Can't upgrade audio receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-15-2012, 07:18 AM - Thread Starter
n3vino's Avatar
I have an older Kenwood Prologic receiver which still works good. I looked into upgrading to a receiver with Blue Ray technology, but I can't find anything at a resonable price that can handle my 4ohm Cerwin Vega Speakers. They are my front speakers which also act as subwoofers. Most receivers only handle 6 ohms and above. Buying a receiver and two front speakers plus a subwoofer will be pretty expensive. Plus I don't want to get rid of my Cerwin Vegas. I don't want to break the bank since I am now retired. Any suggestions?
n3vino is offline
post #2 of 5 Old 12-15-2012, 07:29 AM
bargugl's Avatar
Quoted: 13 Post(s)
There are many receivers that can handle 4-ohms but the manufacturer just doesn't rate them as such, particularly for the US market. Unless those speakers are particularly hard to drive, there are probably several options available to you. What is your budget and what type of features are you looking for? Can your provide some specs on those speakers?
bargugl is offline
post #3 of 5 Old 12-15-2012, 07:55 AM
jdsmoothie's Avatar
Quoted: 12182 Post(s)
Liked: 5549
Also keep in mind that most AVRs can handle 4-ohm speakers at reasonable levels (eg. -30db from reference 0db level). Where it gets iffy is when you approach reference level (ie. 0db) volume. eek.gif
jdsmoothie is offline
post #4 of 5 Old 12-15-2012, 09:28 AM - Thread Starter
n3vino's Avatar
Thanks for your responses. I don't want to spend over $500.00 on an audio receiver. The specs are Cerwin Vega VS120, 3 way with 12", 4", and 1" tweeter, 5/200 watts, 4 ohm. I use them in my living room on stereo for music and prologic for DVD, Blueray, and Netflix. For music, I power them up high, but not to the point where it breaks my ears, but healthy enough to get a good sound. For stereo, I do use an external equalizer. For prologic, I don't use the equalizer since there is a problem with one of the channels. I don't know if it's the equalizer or the receiver.
n3vino is offline
post #5 of 5 Old 12-15-2012, 09:31 AM
jdsmoothie's Avatar
Liked: 5549
At those louder volumes, you'll likely have to find an older upper level model that can handle the 4-ohm load much easier.
