which of these 3 receivers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-12-2012, 06:15 PM - Thread Starter
John Hudson's Avatar
John Hudson is offline
post #2 of 7 Old 12-12-2012, 08:17 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4781
Kinda hard for people to tell you what's best without knowing what features you want/are important to you in your avr. What's your budget? What speakers do you have? HT or music? Connectivity needs? etc...
lovinthehd is offline
post #3 of 7 Old 12-13-2012, 04:53 AM - Thread Starter
I currently have a blu-ray HTIB. I am slowly going to be piecing together a nicer home theater with larger speakers and separate components, starting with a/v receiver. needs are really only HDMI switching, at least 3 inputs. no need for any wattage requirements most likely, dont care about 3D or anything like that.
post #4 of 7 Old 12-13-2012, 05:44 AM
bargugl's Avatar
Quoted: 58 Post(s)
Liked: 58
These are all barebones receivers and it sounds like you have very modest requirements. None of them would knock your socks off, but given the choice of these three, I would probably take the Yamaha because Yamaha's reputation of reliability is superior to the others. However, I will also suggest you take a look at a refurb Denon AVR-1612 from accessories4less. The Audyssey Multieq room correction package in it may be something you find worthwhile to improve the sound.
bargugl is offline
post #5 of 7 Old 12-13-2012, 05:53 AM - Thread Starter
post #6 of 7 Old 12-13-2012, 05:55 AM - Thread Starter
oh, wrong one. still good price though!
post #7 of 7 Old 12-13-2012, 06:16 AM
bargugl's Avatar
Quoted: 58 Post(s)
Liked: 58
The Denon 1513 you linked lacks the Audyssey room EQ so I would really step up to the 1612.
bargugl is offline
