Which Receiver should I buy and why??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 12-26-2012, 12:38 AM - Thread Starter
harpj's Avatar
My choices are between these three Receivers.
Onkyo TX-NR818
Yamaha AVENTAGE RX-A820
Sony STR-DA1800ES
harpj is offline
post #2 of 13 Old 12-26-2012, 01:02 AM
pokekevin's Avatar
Liked: 102
Id recommend the 818 since it has XT32 which could be useful.
pokekevin is offline
post #3 of 13 Old 12-26-2012, 11:37 AM
Jinjuku's Avatar
Quoted: 57 Post(s)
Liked: 141
I would just post a budget and see what fits. At least that is my recommendation.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #4 of 13 Old 12-26-2012, 01:50 PM
afrogt's Avatar
Quoted: 597 Post(s)
Liked: 536
Originally Posted by harpj View Post
Doesn't the sony receiver and yamaha have that auto calibration feature just like the onkyo though.
Pretty much all new receivers except entry level models can setup channel levels, distance and crossover settings nowadays, but some receivers also eq the system to your specific room.
Yamaha has Proprietary calibration software called YPAO and the version on that receiver does not EQ the subwoofer. Don't know what Sony uses but it isn't Audyssey.
MultEQ XT32 is the highest level of Audyssey calibration available on consumer receivers. Much higher resolution filters than MultEQ or MutlEQ XT. You can also EQ dual subwoofers.
http://www.audyssey.com/audio-technology/multeq
Afro GT
afrogt is offline
post #5 of 13 Old 12-26-2012, 02:38 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1225
The manufacturer's web site spec sheets contain information about what auto calibration they features they have. It is skectchy in some cases, but it is there.
You can find more details about how the autocalibraion works in the user's manuals which are also downloadable from the same source. There are also AVS web site threads that expand on them.
arnyk is offline
post #6 of 13 Old 12-30-2012, 06:25 PM - Thread Starter
harpj's Avatar
Anyone else with any feedback.
harpj is offline
post #7 of 13 Old 12-30-2012, 08:55 PM
lodit's Avatar
Before you decide on a receiver, here's a quick checklist you may want to use before soliciting member opinions:
1. What's my main use for the receiver (music and/or movies)?
2. What's my audio/video setup where I plan to use the receiver (how many speakers, subwoofers, zones, source unit(s), display unit(s))?
3. What's my budget?
Come back with the answers to those three questions, and other members will surely chime in with recommendations.
The best bang for your buck will still require research on your part, recommendations notwithstanding.
Good luck!
lodit is offline
post #8 of 13 Old 12-30-2012, 10:28 PM
domos's Avatar
Good luck!
I'm looking for a reciever to buy, too
1. movies almost 100%
2. I have 5.1 B&W mt-25 satellite speakers, and HTPC
3. under $850
I'm considering these candidates,
1.Marantz SR5007,NR1603
2.Yamaha RX-V673
3.Denon AVR-1713,2113
plz help me to choose among these receivers.
domos is offline
post #9 of 13 Old 12-30-2012, 11:27 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 7319 Post(s)
Liked: 3370
Either the 5007 or 2113CI would be good choices, both featuring the higher version of Audyssey MultEQ XT with the 5007 offering a few more connectivity options (eg. EXT IN, main zone pre-outs).
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
Authorized dealer: Denon, Marantz, Yamaha, Onkyo, Sony, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is online now
post #10 of 13 Old 01-07-2013, 12:45 PM - Thread Starter
harpj's Avatar
Onkyo TX-NR818
Sony STR-DA1800ES
Here's my details
1. Blu-ray movies/3D Blu-ray movies/Gaming
2. Setup 7.2 with 6 Harman Kardon SAT-TS7 satellite speakers, 1 Harman Kardon CEN-TS7 Centre speaker and 2 Polk Audio PSW-505 subs. Sony HX-850 TV
3. Under $1000
harpj is offline
post #11 of 13 Old 01-07-2013, 01:24 PM
Knucklehead90's Avatar
Quoted: 260 Post(s)
Liked: 274
I would lower the budget for an AVR and hike the budget for speakers.
Marantz AV7702 - Salk Song Towers - Crown XLS-1500
Center: Selah Audio 3-Way Custom Center - Surrounds Emotiva ERD-1 (in dipole mode)
Powered by 2x Crown XLS-1000 Amps -
Oppo BDP-103 - eD A5-350 15" Sub/12" sub
When all else fails - RTFM! ***GO SEAHAWKS***
Knucklehead90 is offline
post #12 of 13 Old 01-07-2013, 06:08 PM
javygonx's Avatar
Quoted: 51 Post(s)
My vote goes for Onkyo 818 or skip all and get Pioneer Sc-61. I met someone which had 818 and pioneer sc-61 and returned the onkyo 818. He claims it has more power, better clarity on center channel and beter surround details.
javygonx is offline
post #13 of 13 Old 09-24-2013, 08:21 PM
lodit's Avatar
Though it's not always advisable, I would suggest scouting your local B&M for Clearance and Open Box models that are higher MSRP than the ones you've listed.
Typically, though they are display or demo or customer return units, they'll have a full manufacturer's warranty from the day you buy it, and you'll still have the option to buy an extended at a more reasonable price that if you got it at MSRP or original retail.
That way, you pretty much guarantee yourself a higher (generally) quality unit with all the features and functions you need and more for the same or even better price you were going to buy at anyways.
Give your budgets at $850-$1000, I might suggest hitting your local BB and seeking out the Pioneer Elite SC-67 or even Yamaha 3020/2020, which I've seen discounted down to about $1100 or less. Make them an offer to take it off their hands, and you never know, they may just work with you to help you both out. You can usually bargain to get at least another 10% off and do the no-interest financing option if you have a BB Credit Card. Though they've changed the Rewards program so it's not as beneficial as before.
To save even more money, see if they have one or two models below those on clearance or open box display. That's how I scored a BNIB Pioneer Elite SC-57 for about half off MSRP among other things.
Good luck!
lodit is offline
Onkyo Tx Nr818 , Yamaha Rx A820 7 2 Channel Network Aventage Av Receiver , Marantz Sr5007 Home Theater Av Receiver , Yamaha Rx V673 Receiver , Denon Avr 1713 Receiver
