Dolby or DTS priority? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-12-2012, 06:06 PM - Thread Starter
chrisinvan's Avatar
Does anyone know the technical aspects of decode priority when multiple mixes
are available?
For content offered in both DTS and Dolby mixes, I've been wondering which of the two formats the player or receiver chooses to decode and deliver as LPCM. By default it seems to choose DTS HD-MA (the best available) with my BR discs, but in scenarios where the disc contains regular DD and DTS, it could choose either. Is this encoded onto the discs (soundtrack priority) or does the hardware make the decision?
chrisinvan is offline
post #2 of 10 Old 12-13-2012, 01:30 AM
Roger Dressler's Avatar
Quoted: 1526 Post(s)
Liked: 715
It does not depend on the receiver. The disc authoring defines the behavior, after the basic capabilities of the receiver are known to the player via HDMI communication.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #3 of 10 Old 12-13-2012, 02:40 AM - Thread Starter
chrisinvan's Avatar
So it's defined at the source - thanks Roger. Though I wish my receiver would allow me to switch - in my setup the player (the PS3) seems to only send one to the receiver - my options are limited to Dolby OR DTS, Stereo, multi-channel stereo, etc. But I can't toggle between Dolby and DTS on the receiver, even in cases where I know the disc contains both.
Any idea if it's possible?
post #4 of 10 Old 12-13-2012, 04:13 AM
ccotenj's Avatar
Liked: 101
you would select which one you want from the disk menu when you start the movie...
the avr (any avr, ftm) will never be involved in this choice...
- chris
ccotenj is offline
post #5 of 10 Old 12-13-2012, 05:08 AM
HFXguy's Avatar
Doesn't the PS3's remote have an audio button on it?
HFXguy is offline
post #6 of 10 Old 12-13-2012, 04:29 PM - Thread Starter
chrisinvan's Avatar
On the PS3 it's possible to force DTS if you disable Dolby in the audio settings, but this requires stopping the program (or BluRay) - a little awkward. It would be nice to be able to switch on the fly, to make a decision about what sounds best for a particular source. PS3 software and the system software itself seems to prefer Dolby (if both Dolby and DTS are turned on in the settings, it always chooses Dolby). And if mult-channel LPCM is available it will choose that.
Some sources (movies for example) let you choose the format in the settings. Other times, both DTS and Dolby are present, but there isn't a menu option anywhere.
post #7 of 10 Old 12-13-2012, 05:17 PM
Ross Ridge's Avatar
Liked: 81
If pressing the triangle button and then selecting Audio Options doesn't give you the option of switching between Dolby Digital or DTS soundtracks then your only other option is to force the PlayStation 3 to use DTS in the audio settings as you described.
Ross Ridge is offline
post #8 of 10 Old 12-14-2012, 09:19 AM
HFXguy's Avatar
I see that it does have an audio button on the remote. For my own interest does it work like every other remote,(that I have seen), and it toggles through all available audio options?
HFXguy is offline
post #9 of 10 Old 12-14-2012, 12:54 PM - Thread Starter
chrisinvan's Avatar
HFX, PS3 remote is sold separately but I do have one. I'll check that out today and post findings...
post #10 of 10 Old 12-14-2012, 02:21 PM
Steve S's Avatar
Liked: 46
Yes. It toggles through all available audio options encoded on the disc. while toggling, the onscreen display at the lower left corner of the screen only shows what language is used on the particular soundtrack, not the format it's recorded in. for that info you need to hit the "display" button. I've also found when toggling with the audio button that some soundtrack selections don't have anything recorded on them.
Steve S.
Steve S is offline
