Denon 3312CI issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-09-2012, 05:38 PM - Thread Starter
heater8251's Avatar
When running my cable box through the receiver then to the TV it makes the picture terrible! Has anyone had this same issuer or have advice for me? Thanks. The receiver is the avr3312CI, Cisco DVR Box, Samsung 8000 series TV running all monster cables. Thanks in advance guys
heater8251 is offline
post #2 of 6 Old 12-10-2012, 04:10 AM
jdsmoothie's Avatar
Quoted: 12156 Post(s)
Liked: 5538
Cable/Sat boxes often have HDMI handshake (audio and video) issues when connected to an AVR and not directly to the TV. The best configuration is to connect the box HDMI directly to your TV with an optical cable from the box to the AVR for surround sound.
For more info on your new AVR, join us in the Denon AVR-XX12 Owner's thread linked in my sig, especially reviewing posts #3-6 in that thread.
jdsmoothie is online now
post #3 of 6 Old 02-15-2013, 12:33 PM
dta721's Avatar
Do you imply that if this is the only way to work around the issue, the 3312CI in question would need a firmware update to fix the HDMI handshake, or there is no firmware update for this model, thus the work around solution?!
I tried both "lower" but newer AVR models, 1613 and 1713, they both switched STB HDMI well, no problem. In addition, I can listen to Dolby Digital audio from an OTA HDTV by pressing "TV audio" button on the remote. The 1713 then turned on and play Cinema Prologic II nicely.
My point? such HDMI handshaking if experienced earlier, regardless of price/performance level AVRs (3312) has been fixed with later, lower price/performance AVRs. But this is a guess, at any rate!
dta721 is offline
post #4 of 6 Old 02-15-2013, 02:23 PM
Selden Ball's Avatar
Quoted: 3075 Post(s)
Liked: 1504
The problem varies depending on the model of the DVR, or cable or satellite decoder box. Some work fine. Others do not. And some that used to work stop working after an update. Note that it's generally not a problem caused by the receiver, but rather that the code in the DVR, cable or satellite decoder has problems when connected to an HDMI repeater as is provided by AVRs.
Selden
Selden Ball is offline
post #5 of 6 Old 02-15-2013, 05:17 PM
jdsmoothie's Avatar
Liked: 5538
This issue lies with the cable/sat boxes as they are generally not HDCP certified, so if there is any firmware update it would have to come from the cable/sat provider (which in some cases is indeed available upon request).
post #6 of 6 Old 02-16-2013, 08:58 AM
dta721's Avatar
I understand your point. However -playing the devil advocate's role, how would one explain Denon's firmware update to resolve the issue with Pandora in Dec 2012? What changes in the AVR's firmware to fix the issue with Pandora? Is it related to HDMI, HDCP compliant? Thanks!
dta721 is offline
Denon Avr3312ci Receiver
