Onkyo Integra DTR 9.9 NET/USB iRADIO Startup Problem - AVS Forum | Home Theater Discussions And Reviews
Old 12-20-2012, 03:50 PM - Thread Starter
Roc1's Avatar
My Integra DTR 9.9 is 3 years old and I have only occasionally used the NET/USB function to connect to the vTuner for internet radio. "Sometimes" it would not connect and other times it would connect. I have it wired to the router with ethernet cable (not wireless). The problem has been getting worse over time, i.e., the frequency with which it would not connect. One problem is that when it would not connect, I can't even get to the network settings. My attempts to correct the problem include: In Setup, under "7. Hardware Setup", option "6. Network" is grayed out and cannot be selected.
However, one time when the connection with the router did work, "6. Network" was not grayed out so I was able to select "6. Network" and see all the settings (IP addresses, etc.). So I changed DHCP to Disable and gave it all the same IP addresses, DNS Server addresses, etc., thinking it may help to use a static IP address instead of relying on DHCP to do the configuration correctly every time. This worked fine for awhile, even with several power downs and new starts but sure enough, a few days later, it would not connect.
Note that I am 100% certain that it is not my router or ethernet cable because I connected the same cable to other devices (Bravia TV and Blu-ray player) to confirm that the ethernet cable and router are fine. So I went ahead and attempted a system reset to the factory defaults (by holding down the [VCR/DVR] button and pressing the [On/Standby] button). When you do this reset, it is supposed to display a "Clear" message on the receiver's screen and then enter Standby mode. Surprisingly, it did not do this. Instead, the screen message was "NET Clear, Skip [ENT]". More precisely, "NET Clear" appeared above "Skip [ENT]" on the receiver screen. I tried this several times and it would not do a reset until I pressed the "enter" button on the receiver. Then it did the reset to the factory settings, except for the Network settings. Presumable the "Skip [ent]" bypassed clearing of the network settings or something.
I called Integra customer service and the technician was very helpful and interested; however, after about 45 minutes of trying this and that, no luck. He had never even heard of the "NET Clear, Skip [ENT]" result from attempting a reset. He thinks the problem may be with the receiver itself. He also didn't think the "6. Network" settings option should have been grayed out regardless of whether an ethernet cable was even plugged in.
Has anybody experienced this kind of issue?
Roc1
Roc1 is offline
Old 01-03-2013, 05:47 AM
heatman5's Avatar
it's fine that you assigned a static ip address at the receiver, but you still have to reserve that exact ip address in the router's setup menu. Without reserving the address, the router only allowed the receiver to use it until the lease expired, then it made it available to other users because it wasn't reserved. I believe most if not all routers support this feature.
heatman5 is offline
Old 01-04-2013, 03:02 PM - Thread Starter
Roc1's Avatar
Thank you very much, heatman5. Your advice was a great clue that it was not enough that I set the IP address static on the receiver. I managed to find (logged in to my router) that I could set the lease type to be static for this IP address. The way I did it in my Actiontec MI424-WR router: I went to Advanced> yes> IP Address Distribution> Connection List> New Static Connection> and filled in a host name , the IP Address I had previously set in the receiver, and its Mac Address. Then, back in my Connection List (DHCP Connections), click on "IntegtraDTR99" in my list to be sure "Static Lease Type" is checked.
At this point I still couldn't connect to the receiver and was concerned because the "Status" for this item was "Expired". Further research implied to me (in a Verizon forum) that I either needed to "RELEASE the current DHCP address" somehow or reboot the router or maybe renew the lease. Rebooting the router was easy enough but did not do the trick.
I hesitated trying to click on "Renew" or "Release" the DHCP Lease on the Configure Broadband Configuration (Ethernet) page because I am not familiar enough with this action and potential side effects.
I also picked up that a DHCP lease is automatically released after the router is turned off for two hours so I put this off for the evening and turned off the router overnight. And in the morning, turning everything back on, low and behold, I was able to connect. Once connected, I went into the receiver's Setup Menu > Hardware Setup > Network > Control=Enable. (I had previously left this set to Disable on the advice from an Integra CS rep in November when I was initially trying to resolve this issue but in a convoluted way, the router settings must have been the bigger problem). The advice to go back and set Control = Enable came from my dealer Customer Service: Thank you, Barb and Gabriel!
As an aside, the reason I believed the router settings were fine before was because I had a separate problem in which my HP All-in-One printer would very often go off-line and the fix was to go into the printer settings (on the printer itself under "setup") and print out the network settings; then log into the printer using the printer's IP address as the URL and go into Networking> IP Configuration> Select "Manual IP" and provide the configuration numbers from the printout. The "Printer Offline" problem went completely away and I never had to change any settings in the router.
So, at least for now, all seems well (fingers crossed).
Roc1 is offline
Old 02-15-2013, 06:51 PM
m1yag1's Avatar
So the network grayed out went away when you reconfigured your router? Was your remote control function grayed out aswell? Is it still working?
m1yag1 is offline
Old 02-15-2013, 09:01 PM - Thread Starter
Roc1's Avatar
Actually, no. Not yet but still pursuing it. I declared victory too soon in my posting of Jan 4 and since the problem returned, I want to resolve it for sure before giving the full followup. But I can say that there is a deeper problem in which something is causing the Network Interface Card to go bad and that is when the "6. Network" setting is grayed out. As it turns out, the way it's supposed to work is that when the unit is turned on, it may take a minute for the NIC to be recognized (during which time the Network setting will be grayed out) but then it is not supposed to be grayed out even if there isn't even an Ethernet cable connected. I now have some of the best and the brightest about to look into this. I will update this posting when it gets resolved.
Meanwhile, with regard to your question about the router configuration, none of that was the problem. In summary, I have tried all combinations of Network settings, e.g., Control=Enable/Disable, DHCP=Enable/Disable, Dynamic /Static IP addressing, router DHCP ranges inclusive/exclusive of the static IP address (including DHCP with/without Static IP address reservation). It always comes back to the Network settings being grayed out and inaccessible, particularly after a disconnection from the router and/or router turned off.
Roc1 is offline
Old 02-16-2013, 07:26 PM
m1yag1's Avatar
So sorry man, my onkyo is the same. After reading hours of forum thread I've found that onkyo/Integra has had this problem for years and as the brand new models age the same happens to them. Hope they get yours fixed
m1yag1 is offline
Old 04-01-2013, 10:21 AM - Thread Starter
Roc1's Avatar
I thought I should wrap this up with a final update. The Technical Evaluation on the DTR-9.9 determined that the intermittent problem was somewhere in the complex circuitry that involves the communication between the HDMI board and the NIC. It would require time consuming and expensive further testing to trace it to precisely the exact part of the circuitry. So rather than most likely replace the HDMI board and do further testing, we made a decision to trade up to the newer DTR-80.3. So this is one time Paul Harvey could say, "We will never know the rest of the story!"
Roc1 is offline
Old 12-05-2014, 12:15 AM
PeterPL's Avatar
I have same problem with my Onkyo TX-NR905, when I try do factory reset it shows "Net Clear skip [ent]" no pure "Clear" my network and USB port do not work anymore.
Did you resolved your problem ? if yes what was the problem. I will be very appreciate for any information.
Thank You.
PeterPL is offline
Old 12-05-2014, 08:56 AM - Thread Starter
Roc1's Avatar
Thank You.
Peter, I sent a fairly long reply but now I can't see it and don't know if it got sent to you. Let me know if you got it and if so, please copy and paste my reply in a new post so others can benefit.
Roc1
Roc1 is offline
Old 12-05-2014, 09:16 AM - Thread Starter
Roc1's Avatar
Roc1
Peter,
The problem couldn’t be fixed in the end. Even replacing the network card didn’t resolve the problem. Onkyo USA even looked at it and implied that the problem was inherent in the complex circuitry and couldn’t be fixed (an inherent flaw in the design). So I traded up to the DTR-80.3 and haven’t had a single problem since. That was over a year and a half ago and confirms that there was no problem with my router, network cabling, or any network settings. I suspect you have the same problem with your TX-NR905 and there is no problem with your network.
I suggest you do one of the following three options:
1. Sell your TX-NR905 and buy the latest model or at least the DTR-80.3. It has many more network options for music apps than the vTuner anyway, e.g., Pandora, Spotify, and a slew of others.
2. Keep your TX-NR905 and buy an inexpensive box such as a Roku 3 for streaming the music (and other stuff). You will need to include your TV in the setup but you can still send your music to the TX-NR905.
3. Option 3 is to leave everything the way it is and put up with the intermittent problem of the network streaming.
Hope this helps and good luck with your decision.
Roc1
Roc1 is offline
Old 12-05-2014, 10:43 PM
PeterPL's Avatar
Thank you very much for answer here, I checked PM and do not received any message from you.
That's very bad news for me that even autorized Onkyo service in USA couldn't repair that does they told you maybe what could cause this problem ?
I'm 100% sure that's not my network problem I used this network always same configuration for about 4 years till now without any problems, all other my devices work perfect from this network, TV, HTPC, PS3, X360 they are all see my DLNA server.
USB port also don't work, when I insert pendrive nothing happen only solid light from it, should blink when is inserted when checking it/reading, of course I tried with all my pendrives of course they are formated to FAT32 as always.
I upload video with that problem.
I checked firmware versions from dispaly and looks like it miss firmware for Net because shows "?" but of course that could be not only firmware issue.
Main 9....1.08 / 08223A
SR8051...08214A
SR8052...07518A
SR8053...07820B
HDMI......1.01 / 07706A
Video......07606E00924
Net........?
Net usr...blank
Net rfs...blank
Net krn....blank
Net ipl...blank
I will try to send it for repair in authorized Onkyo service in Poland, and let you know what they will tell me doing diagnostic. I will send it after new year, because now they have a lot of work and recomended me to send later.
If my unit also they will can't fix this I think I will have to find some external USB/Network player which have some small display, because for music listening I don't want to use also TV. Maybe you know any good models like this ?
Thanks again for answer!
Ohh and forgot to say, about this Factory reset, I also was confused when display shows me "Net Clear skip [ent] not pure Clear and then I have to confirm that by Enter button then show Clear. I asked them in service and they told me that's correct for that model, even more they send me a video to confirm this.
But this kind of reset is for me bad, because looks like it not clear Network settings at all, it skips them.
After this factory reset when I enter to Server or iRadio I see on right side of list white bars which they are in different level which look like they stay there when was correct connection with internet and shows list for example with my iRadio stations.
PeterPL is offline
