Denon 4520 vs. Marantz 8801 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 32 Old 12-26-2012, 10:23 AM - Thread Starter
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
Curious if anybody has compared these two for use as a pre-pro (I would not be using the amps in the Denon)? Trying to figure out why the Marantz is so much higher though feature sets appear comparable (Denon may even have a slight edge). Local dealers push what they have and talk down the other, natch, so looking for a little user feedback.
Thanks - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #2 of 32 Old 12-26-2012, 10:46 AM
Frohlich's Avatar
Quoted: 1164 Post(s)
Liked: 1112
Thanks - Don
Check the Denon 4520 thread and the AV8801 thread as this topic has come up several times. Some people think it is worth the difference in price and some don't...there is no "right" answer. JoeRod (I think that is his name) reviewed both and choose the AV8801. Good luck.
AustinJerry likes this.
Frohlich is offline
post #3 of 32 Old 12-26-2012, 11:47 AM - Thread Starter
DonH50's Avatar
Liked: 1325
Yeah, I started to wade through those threads but got lazy... Thought it might be easier to do it separately, maybe not. I am not expecting anything profound.
Thanks - Don
DonH50 is offline
post #4 of 32 Old 12-26-2012, 01:35 PM
Bill Mac's Avatar
Quoted: 1265 Post(s)
Liked: 1442
Don,
I have no experience with the 4520 or the 8801. I would think both would sound excellent and that the SQ differences would be minimal at best. I guess if the 8801 is in ones budget that might be the way to go. If the 4520 has all the features that one would want and cost is an issue then the 4520 might be the best choice. I think you will get many different opinions but none will be definitive. You could try both in your system but that is costly and time consuming.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #5 of 32 Old 12-26-2012, 03:29 PM - Thread Starter
DonH50's Avatar
Liked: 1325
Hi Bill,
I think you are right, of course. Since Marantz claims higher-performance analog stages I was curious if anybody actually noticed. My experience with (RF) current-mode amps is higher slew rate, often faster settling, but higher noise. I would not expect any real SQ difference given both have XT32. Features appear roughly the same to me, but of course for about $1k less the Denon throws in amplifiers as well. Balanced is not a concern; I could run XLRs but do not believe I would hear (let alone measure) any difference in my system. From what I have seen and read to date the Marantz GUI seems better but that's fairly low priority after setup. I wish Denon offered a way to turn off their amps (I suspect opening the case to yank the supply lines would void the warranty smile.gif ).
Like Chris, I am looking for a reason to get the 8801, but for roughly the same price I can get the 4520 with Pro and that seems a much better value. My local Denon dealer might let me take a demo home overnight, but the Marantz dealer is further away and wants a 10% restocking fee if I return. mad.gif The local Denon dealer does not usually deal on price, however, while the Marantz dealer may cut a deal.
Backup plan: Convince Chris how much better the 8801 is, then buy his 4520 for a song... smile.gif
Don
DonH50 is offline
post #6 of 32 Old 01-06-2013, 04:40 PM
Bghead8che's Avatar
I'm in the same boat as you, with the same questions.
I'm still on the fence but I have one foot on the side of the 4520.
The Denon 4520 has a few advantages:
Price
9 Channel Amplifier
DDSC
Denon Link (4th gen)
AL32
The 8801 has fewer, but some advantages on paper:
Preamp only (no wasted amps, cleaner signal)
HDAM circuitry
Copper chassis
Pure speculation at this point about which one is better. Heck, they may sound near identical!
Let us know what you decide.
-Brian
Brian R. Smith
Bghead8che is offline
post #7 of 32 Old 01-06-2013, 04:42 PM
Bghead8che's Avatar
I forgot to mention. XLR inputs/outputs are not an advantage to me. Nearly EVERY test shows that XLRs typically have a worse S/N ratio than XLRs. Go figure! eek.gif
I want the quietest connection possible.
-Brian
Brian R. Smith
post #8 of 32 Old 01-06-2013, 04:59 PM
RajeeK's Avatar
-Brian
Ummm....do you mean XLR's have a worse S/N ratio than RCA's?
For what it's worth, I had a 4520 and changed to a 8801. Both are phenominal pieces of equipment and sound wonderful. Would I say I could hear a difference....no.
RajeeK is offline
post #9 of 32 Old 01-06-2013, 05:24 PM
Bghead8che's Avatar
Nope, XLRs measure more noisy then RCA inputs in the majority of cases. This has been pointed out before. Just look at Sound&Vision and HomeTheater magazine's test reports. Opposite of what you would think!
-Brian
Brian R. Smith
post #10 of 32 Old 01-06-2013, 05:36 PM
RajeeK's Avatar
-Brian
Yup, I was getting mixed up. Thx.
RajeeK is offline
post #11 of 32 Old 04-02-2013, 08:57 AM
nezff's Avatar
Quoted: 141 Post(s)
Liked: 63
hmmm, the 8801 seems enticing. Might have to get rid of my brand new 4520. smile.gif
nezff is offline
post #12 of 32 Old 04-02-2013, 09:47 AM
Bill Mac's Avatar
Liked: 1442
What is enticing enough about the 8801 that you would want to get rid of your 4520?
Bill
Bill Mac is offline
post #13 of 32 Old 04-02-2013, 10:29 AM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
-Brian
That is not a good generalization to make. There is a reason that professional studios use XLR. You'll have to provide some links to the info you're referencing, but if anything, the conclusion might be that on a certain piece of gear the XLR inputs might not be superior. But that is far from a sweeping conclusion about the connector type in general.
Sam S is offline
post #14 of 32 Old 05-12-2013, 11:34 PM
DenonLover's Avatar
Quoted: 176 Post(s)
Liked: 40
Bill
Samsung 75” 4k UHD 8550 | Oppo BDP-105D | Paradigm Studio 100's v5 (Mains Bi-amped) | Paradigm Studio CC-690 v5 (Center) | Paradigm ADP-590 v5 (Back) | SVS PB13-Ultra (x2) | Marantz AV-7702 mkII pre/pro | Emotiva XPA-2, XPA-3, XPA-5 | Harmony Ultimate Home Remote
DenonLover is offline
post #15 of 32 Old 05-15-2013, 05:22 AM
Hifi4Hobby's Avatar
Perhaps 8801 is a dedicated processor with strengthened pre amp section featuring Marantz HDAM whereas the 4520 is just merely a AVR with perhaps the same digital boards and some analog but nothing beats a dedicated processor for sound smile.gif
Hifi4Hobby is offline
post #16 of 32 Old 05-15-2013, 09:10 AM
rec93's Avatar
My only question is about power consumption, my Marantz AV7005 only consumes 60 watts. I think the 8801 should be similar.
What about an AV receiver? Are the unused amps affecting power consumption?
rec93 is offline
post #17 of 32 Old 05-15-2013, 09:34 AM
jrhooper1963's Avatar
Quoted: 55 Post(s)
Liked: 36
Don't be at all surprised, if nether the 4520 or 8801 puts the AV 7005 to shame. In my humble opinion, the AV 7005 is very much an overachiever at it's price point. Marantz really hit one out of the park on the AV 7005.
jrhooper1963 is offline
post #18 of 32 Old 05-15-2013, 09:45 AM
nezff's Avatar
Quoted: 141 Post(s)
Liked: 63
I sent my denon back for another one within the first 30 days because of it shutting down. I instead bought the marantz. I feel more comfortable with it mainly because of possible reliability issues concerning he denon.
nezff is offline
post #19 of 32 Old 05-15-2013, 06:55 PM
rec93's Avatar
I really like the AV7005, but have to accept that I'm victim of the XT32's hype. A worthy upgrade? Probably not. Discipline dictates another year from today, minimum, before pull the trigger
rec93 is offline
post #20 of 32 Old 05-15-2013, 07:57 PM
Quoted: 55 Post(s)
Liked: 36
If you have only one subwoofer in your system, and are reasonably happy, then I would just wait . IMHO YMMV
post #21 of 32 Old 07-01-2013, 11:06 AM
turnne1's Avatar
Quoted: 1755 Post(s)
Liked: 410
its more than just the capability to run dual subs
XT32 is a pretty significant upgrade for HT purposes
since I dont listen to matrixed music there are no pluses in that category
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is offline
post #22 of 32 Old 07-01-2013, 11:07 AM
turnne1's Avatar
Liked: 410
if so I bet its minimal
Warren
turnne1 is offline
post #23 of 32 Old 07-01-2013, 12:31 PM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
I blew up a 8801 after 2 hours of use doesn't say anything you just had a lemon. They are probably (i bet mcode can tell us) made at then same outsourced place now. Also the HDAM are no magic parts. I think if you are already set on using it as a pre/pro the 8801 makes more sense but if you expect changes it will mostly be in the analog parts and that you can use nice XLR connectors which for the connection alone i prefer over rca where i can.
Daniel.
for men to evolve we have to upgrade
danielo is offline
post #24 of 32 Old 07-01-2013, 12:55 PM
audiofan1's Avatar
Quoted: 1650 Post(s)
Liked: 1666
Warren
audiofan1 is offline
post #25 of 32 Old 07-01-2013, 01:46 PM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
If I had pick one I take 4520 because of the price and plus the speakers I have.
Chise is offline
post #26 of 32 Old 07-01-2013, 07:23 PM
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
Just looking at the first page of the 8801 thread shows quite a lot of differences. DAC's 32/192 dedicated to each channel better then the Denon 24/96 and up, HDAM on each channel, Troidal trans power supply bigger and better than in the Denon with amps., copper insulation 11.2 VS. 9.2, More processing power, XLR's.
If none of this matters to you, don't waste your money on the Marantz.
Lot more than that, if you are not interested in reading even the first page of the 8801 thread, buy the Denon and enjoy it. Also the 8801 is a significant upgrade over the 7005. I had one for 3 years and there is no way I would ever step down so far.
PeterK and audiofan1 like this.
Life is enjoyable with good quality
Dr_Mark is offline
post #27 of 32 Old 02-16-2014, 08:14 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
My 4520 draws one amp more power than when it is in standby mode... I think standby mode is .1 amp. I think that means it draws 125 watts (on top of standby), since my Monster says 122.5v and 1.1 amps.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #28 of 32 Old 02-17-2014, 07:27 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
Are you running dedicated 20 amp line in your house.
Chise is offline
post #29 of 32 Old 02-17-2014, 07:36 AM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Not currently, but when we get the new HT built we will be.
ellisr63 is offline
post #30 of 32 Old 02-17-2014, 07:56 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 132
My friend it makes big difference audio and video plus Im going to upgrade my electrical outlets next.
Chise is offline
Denon Avr 4520ci Receiver , Marantz Av8801
