Help with Denon 1713 AVR. - AVS Forum | Home Theater Discussions And Reviews
Old 12-15-2012, 04:04 AM - Thread Starter
raptor89's Avatar
Hi all. Purchased this AVR yesterday and cannot output 1080p via the xbox only 1080i. Its really fustrating me now, have swapped HDMI's cables and ports but still unable, changed alot of settings on xbox and AVR still the same. Any ideas on fixing this would be highly appriciated. Another issue is with my cable box which only outputs DD 5.1 via Optical and not HDMI, I have plugged both in and set the digital resource to Optical, but still only outputting in Dolby PL 2. Apart from this everything is ok. But if I dont get these issues fixed soon i think I may have to return it.
raptor89 is offline
Old 12-15-2012, 08:57 AM
afrogt's Avatar
Quoted: 1090 Post(s)
Liked: 782
1. Press Setup
2. Video
3. HDMI Setup
4. Make sure HDMI audio out is set to AVR
I use a Denon 1613 and get Dolby Digital from my satellite receiver with no problem.
the first part of your sentence states you get dd 5.1 via optical. But the second says you only get Dolby PL2 via optical. Which is correct?
Could also be your cable box audio output setting is not correct.
Afro GT
afrogt is online now
Denon Avr 1713 Receiver
