Quick question about PCM from Windows - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-11-2012, 10:58 PM - Thread Starter
jonainpdx's Avatar
I have a 5.1 speaker system and a nice little Denon Receiver pushing them along. There is a crossover freq available for all the speakers, which are all set to 80Hz.
(If that doesn't sound right let me know)
Everything is Polk. 4 Monitor 30's and a matching center and the PSW 10 Sub.
So anyhow onto Windows 7. The only thing going to my souround system is my Windows 7 HTPC. With two options for output to the suround system. HDMI or SPDIF off of my X-Fi HD card that encodes in DD for gaming.
So my question is, being that all my speakers are set to Small and everthing set to 80Hz CO on my Denon, should I leave my Win7 speaker setting to large? Are there any other optimum settings I should consider?
BD movies do sound amazing already, but...... I just want to make sure I'm not missing anything.
Thanks for reading
Asus Maximus IV GeneZ--i5 2500K @ 4.2Ghz-8Gb Corsair 1.5v 9-9-9-243x --Intel x25m 80Gb & Corsair GT 240Gb--GTX780by Evga-- Corsair AX 850 PSU--Denon AVR x1000--Asus PB278Q monitor
jonainpdx is offline
post #2 of 14 Old 12-11-2012, 11:14 PM
Dimethios's Avatar
Yes, leave it at large, your Denon will adjust the crossovers accordingly and send the bass to the lfe channel. No other settings to optimize either, your doing it correctly. smile.gif
jonainpdx likes this.
Dimethios is offline
post #3 of 14 Old 12-12-2012, 06:14 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Dimethios is right - from a Windows perspective your surround system should be configured as a 5.0 system with all of its speakers set to large and no subwoofer. That leaves the bass management up to the AVR which is the right place to do it.
arnyk is offline
post #4 of 14 Old 12-12-2012, 06:36 AM
Theresa's Avatar
Liked: 51
I thought that all should be set to large and subwoofer should be selected as present. I will try it the way you suggest as I am not satisfied with my subs output when outputting from Windows via HDMI.
Thank you..
Theresa is offline
post #5 of 14 Old 12-12-2012, 10:09 AM
Ross Ridge's Avatar
Liked: 81
I'd configure Windows with the subwoofer present. Otherwise it might end up mixing the LFE channel into the other channels.
Ross Ridge is offline
post #6 of 14 Old 12-12-2012, 12:43 PM - Thread Starter
jonainpdx's Avatar
I haven't even thought of the LFE channel. I'll have to play with it in Windows and see if I can tell a difference.
How about the bit rate setting on the advanced tap of the speaker setting? Does that make any difference?
post #7 of 14 Old 12-12-2012, 03:36 PM
Theresa's Avatar
Liked: 51
I tried both with sub selected and deselected and with it deselected there is significantly less bass than when selected.
Theresa is offline
post #8 of 14 Old 12-12-2012, 05:26 PM - Thread Starter
jonainpdx's Avatar
Hmm when I switch it back and forth I can't tell any difference, on a bass heavy sound too.
post #9 of 14 Old 12-12-2012, 06:02 PM
jdsmoothie's Avatar
Quoted: 12242 Post(s)
Liked: 5576
What Denon AVR are you using as Audyssey will set the correct crossovers for you speakers?
jdsmoothie is offline
post #10 of 14 Old 12-12-2012, 06:02 PM
jdsmoothie's Avatar
Liked: 5576
post #11 of 14 Old 12-13-2012, 10:25 AM - Thread Starter
jonainpdx's Avatar
Actually I don't have Audyssey. It's the AVR 1513. But the crossover freq on the reciever is of no mystery, 80Hz is clearly where it's at for all my speakers. And I have plenty of bass, esp given the fact that I live in an apartment, I have to be carefull at night.
My main focus has been at this piont, as to what settings to set inside Windows 7. Sending a full unmolested signal by setting my speakers in Win7 to "Full Range" makes sence to me though. While playing music, setting the speaker config in Win7 from 5 vs. 5.1 however does not seem to have any consiquence either way. I think the reciever is handeling all the crossover processing.
post #12 of 14 Old 12-13-2012, 06:03 PM
jdsmoothie's Avatar
Liked: 5576
When you're ready to upgrade your audio listening experience, upgrade to an Audyssey model. wink.gif
post #13 of 14 Old 12-15-2012, 01:43 AM - Thread Starter
jonainpdx's Avatar
What does Audyssy do for me?
post #14 of 14 Old 12-15-2012, 02:07 AM
jdsmoothie's Avatar
Liked: 5576
