need help on receiver ideas/way to power multiple zones - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-11-2012, 09:17 AM - Thread Starter
brodeur78's Avatar
Apologize for being super amateur at this...here is what I'd like to do:
I would like to run a 2 zone receiver where I can watch TV/etc in one zone and the second zone will be outdoor speakers (thinking 9 or 10 speakers). Thinking polk atrium 5 for outside (they will be all around the house, maybe 5 around the pool and 5 in other areas). The interior will just be something like a 5 speaker surround system (polk I'm guessing)....
for the receiver, I am thinking the Denon AVR-3313CI....
I think I set the outdoor speakers up to Zone 2 but I'm guessing I need both another amp and a speaker selector for the outdoor speakers?...I would like to be able to turn on/off outdoor zones so I think i need the speaker selector...I also dont think the Denon can power all the outdoor speakers on zone 2 as well?...Im guessing a basic amp for outdoor plugged into the zone 2 of the Denon?
I really appreciate any help/thoughts/ideas on all of this...
also...on the outdoor speakers, how do you set zone 2 to be "stereo" to all speakers? I dont think I will have "left" and "right" speakers outside??...
I have a basic idea of items needed but it is hard to conceptualize how this will work...
thanks so much for any help...sorry for the lack of knowledge!!!
brodeur78 is offline
post #2 of 12 Old 12-11-2012, 09:36 AM
NorCalJason's Avatar
Liked: 30
Yes, the Denon can send a stereo (2 channel) signal to your additional zone. I can even power that (2) channel zone.
But since you have many speakers, you have a variety of ways to accomplish this task.
The most simple is using a device like this:
http://www.abt.com/product/4099/Sonance-91368.html?utm_source=scfroogle&utm_medium=sc&utm_campaign=SS4&adtype=pla
NorCalJason is offline
post #3 of 12 Old 12-11-2012, 04:12 PM - Thread Starter
brodeur78's Avatar
does the denon have the power to do a zone 1 (lets say 5.1) and 10 outdoor zone 2 speakers?.....I figured I would need another amp for zone 2 which will go in the pre-out zone2 on the denon with a speaker selector
post #4 of 12 Old 12-11-2012, 04:20 PM
afrogt's Avatar
Quoted: 1416 Post(s)
Liked: 972
No, no receiver would have that capability to power 10 zone 2 speakers. You'll need some kind of speaker selector to deal with that many speakers.
Afro GT
afrogt is offline
post #5 of 12 Old 12-11-2012, 04:27 PM - Thread Starter
brodeur78's Avatar
yeah but do i need a separate amp for zone2 which is connected to the zone 2 pre-out and the speaker selector? (so speakers ----> speaker selector ----> amp 2 ----> denon 3313) ?
if that's correct, any ideas on a speaker selector and the 2nd amp (brand/model?)....looking for maybe 4 zones of speakers outdoors for the speaker selector....
post #6 of 12 Old 12-11-2012, 04:39 PM
Liked: 30
No...
Zone2 speaker outputs ---> speaker selector ---> speakers
Any quality speaker selector will manage the load of the speakers connected to it, so that it doesn't demand more from your amp than it should.
The selector I linked above does this.
Alternatively, you could go a different route:
Zone2 rca outputs ---> amplifier ----> speakers
There are amps made for this type of installation. They're made to work with very low ohm loads, and are very rugged. Here's an example: http://sonance.com/products/electronics/detail/233
Or even:
Zone2 rca outputs ----> amplifier with built in speaker selector ----> speakers
This amp is 3 separate sets of speaker terminals, with 3 speaker selectors: http://sonance.com/products/electronics/detail/234
post #7 of 12 Old 12-11-2012, 04:55 PM
jdsmoothie's Avatar
Quoted: 15094 Post(s)
Liked: 7286
Yes, you will indeed require an external map for the Zone 2 speakers. Consider the following amp (background music volume level only) and speaker selector.
http://www.amazon.com/AudioSource-Amp-200-High-Current-Amplifier/dp/B0006VHZHO/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355273571&sr=1-1&keywords=AMP-200
http://www.monoprice.com/products/product.asp?seq=1&format=2&p_id=8232&CAWELAID=1329456295&cagpspn=pla&gclid=CLOcsfTTk7QCFQGFnQodeHcAzA
jdsmoothie is online now
post #8 of 12 Old 12-11-2012, 05:15 PM - Thread Starter
brodeur78's Avatar
thank you guys very much for the help - sorry, new to some of this stuff....have just had basic home theater items before
post #9 of 12 Old 12-11-2012, 05:18 PM - Thread Starter
brodeur78's Avatar
one last ? --- are there any electronic speaker selectors that would work with a universal remote? (click one button to turn on music only at the pool, etc)....or are they all mechanical push button
post #10 of 12 Old 12-13-2012, 09:05 AM - Thread Starter
brodeur78's Avatar
so if the external speakers are attached to this speaker selector for instance:
http://www.outdoorspeakerdepot.com/7-pair-speaker-selector-with-remote-control.html
How would they go from the speaker selector to the Denon 3313CI? is it speaker wire out to speaker wire in on the 3313CI? zone 2 on the 3313ci is just hdmi or rca out for zone 2, no??
and last question (I promise, I think)
does the 3313ci have sufficient power to power all 9 exterior speakers as well as the 5-6 interior speakers on zone1
thanks guys....
post #11 of 12 Old 12-13-2012, 09:26 AM
Liked: 30
thanks guys....
That selector is fine, if you're only going to run 1 set of speakers at a time.
The challenge with running multiple sets of speakers off the same speaker-level connection is - Impedance. 2 8ohm speakers = 8 ohm impedance. 4 8ohm speakers = 4ohm impedance. 6 8ohm speakers = 2ohm impedance.
Your receiver isn't going to be happy pushing anything less than 4-6ohms, especially when driving an additional 5+ speakers in your main listening room.
Honestly, home-distributed audio is something that should be left to experienced DIY-ers, or professionals. You might want to contact a custom installer in your area.
post #12 of 12 Old 12-13-2012, 09:46 AM - Thread Starter
brodeur78's Avatar
sorry...trying to do it for relatively cheap (~2-3k for the outdoor speakers and receiver setup)....maybe I will call someone, fair enough..
