Audio network streamer options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-25-2012, 10:37 AM - Thread Starter
djrumour's Avatar
Hi All,
I am trying to work may way around finding solution for streaming audio from NAS to my receiver (controlled via smart phone app). I see that my options are Logitech Squeezebox (phased out) , Sonos connect (expensive) and other 500+ network players from Denon, Marantz....
I wanted to know if there are other options to make this work with out spending too much as my receiver will do the DA job.
Prob with sonos connect/ZP90
Its really expensive for what it does ($350)
can not play files greater than 16 bps
any and all help will be appreciated.
djrumour is offline
post #2 of 3 Old 12-25-2012, 10:55 AM
kousikb's Avatar
If you can add a display near your receiver, you can use wdtv. Wdtv can stream from NFS as well as samba mount. It also does most of the internet radio including spotify (need premium sub). Wdtv has both iOS and android app, but you still need a display like at least a 7" LCD ($20 in amazon/eBay) or better a tv to browse between various apps.
kousikb is offline
post #3 of 3 Old 12-25-2012, 11:31 AM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
I use this:
http://www.nch.com.au/streaming/index.html
Streams from my server to my Yamaha RX-A3000 just fine.
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
