Onkyo TX-NR1010 or TX-NR3010? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-13-2012, 09:50 PM - Thread Starter
lorneth1's Avatar
Alright everyone I've been reading a lot of post about different AVRs and I decided to narrow my selection to these two receivers; the NR-1010 and the NR-3010. To be prank, i'm in such a dilemma right now on which to upgrade to. I don't mind spending the $400 that if its justified. I just need everyone's input or at least majority of our resident experts:) Any help is appreciated.
My current setup are as follows:
Onkyo SR-805
Elemental Designs A5-350
Polk Rtia9s/7s
Polk Fxia4
Polk Csia6
Emotiva XPA-5
lorneth1 is offline
post #2 of 7 Old 12-13-2012, 11:12 PM
nismo604's Avatar
Do you plan on going 11.2? If not just get the 1010. Aside from that the main difference I see is that the 3010 has two more amps and has independent power supplies.
nismo604 is offline
post #3 of 7 Old 12-13-2012, 11:26 PM - Thread Starter
lorneth1's Avatar
Thanks for your input. In the meantime I would go 9.2 (wides) a few years maybe 11 but not anytime soon. And yes, I'm wondering how much those independent power supplies make a difference with sound and or overall fidelity. Granted I have an XPA-5 to power my front stage and the rears will solely be handled by either what I pick. More inputs? Tnx!
lorneth1 is offline
post #4 of 7 Old 12-18-2012, 09:26 AM
cybrsage's Avatar
Liked: 154
If you are not going to do 11 for a few years, get the 1010 now. In a few years, replace it with the newest technology. smile.gif
cybrsage is offline
post #5 of 7 Old 12-19-2012, 09:16 AM - Thread Starter
lorneth1's Avatar
I was just about to reply to your message in the 3010/5010 thread. Yes, I would have the setup for 9.2 and have to say 2 yrs for the heights and going wides right now. The thing is that I would have to keep this one for at least 5 years maybe more rolleyes.gif I've been on the fence with this one for the past few months and just waiting to reach the price to about 1500. Although I would like your idea of replacing it in a few years but it will be a tough sell to the other half biggrin.gif I'm just trying to find a compromise price between 1010 and 3010. Thanks for the input and more is appreciated.
lorneth1 is offline
post #6 of 7 Old 12-19-2012, 09:18 AM - Thread Starter
lorneth1's Avatar
How much factor those independent power supplies provide anyway? Kinda learning that right now if it makes huge difference or not.
lorneth1 is offline
post #7 of 7 Old 01-17-2013, 09:54 AM
SJSJ's Avatar
Here are a few beefs I have with the TR-NR1010s:
If you connect an iPod or iPhone to the USB port, no sound will be output from the headphones jack.
I don't like that restriction!
Also, the "Whole House Mode" only supports analog audio.
I don't like that if I'm using HDMI out on Zone 2!
Not enough speaker terminals, for example:
* If the “Speakers Type(Front)” setting is set to “Bi-Amp” or “Digital Crossover”, Powered Zone 2 cannot be used.
* When the “Powered Zone 2” setting is set to “Yes” and Zone 2 is turned on, the surround back and front high speakers cannot be used.
* When the “Powered Zone 3” setting is set to “Yes” and Zone 3 is turned on, the surround speakers cannot be used.
* IntelliVolume does not work for Zone 2/3.
*The Auto Standby function does not work when Zone 2/3 is on.
*Much heavier than other AVRs: 50.7 lbs (23.0 kg) compared to Denon @ 3313CI 26.5lbs, Pioneer SC-67 @ 38.4 lbs, Yamaha RX-A2020 @ 37.7 lbs
One thing that is nice is that the Main zone and Zone 2 can listen to different AM/FM radio stations at the same time.
SJSJ is offline
