Upgrade from 3806 to 4311CI and now with major surround speaker issues! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-18-2012, 08:43 PM - Thread Starter
jbutler1959's Avatar
Hello everyone. I just upgraded my 3806 to a 4311CI and found that the 4311CI does not support an additional pair of surround speakers.
The theater room consists of 9 speakers, Front right and left with a center, right and left Surround A for the 1st row, right and left Surround B for the 2nd row, and finally 2 Surround rear speakers along with a subwoofer.
The 3806 had jacks for Surround A and Surround B but the 4311CI has jacks only for right and left Surround, as well as Height and Width jacks which I do not have speakers for. The speakers are installed into the wall and cannot be moved.
I would definately like Surround for the 1st and 2nd row seating. How do I accomplish this? The manual is not clear at all. No surprise given my experience with the 3806 manual I expected no different.
So any experts please advise! I appreciate any information you can give me.
Have a great day!
jbutler1959 is offline
post #2 of 4 Old 12-19-2012, 03:34 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
Although a set of Surr B speaker posts was provided on the 3806, they were simply connected in parallel. So just connect them in parallel to the single set of Surr speaker posts on the 4311CI.
jdsmoothie is offline
post #3 of 4 Old 12-19-2012, 10:23 AM - Thread Starter
I am new to this so please excuse my ignorance. How do I accomplish that? Any links I could reference?
I have 12-2 gauge speaker wires and at the ends banana plugs. Do i combine 2 left surrounds and 2 right surrounds into 1 banana plug each? Do I have to worry about the impedence or overheating my 4311ci? Any special settings in the setup or should I just do auto setup as usual?
Thanks again for your help!
post #4 of 4 Old 12-19-2012, 06:24 PM
jdsmoothie's Avatar
Liked: 5502
Correct. As the diagram above shows ... wire the two "+" cables together and the two "-" cables from the SL(A) and SL(B) speakers together and connect the combined "+" cable to the SL "+" speaker post and the combined "-" cable to the SL "-" speaker post on the AVR. Do the same with the SR(A) and SR(B) speaker wires and connect the combined cables to the SR +/- speaker posts on the AVR. Although the impedance of each of the 4 speakers will be reduced to 4-ohm (if originally 8-ohm speakers), not only do the side surrounds generally not draw much power, but the 4311CI is more than capable of handling 4-ohm speakers. Run AUTO SETUP as you normally would.
