Input on a Harman/Kardon Reciver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-13-2012, 07:51 AM - Thread Starter
slickmastajay's Avatar
I found a Harmon Kardon AvR1700 for 299.99. What do you guys think about this reciever for music mostly and does it do 2.1?
Music to movie ratio is 80/20 and will most likely be paired with either wharfedale diamond 10.1 or wharfedale evo2-20 and an hsu vtf2-mk4.
This will be in a 15
slickmastajay is offline
post #2 of 6 Old 12-13-2012, 08:34 AM
bargugl's Avatar
Quoted: 13 Post(s)
Just about any receiver will do 2.1. The 1700 already has been as low as $250 already so I have to think it will drop to that again. First of all, you need to tell us what features are important to you. Do you want networking, ipod connection, is room EQ important to you, etc? There may be other options to look at for a similar price.
bargugl is offline
post #3 of 6 Old 12-13-2012, 09:11 AM - Thread Starter
Music is the main thing for me. Id like a reciever with
-room eq
-5.1
-less than 0.1% THD (??? Is there audible difference between 0.9% and 0.1%?)
-at least 90wpc
-multiple hdmi ports with audio
-aesthetically pleasing
-reliable
-bluetooth (if possible)
- under 349.99 shipped/tax included
Sent from my SGH-T889 using Tapatalk 2
post #4 of 6 Old 12-13-2012, 03:28 PM - Thread Starter
So harmon kardon avr 1700 @299 or yamaha RX-V473BL @349??
Sent from my SGH-T889 aka "Galaxy Note 2" running the Force v6.1 using Tapatalk 2
post #5 of 6 Old 12-14-2012, 09:55 AM
bargugl's Avatar
Quoted: 13 Post(s)
Probably not going to be a significant performance difference between the two so just pick the one whose features seem to match your needs more. I will say that the 1700 is pretty much an all new design so there is less of a track record on reliability while Yamaha is generally considered to be the most reliable of the receiver brands. You should also make sure to check out the options Denon has.
bargugl is offline
post #6 of 6 Old 12-14-2012, 11:28 AM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
If you have a Fry's electronics close by they have the HK 1700 for $249 starting today.
http://www.frys.com/ads/audio-video-television-cameras-portable-car-electronics
Afro GT
afrogt is offline
