Noob question Yahama RX-V373 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-18-2012, 03:49 PM - Thread Starter
Doebeck's Avatar
Hey I just bought this receiver from Dell along with the Pinnacle MB10000. This is my first set up and I was wondering if it is possible to play music out of the USB while playing video out of HDMI 1?
Thanks, Alex
Doebeck is offline
post #2 of 7 Old 12-18-2012, 03:52 PM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 972
No, because you probably cant assign the USB port to an HDMI input.
If you want to do things like that it is probably best to run your source directly to the TV for video. The you can use whatever input you want on the receiver for audio.
Afro GT
afrogt is offline
post #3 of 7 Old 12-18-2012, 03:56 PM - Thread Starter
Doebeck's Avatar
Thank you for the fast reply, just wanted to check because I usually listen to music while playing video games but use the xbox for Netflix too so I was seeing if I had to switch it every time.
Doebeck is offline
post #4 of 7 Old 12-18-2012, 04:03 PM
afrogt's Avatar
Liked: 972
I would connect the Xbox directly to the TV for video and then run an optical cable from the Xbox to the receiver for audio for the times you actually want to hear your games..
Afro GT
afrogt is offline
post #5 of 7 Old 12-18-2012, 04:24 PM - Thread Starter
Doebeck's Avatar
I don't think the xbox has a hole for the optical imput.
Doebeck is offline
post #6 of 7 Old 12-18-2012, 04:26 PM
afrogt's Avatar
Liked: 972
Aren't there several versions of Xbox? Which one do you have?
Afro GT
afrogt is offline
post #7 of 7 Old 12-18-2012, 04:27 PM - Thread Starter
Doebeck's Avatar
360 Elite
Doebeck is offline
Yamaha Rx V373 5 1 Channel Av Receiver
