AVR 1650 EZset/eq - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-13-2012, 04:19 AM - Thread Starter
darkuth123's Avatar
I recently bought the AVR 1650 but It wont let me finish the set up when using the ezset/eq. I do have only a 2 channel set up atm just the front and right speakers...it just continually searches for all of the other speakers which I dont have and never finishes the set up. Any help would be appreciated.
darkuth123 is offline
post #2 of 5 Old 12-13-2012, 03:59 PM
Kini62's Avatar
Quoted: 1743 Post(s)
Liked: 1557
Only works in surround 5.0 or 5.1.
Just manually set your distance, about the only setting needed since you have no sub.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #3 of 5 Old 12-13-2012, 04:33 PM
M Code's Avatar
Quoted: 815 Post(s)
Liked: 499
In the OSD menu under Speaker Select set:
  • Center Speaker OFF
  • L/R Surround Speakers OFF
M Code is offline
post #4 of 5 Old 12-13-2012, 06:28 PM
Kini62's Avatar
Liked: 1557
It still wouldn't run for me when I had a 2.1 setup with those settings.
Def Tech SC8000
Kini62 is offline
post #5 of 5 Old 12-13-2012, 06:35 PM
M Code's Avatar
Quoted: 815 Post(s)
Liked: 499
EZ Set won't, only programmed for 5.1...
Those settings were advised so that the DSP can handle 5.1 source material and downmix properly.
M Code is offline
