Pre Amp under $1300 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 12-19-2012, 12:11 PM - Thread Starter
BartholomewR04's Avatar
I am in search of a great sounding processor under $1300 and would like some input/advice on the "best bang for buck" in this price range. I have considered the Outlaw 975 and the Marantz 7005. But I am really liking the price tag on the Outlaw. Is there anything in this price range that is going to give me an obvious improvement in sound quality over the Outlaw?
Thanks guys,
Joe
BartholomewR04 is offline
post #2 of 19 Old 12-19-2012, 12:24 PM
LVS
LVS's Avatar
Check out the preamps from Emotiva.
http://shop.emotiva.com/collections/processors
LVS is offline
post #3 of 19 Old 12-19-2012, 01:50 PM - Thread Starter
Thanks LVS, I will look into it. Any other recommendations?
post #4 of 19 Old 12-19-2012, 02:15 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
What do you find in these devices that you can't find in an AVR for half the price?
arnyk is offline
post #5 of 19 Old 12-19-2012, 02:29 PM - Thread Starter
Heck, I don't really know.. After researching it seemed that many home theater enthusiast went with separate components. I just assumed the audio quality was potentially better this way. I am fairly new to this but I want optimal sound on a budget. I'm trying to keep the processor and amp under $2000, but ideally around $1500. Any suggestions?
post #6 of 19 Old 12-19-2012, 02:34 PM
BentZero's Avatar
I'm in the same exact boat. I've kind of landed on the Denon 4311 for now. It seems like it's a very capable AVR and can be used as a pre-processor when I decide to go with separates for my front channels while still using the 4311 for my surround channels.
BentZero is offline
post #7 of 19 Old 12-19-2012, 02:40 PM - Thread Starter
I am currently using 2 RF-3 towers, 2 RS-3 surrounds, and 1 RC-3 center. Wanting to upgrade to a full 7 speaker system however. I would like around 125 watts RMS x 7 if this helps with recommendations?
Bent zero- thanks for the recommendation. I will look into the denon.
post #8 of 19 Old 12-19-2012, 03:13 PM - Thread Starter
I will primarily be using for home theater purposes (MOVIES). And also for cable TV/Sports. Not sure if this helps with recommendations.
post #9 of 19 Old 12-19-2012, 04:19 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
I landed on the 4311 as well--what a fantastic AVR.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
post #10 of 19 Old 12-19-2012, 04:38 PM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
I'm going to hop on the bandwagon and recommend the Denon AVR-4311. Run it as is and if you need a separate amp, add an Emotiva XPA-3 for your front three channels and run the remainder off the Denon. If not, you've just saved yourself some money and real estate in your equipment rack/shelf as well as cabling hassles.
duc135 is offline
post #11 of 19 Old 12-19-2012, 04:51 PM
Bill Mac's Avatar
Quoted: 1263 Post(s)
Liked: 1440
I have the 4311 which I'm using as a prepro as well. If one wants a dedicated prepro I understand that as I used feel that was the best route to take. But after owning the 4311 for about six months I see no disadvantage of using an AVR as a prepro. The talk of added heat or electronic interference of an all in one box solution is all BS if you ask me wink.gif. I doubt very much anyone could pickout the SQ differences between the Onkyo 5009 (AVR used as a prepro) and the Onkyo 5509 (prepro). So I strongly recommend the 4311 as well. The upside is if your amp craps out you still can use your system. But with a prepro if your amp craps out you are out of commission wink.gif.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #12 of 19 Old 12-19-2012, 05:24 PM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
Bill
While these statements may be true I don't see a point in buying a separate amp just so you can use an AVR as a pre-pro unless you already have an amp or the AVR doesn't have sufficient power for your requirements. OP said he needs 125Wx7. The 4311 is 140Wx9 if you believe Denon marketing. Not sure what real world testing has proven though. I think the OP should just get the 4311 sans external amp and give it a shot first.
duc135 is offline
post #13 of 19 Old 12-19-2012, 06:06 PM
Bill Mac's Avatar
Liked: 1440
I recommended the 4311 as a prepro as the OP is looking at the Outlaw 975 and the Marantz 7005 which I'm assuming is the AV (the prepro). So that lead me to believe he was looking for a prepro and was going to buy an external amp. I think the 4311 will be fine with the OP's speakers without an external amp. I already had an external amp as I had an Onkyo 886 before the 4311. So I did not go out and buy the amp as I already had one. If one wants to use an external amp with an AVR as a prepro why not? But your advice to try the 4311 first before adding an external amp is very good advice without a doubt smile.gif.
Bill
post #14 of 19 Old 12-19-2012, 06:34 PM - Thread Starter
Right on fellas! Thanks a lot for all the advice. I am leaning this way now for sure.
post #15 of 19 Old 12-20-2012, 10:31 AM - Thread Starter
Anyone know if thee are gonna be good deals on this receiver after christmas? Or does anybody know of any great deals in the receiver right now?
post #16 of 19 Old 12-20-2012, 11:41 AM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
I'll toss on the same recommendation. A few years ago picked up the Denon 4308Ci and got rid of my HK + Adcom GFA 5503. Nearly broke even $$ wise and in my 17X23X9.5' room it has no problem at -7on the volume knob. Room's a rockin' at that point.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #17 of 19 Old 12-20-2012, 01:24 PM
Bill Mac's Avatar
Liked: 1440
The 4311 is no longer being made so I would grab one while you can. There is a A100 which is a special edition version of the 4311 available over at the Emotiva Lounge. Here is a link to that listing.
Bill
post #18 of 19 Old 12-20-2012, 05:42 PM
MUDCAT45's Avatar
Quoted: 346 Post(s)
Liked: 280
Bill
Do you think the UMC-1 would be a better choice? I know the UMC-200 would be the best choice, however, the UMC-1 is a bargain.
smile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gif:)Just bugging you Bill. MERRY CHRISTMAS
MUDCAT45 is online now
post #19 of 19 Old 12-20-2012, 07:08 PM
Bill Mac's Avatar
Liked: 1440
What was I thinking eek.gif. Yes you are correct the UMC-1 would be the better choice wink.gif. Merry Christmas to you as well smile.gif.
Bill
