is offline
post #2 of 5 Old 12-08-2012, 01:45 AM
derrickdj1's Avatar
Quoted: 883 Post(s)
Liked: 593
The Pioneer is an excellent choice and it has preouts if you ever feel the need for more power. Multiple subs(large) will be needed for that much space. The subs will make or break the HT.
derrickdj1 is offline
post #3 of 5 Old 12-08-2012, 05:40 AM - Thread Starter
danpetit's Avatar
Thanks for the response. I am leaning towards the pioneer for simplicity. There is just so much out there in this price range in separates, I want to be sure I consider the options.
danpetit is offline
post #4 of 5 Old 12-16-2012, 08:38 PM
wes182's Avatar
Quoted: 51 Post(s)
Liked: 26
Is the $2500 just for your electronics or speakers too? If you haven't purchased your speakers yet then I'd recommend starting with those and building around. If you have purchased your speakers then what do you have and how many?
wes182 is offline
post #5 of 5 Old 12-17-2012, 03:49 PM - Thread Starter
danpetit's Avatar
That is just the amp/pre/pro or receiver. I am trying to decide between a combination of separates (totaling no more than 2500) or a receiver in the same price range.
danpetit is offline
